Old 08-06-2012, 01:32 PM   #1
Single Slice
2004 28' Safari S/O
Livingston , Louisiana
TV battery drain
With the 7way connected, over time, will the trailer start to drain the TV's batteries? Thanks
david686 is offline   Reply With Quote
Old 08-06-2012, 01:37 PM   #2
Skater's Avatar
1995 30' Excella
Bowie , Maryland
If no one knows for your specific vehicle (which you didn't specify), the easiest way to tell would be to check voltage at the +12 charge line terminal in the 7-pin connector with the engine off. If you see voltage, it has constant power and will be connected to the camper when the engine is off. Many of them are switched, though, to prevent this. In fact, even if we do know how it should be wired, you should check anyway.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 08-06-2012, 02:03 PM   #3
Single Slice
2004 28' Safari S/O
My TV
My TV is a 2011 Ford 250 diesel. I am talking about when the TV is not running and am parked at say a rest area for the night. Thanks
Old 08-06-2012, 02:30 PM   #4
1974 Argosy 20
Kooskia , Idaho
As Skater says, depends on the specific vehicle, and you can test to see if there is 12 volts on one of the pins of your TV connector to be sure. If you have 12 volts on one of the pins when the TV is not running, your trailer and your TV will be interconnected and you could run the battery down. If no 12 volts is present it won't happen.
My 2012 Jeep Grand Cherokee has 12 volts at the TV connector all the time, so it is interconnected. Yours may or may not be, depending on what Ford did.
Old 08-06-2012, 02:56 PM   #5
Single Slice
2004 28' Safari S/O
Thanks to all
Old 08-07-2012, 08:32 AM   #6
mefly2's Avatar
2015 25' FB Eddie Bauer
My Ford F150 cut the power to the TT plug when the TV engine waws off ... but I carried a gen just in case...
