Old 06-03-2015, 03:49 PM   #1
East Tawas , Michigan
Water heater element protection
We all know that monitor systems are not accurate. When boondocking with fresh water tank filled, how can one protect the water heating element if the level of the tank drops too low? If the element is trying to heat water and the water level is too low, the element will burn out in short order.
baylito99 is offline   Reply With Quote
Old 06-03-2015, 04:48 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
it is unlikely you will dropped the water level in the hot water heater enough to expose the heater element. The hot water comes off the top of the heater tank and the element is below that.
Not sure how you are going to be using the electric element while boon-docking without killing the batteries before you run out of water.
That is what the propane is for.
2004 Excursion 4x4
Old 06-03-2015, 05:37 PM   #3
Not really boondocking in it's true sense. Many state parks have electric but no city water.
Old 06-03-2015, 06:36 PM   #4
1974 Argosy 20
Kooskia , Idaho
The water heater is lower than any hot water outlet in the trailer and so will not empty unless you open the drain valves. It will not empty back through the pump as there is a check valve built into the pump to prevent that.
In other words, this is not an issue to worry about at all.
Old 06-03-2015, 06:45 PM   #5
JimGolden's Avatar
1977 31' Excella 500
Howie beat me to it
But really though, you could do like I do....don't turn the water heater on until 20 minutes before you need it. That way you are there if something goes wrong.
I often run gas and electric together to "double" the recovery rate.
- Jim
JimGolden is offline   Reply With Quote
Old 06-04-2015, 03:18 PM   #6
OK. Thanks for the info.
Issue installing new heater element Bex Refrigerators 9 09-14-2014 11:33 AM
where to put switch to turn on electric element for hot water Alphonse Water Heaters, Filters & Pumps 7 12-22-2012 11:11 AM
Electric water heater element: Draining dilema rfield54 Water Heaters, Filters & Pumps 4 05-19-2005 10:07 PM
heater element RM 67 remcolent Refrigerators 4 02-14-2004 06:18 AM
Coleman AC Heater Element Pick Furnaces, Heaters, Fireplaces & Air Conditioning 4 12-02-2002 02:04 PM
