Old 07-26-2016, 05:09 PM   #15
1974 27' Overlander
Baltimore , Maryland
AM solar does premium work for a premium price. $8k for the turnkey kitchen sink approach is probably reasonable if that's what you're looking for. It sounds like it's not.
How involved are you interested in getting with your electrical system? The more you DIY, the cheaper it gets ... unless you count the cost of your own time in labor and research.
1974 Overlander In Progress
TheGreatleys is offline   Reply With Quote
Old 07-26-2016, 10:38 PM   #16
time2play's Avatar
2013 30' Classic
Kent , Washington
TheGreatleys, Thanks for your response. We definitely have to do more research on this. We are not DIY'ers, so if we decide to go with solar, we're going to pay to have it done.
Anyway, thanks again. I appreciate your response.
Yolanda (and Phil)
2013 30' Classic Limited
2015 GMC Sierra Denali 2500HD
ProPride 3P Trailer Sway Control Hitch
WBCCI #7878
time2play is offline   Reply With Quote
Old 07-26-2016, 11:29 PM   #17
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
As was mentioned somewhere back I think if you really want to learn for yourself about the whole solar issue then you need to read
gandttimes is offline   Reply With Quote
Old 07-26-2016, 11:34 PM   #18
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
Whoops!Meant to say, you need to read Handy Bob's solar blog.
Old 07-26-2016, 11:45 PM   #19
lewster's Avatar
Naples, FL , Hood River, OR
This is a good place to start reading: http://www.amsolarrv.com/rveducation/
Old 07-27-2016, 12:40 AM   #20
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
It is good reading but it is only one view. And that is from the retailer. The thing I like and respect about Bob Shearer is that he totally lives off the grid and probably has more real experience about solar than a retailer who is only trying to sell.
Old 07-27-2016, 12:52 AM   #21
lewster's Avatar
I don't really want to get in to a pissing contest with you about 'Angry Bob' and his obvious biases.
I'll simply remind you that Greg Holder, founder of AM Solar virtually started the RV solar field almost 30 years ago and has been living with solar for the same amount of time. As far as experience, when 'Angry Bob' has passed several thousand RV solar installations, as AM Solar has, you can start to talk to me about 'experience'!!
They are not simply a reseller, but also a solar panel manufacturer and designer and are responsible for bringing the GS-100 high efficiency compact 100 watt solar panel to market thru Grape Solar along with the first solar charge controller (Heliotrope) that was specifically designed for RV use.
DON'T MAKE 'FACTUAL' STATEMENTS ABOUT PEOPLE OR ENTITIES THAT YOU HAVE LITTLE TO NO FACTUAL KNOWLEDGE ABOUT!!!
Old 07-27-2016, 02:51 AM   #22
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
Ditto!
George
Old 07-27-2016, 07:03 AM   #23
2015 23' Flying Cloud
Livermore , California
We have 200 W (Zamp) on our FC 23D and that is sufficient for our boondocking purposes. Bay Area Airstream installed it. I like the Zamp sheets and didn't want to piece together a bulkier system.
cactusjk is offline   Reply With Quote
Old 07-30-2016, 04:09 PM   #24
2013 27' FB International
Bozeman , Montana
I got a 15k quote from precision rv!! Lol
GratefulDad is offline   Reply With Quote
Old 07-30-2016, 05:04 PM   #25
time2play's Avatar
2013 30' Classic
Kent , Washington
Wow!
Yolanda (and Phil)
WBCCI #7878
Old 07-30-2016, 06:02 PM   #26
2015 30' Classic
Pleasanton , California
You could DIY a quality 400 W system for your Classic, like I did for mine, for less than $1500. You'll need some basic mechanical and electrical skills but it's not that difficult. It was made even easier since I was able to reuse the solar pre-wiring and CAT5 cable.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 07-30-2016, 07:42 PM   #27
Rich and Kat
AIRHEDS's Avatar
Virginia ... near ... , Washington, D.C.
ALANO, can you please provide more details, and if inappropriate to post here, PM me? I thought I just read that the standard AS 10GA pre-wiring was not enough capacity to even add a third 80W panel. Or do I have this wrong?
Rich
Rich
2017 Classic 30', ProPride 3P Hitch, 2016 RAM 3500 Laramie Crew Cab 4x4 SRW w/ 6.7L Cummins Turbo Diesel and Retrax Pro MX Tonneau Cover
KB2ZMF
Save
AIRHEDS is offline   Reply With Quote
Old 07-31-2016, 01:21 AM   #28
2015 30' Classic
The goal is to keep the voltage losses due to the pre-wiring to less than 3%. If your solar charger can handle a higher input voltage you can then stack identical panels in series. When you do this the output voltage of your solar array is doubled, the voltage drop due to the cable remains constant, and the voltage loss due to the pre-wiring is cut in half. To give you an example, I have (4) 100 W panels connected in a series/parallel configuration. Even with the 10 AWG solar pre-wiring in my 30' classic the voltage loss due to the pre-wiring is about 2%. I'm using a Blue Sky 3024 MPPT controller. You're configuration may differ but as long as you use a MPPT controller rated for series connected panels you can safely and efficiently reuse the existing solar pre-wiring.
Al, K6IV
Zamp 160 watt portable solar dznf0g Generators & Solar Power 20 03-02-2016 07:10 PM
160W Portable Solar Kit (Zamp) chrij0ir 2009-2015 Flying Cloud 1 02-22-2015 12:53 PM
Zamp Solar-80w portable charging kit-questions EmoryRiver Generators & Solar Power 5 05-14-2013 03:25 PM
