i'm in the early stages of a shell-off updating of my 22' flying cloud and my mind is on tanks at the moment. i'm planning on doing a good amount of boondocking since i've already been doing it with the tent and this is socal. i'm thinking of a 20 gallon black, 25 gallon grey, and 30 or 35 gallon fresh. what does everyone else have? are your tanks above floor or within the frame?
this is such an exciting topic, one more way to pass the work day.
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
there is lots of info in the search. i am curious as to specifically what people who boondock have. i thought it would be a fun and exciting post, but maybe not.
david
David,
I should have looked at your signature line before suggesting a search!
Dave
David,
Dave
dave, too funny. i've been thinking of a signature for awhile and i know i wanted it to say something about the search button but the words never quite came to me UNTIL i read your first response, so i went and changed my signature, and it updated it on all my posts. in other words, it wasn't there when you responded but appeared there after i changed my signature, make sense? i'm still laughing.
creampuff - i'm going to try and get the shell off this weekend so then i can assess the frame and see what i have for dimensions to work with. i can move some cross members around if needs be, i'm gonna try really hard to use stock sizes. i've looked at incaplastics.com and roncoplastics. inca looks like some possibilities. i'll send you a p.m. when i get my cavity dimensions.
david
About 3/4 or more of what we use from the fresh tank winds up as gray water. So we're about 6 gallons short there. The other 1/4 is matched by food and other drink, and winds up in the black tank (about 27 gallons). Starting out with 2 gallons in it to prevent the black mountain under the toilet, and hoping not to get within 2 gallons of max capacity, leaves right at 6 gallons spare we can use to offset the gray water capacity shortage by dumping dishwater in the toilet, etc.
But honestly, we've never maxxed those tanks out in the Airstream. The sailboat is another story, with basically the same percentages, but on a much smaller scale.
If you go with 32 gallons fresh, the 25 gallons gray and 20 gallons black should be about right, at least the way we use water.
David.
Definetly under floor.
I plan on doing the exact conversion but not for awhile. I am/ have been doing a few on other trailers and the real question is whether you want to keep them within the existing frame depth so as to mostly enclose under the bellypan, or to drop them and gain more capacity. A lot of 5-7" depth stock tanks are available and some will get you up to 25- 27 gals but no more. Most are in the 17-20 gal range - or pay more for a custom design.
I have a catalogue of stock tanks and we can work out a system if you can give me the cavity measurements.
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
I have a 2007 20ft Safari with 22 gallon fresh water, 18 gal gray and black water. Black water tank can last a long time, however, the size of fresh and gray water tanks could be larger.
Our 22' CCD has 30 gallons fresh, 20 gallons gray and 20 gallons black. We boondock almost exclusively.... wish we had more gray water capacity (30 gallons). We use a portable "blue boy" tote for the gray water if we'll be camping for more than about 5 days. That way, we can drain off 10 gallons of gray water into the blue boy, and stretch things to 7-9 days. Also, we find that we never completely fill the black water tank, and sometimes dump excessive gray water into that. With some creativity and careful use of water we can do even better than that.
Wayne
2002 22' CCD
1997 Dodge Ram 1500 5.9L
One of the reasons I bought my trailer ('99 23' Safari) is tankage: 39 (+6 in water heater) = 45 fresh, 39 gray, 39 black. I think the consensus is that almost always, the gray tank fills first unless e.g. dishwashing water, etc. is "captured" and put down the toilet. And you can always carry additonal totes, etc. of fresh water ... so to me (and my somewhat limited experience), get the largest gray water tank you can stuff in the trailer. Then a) limit shower water use, b) minimize dish washing (paper plates?), c) put wash water down the toilet, and d) carry extra fresh water, and you can boondock for a LONG time.
