Old 08-16-2011, 03:52 PM   #29
Excella CM's Avatar
1978 31' Excella 500
Venice , California
I finally found the kind of solar panel that seems made for an AS. It's a flexible, self-adhesive 68 watt unit the is 15" wide and 112" long and only 2/10" thick. Peel and stick right onto the roof. deep blue color with a black border. I wired it in using the old power antenna wires and put the charge controller on the inside wall where the old antenna control was mounted. The wires were too small, but there were six of them so I ganged them into two units of three. Twenty year warranty. I have never been reconciled to framed units standing proud of the surface. It's less than $200 from: There is also a 134 watt unit that is about twice as long, but will just fit the longer 'streams.
Uni-Solar Solar Laminate PVL-Series 68 Watt
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 08-16-2011, 04:22 PM   #30
timmaah's Avatar
1999 25' Safari
On , the road
Wow Those panels look cool but long. The 144W ones are 18' long but only 16" wide, and half the weight of usual 135W panels.
Looking at my roof, I think I could fit two 68W.. Am hoping to get as close to 300W as possible.
How is the adhesive? Do you think there would be a way to mechanically attach every few feet?
timmaah is offline   Reply With Quote
Old 08-16-2011, 04:28 PM   #31
Excella CM's Avatar
Venice , California
Yes, they do have potential-12V! The adhesive is very strong. Better get right the first time! Don't see why you couldn't leave gaps if they weren't too long and didn't allow the panel to flex much.
Old 08-23-2011, 11:08 AM   #32
1968 24' Tradewind
St. Pete Beach , Florida
I am new to my airstream but have many years experience with solar on my boat. I have (2) 50 watt panels and a simple 10 amp controller. I haven't plugged my 31' boat to shore power in over two years, I run my large chest frig 24/7 and any lighting, stereo, fans I need. This is FL sunshine with no shading issues and a couple days of rain/heavy clouds will start to drain my 180 AH battery bank. Cost was c. $500 for parts and shipping for quality Kyocera panels. On the Airstream I am thinking of a 50 watt panel mounted in place of the rock guard w/ a protective cover over, I'm thinking I could make it look almost original and given sunny weather it should keep up with lighting, stereo and fans.
blubadub is offline   Reply With Quote
Old 08-23-2011, 11:44 AM   #33
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Quality often is cheaper in the long run, but I can't always afford it. Our experience is that we wanted solar when we bought our Safari and the dealer installed an after market 96 w. system for around $1,000. It lasted little more than 3 years and wasn't installed properly either. The company went out of business and we were told their technology was way out of date when the dealer installed it.
Now we have a 200 AM Solar system. Is it cost effective? Maybe not. Does AM Solar have a good reputation? Yes. Does it give us lots of flexibility to use the trailer? Yes. Will there be a cheaper, better system down the road? Probably, almost certainly.
To get the most out of a solar system, you need AGM batteries and a better converter than the OEM one. That costs a lot too.
The idea of Airstreams has always been to provide a comfortable camping experience in all sorts of environments. Solar helps that goal be realized. It is not necessary just like a trailer isn't necessary. I'm still waiting for my flying car, but in the meantime I buy land-based vehicles to get around.
Gene
Old 08-30-2011, 01:47 PM   #34
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Thats a nice alternative but the Watt/sq ft is less than rigid panels. I managed to get 260 W on top of my trailer with rigid panels.
Michelle TAC MT-0
Sarah, Snowball
Old 09-01-2011, 01:21 PM   #35
Dyer, , Indiana
How long can one expect your Lifeline batteries to last?
4evrhers is offline   Reply With Quote
Old 09-01-2011, 02:07 PM   #36
UAPachyderm's Avatar
2004 28' International CCD
Birmingham , Alabama
I was told 7-8 years.
UAPachyderm is offline   Reply With Quote
Old 09-01-2011, 08:04 PM   #37
Desert Diva's Avatar
Las Cruces , New Mexico
Gene
Not so sure that I agree that you need AGM batteries to get the "most" out of a solar system. AGM are nice, but I've had my deep cycle batteries for two years and I'm doing just fine. I think the difference is marginal - IMHO...
Desert Diva is offline   Reply With Quote
Old 09-01-2011, 08:16 PM   #38
Glad you are satisfied with your deep cycles but, I assure you, the difference isn't marginal.
Old 09-01-2011, 08:34 PM   #39
Manhattan , Kansas
solar
portable (or roof mounted) contact Zamp Solar out of Bend, Oregon. Steve at Zamp is SO helpful and they are have some really cool products including a new 120 watt portable panel.
NFI on my part...it is just a cool company with great panels and a wealth of solar info. Simple to use, too.
alta vista is offline   Reply With Quote
Old 09-25-2011, 09:37 PM   #40
tr0y's Avatar
Las Vegas , Nevada
If anyone is still following this thread I have 520 watts of panels up top, and paid nowhere near the crazy prices people here are talking about. Have a look a sunelec.com great supplier great prices. They supplied both my off grid home and the trailer.
tr0y is offline   Reply With Quote
Old 09-26-2011, 02:09 PM   #41
1969 18' Caravel
Bee Cave , Texas
hi Troy, just saw your post and wondered how long is your trailer and how many batteries do you need for 540 watts?? We have been lurking on this thread and have a little 18 foot Caravel and can't get much on top and am worried about portable units. Bob Morgan
Beecavetx is offline   Reply With Quote
Old 09-27-2011, 07:40 AM   #42
2011 23' Flying Cloud
Durango , Colorado
I have found our 85 watt Kyocera panel with a Blue Sky MPPT controller/monitor sufficient for continuous (water and sewerage are our limiting factors) off-grid camping in almost any situation. We've seen many freezing nights and overcast rainy days in the six months, 8100 miles and 74 nights that we've used our 2011 FC23FB. We use the furnace, stereo/DVD player, laptop and water pump as desired. LED lighting helps a great deal. I'll add another 85 watt panel (in place of the unused TV antenna) if/when our consumption exceeds the solar capabilities. We have the original Interstate flooded gp 24 batteries which I'll change to AGM's when these expire, simply for the low maintenance. AGM's certainly have advantages - I have a large bank of Lifeline AGMs on my sailboat, but are actually not as efficient as well-maintained flooded batteries. You can do just fine with flooded batteries on solar.
Go solar, and enjoy the freedom and silence of boondocking.
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Seeking Feedback: solar solutions for full-time telecommers burnsdl Generators & Solar Power 7 08-19-2011 02:31 PM
Solar Power for Battery Maintenance Tumajin Generators & Solar Power 10 08-12-2011 06:10 AM
Solar panels Marilynperl Generators & Solar Power 6 05-27-2011 09:21 AM
Solar Power Quandary for my '58 mello mike Generators & Solar Power 7 04-06-2011 08:05 PM
Solar Panel Prices Dropping tbro Generators & Solar Power 11 03-30-2011 08:21 PM
