Originally Posted by powerwiz
I told ya I'm a prepper it does 20,000 liters that's 5283 gallons of water. You tube the company and he created lifesaver water line after Katrina and Japan nuclear accident. It's filter can filter out all known virus's bacteria some radiological and fecal matter.
5283 gallons = 1,057 containers (5 gal/container) which would give you enough for 27 fills per filter change, for use in your AS, using 7.8 containers to full, assuming 39 gallons to a full tank !
As a "prepper", does that mean you use this container all the time for your water needs? Just curious.... As I am not a prepper, my wife pointed out, trying to use this device could substantially cut into my retirement budget and my play time; not to mention the lifting to fill the fresh water tank in the AS each time!
I certainly would not purchase more than one of these if there was a need.
I am currently not worried about the radiological, fecal, nor virus bacteria with my current sources of water. (Maybe I should be?)
