Old 01-14-2013, 12:23 AM   #1
1996 28' Excella
Mobile , Mississippi
What LED lights do you use?
What LED lights have you installed?
I'm looking to upgrade the florescent lights in my 1996 to LED's for more conservative usage and thought I'd see what everyone was using.
Nomadic1 is offline   Reply With Quote
Old 01-14-2013, 09:13 AM   #2
Johnco's Avatar
2006 19' Safari
Anaheim , California
We changed out all our puck fixtures with bulbs from superbrightleds.com
The have a large selection of types and color temperatures and so far, after 5 years of use, no failures. Not sure if they have a strip to retro into your fluorescent fixtures, but they have lots of component parts you can "cook" something up with.
Johnco is offline   Reply With Quote
Old 01-14-2013, 09:23 AM   #3
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Check out "LED4RV.com" We have been very happy with the products from them.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 01-14-2013, 09:56 AM   #4
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
LED lighting retrofit
http://www.airforums.com/forums/f447...hts-17392.html
retrofit leds for 6-light ceiling fixture
http://www.airforums.com/forums/f447...der-97498.html
reinventing the scare light
http://www.airforums.com/forums/f447...ght-99834.html
converting spots to LEDs
http://www.airforums.com/forums/f447...eds-99293.html
Warning: non-dimmable LEDs
http://www.airforums.com/forums/f447...eds-99694.html
Scare/Door light replacement
http://www.airforums.com/forums/f447...ent-99701.html
Zep
Old 01-15-2013, 08:33 AM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Just ran across this product line in the latest issue of Sea magazine:
Linear Lighting - Marine Lighting - Boat Lights - Yacht Lights - Imtra
A wide variery of 12vDC LED linear fixtures (designed as replacements for fluourescents), either surface mount or recessed. And because they're designed for wet conditions aboard a boat, they should work fine in a galley or bathroom as well.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-15-2013, 08:45 AM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I am using flexible LED tape to refit the existing long incandescent fixtures over the bed and in the bathroom. Not done yet, but really simple and inexpensive. There are several manufacturers.
I second the recommendation for LED4RV they are helping me with my overhead lights and are most helpful.
Old 01-15-2013, 12:34 PM   #7
Florida 55's Avatar
2008 27' Safari FB SE
Pfafftown , North Carolina
Images: 42
LED Interference
We converted our 2008 Safari 27FB to LED lights. We have found that when the overhead LED's are on, they create enough interference that we cannot pick up over the air television signals through our antenna. When we turn off the overhead LED's, the television reception returns.
Chuck
Airstream - 2008 Safari 27FB SE (Sweet Pea)
TV - 2011 Ford F250 Lariat, 6.7 Diesel, 4X4 (Brutus)
TAC FL-55 | WBCCI 3823 - Unit 12 | AIR 48265
Florida 55 is offline   Reply With Quote
Old 03-17-2013, 11:57 AM   #8
1996 28' Excella
Just wanted to say thanks, After alot of looking I used these:
LEDwholesalers 5 Meter Reel Warm White 3100K Flexible LED Ribbon 300 LEDs 16ft 2026ww-31k - Amazon.com
With these:
Amazon.com: HitLights LED PCB Strip to Strip Connector, 2 Conductor, Any Angle Turn, For SMD3528 LED Strip Lights (4 Pcs Pack): Patio, Lawn & Garden
And like them VERY much.
I just got one roll.... going to order a few more.
(Getting set for boondocking)
Old 03-18-2013, 05:51 PM   #9
outofcontrol's Avatar
1996 28' Excella
Portland , Oregon
WOW! 300 LEDs for $16? Uh, yea, I'm in. Last time I looked at doing LEDs I did the exterior lights on my Motorhome and it was about $200. The interior lights were going to be more; like $300.
With these strips I could make a whole new lighting design and just leave the stock lights in place. Awesome, and Thanks!
-Kevin
1996 Airstream Excella 28'
2007 GMC Duramax 4x4 CCSB
outofcontrol is offline   Reply With Quote
Old 03-18-2013, 06:12 PM   #10
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I did all inside Bambi lights with LEDS, purchased from Airstream. I am new owner and my radio is all static when lights are on and funny thing I have not gotten my TV to work, I bet thats why...hmmm how do I fix that?
Sbb is offline   Reply With Quote
Old 03-18-2013, 06:39 PM   #11
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Most used lamps...
All interior puck lights, over stove light, step light, porch light.
No aesthetics involved, conservation only.
From Superbright and led4rv.
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-19-2013, 08:31 AM   #12
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Originally Posted by ROBERT CROSS View Post
Most used lamps...
Same here. Have not any interference problems with radio or TV.
Ahab is offline   Reply With Quote
Old 03-19-2013, 09:07 AM   #13
1975 31' Sovereign
1977 23' Safari
Many of the LED products that use current regulators (instead of resistors) product RFI. You won't notice it if you are in an area of strong reception. The reels of LEDs do not have regulators, so they will always be interference free.
You can cut down on the RFI by soldering a small disc ceramic capacitor into the socket, or even on the LED device itself. If that doesn't solve th problem, the next step is an RF choke in one of the power leads, very close to the socket.
I've found that most of the problems are created by the small multi-LED discs that have G4 pins.
Zep
