Post #64... DITTO.
I sold the 2014 and included the Costco Solar Panel.
Purchased the 2019 and had two 80 watt Solar Panels installed with AGM batteries from Las Vegas Airstream and they were wired properly, panels secured on the roof. They were charging the batteries before we drove off into the Sunset to Boulder City... with Hoover Dam electric power... not even needed to keep this thing lit up.
If that was not enough, Costco had a sale on their 100 watt panels for $120 plus State tax delivered to our door, again. The 2019 has a plug, + and -. The Solar Panel has a + and -. The included controller that came with the Costco panel and a + and -. The factory on the battery box has a Zamp Solar system ready to plug in with an external Solar Panel in the 2019, marked + and -.
I took the + of the controller, connected it to the + battery terminal on one battery.
I took the - of the controller, connected it to the other battery's -.
I took the Airstream's included plug that fits into the Zamp Solar outlet on the Battery box, wired the Solar Panel to the + and - wires. Plugged it in with my adding about 10 feet of extension cord, spliced and secured to move the panel around at will.
Put the Costco purchased Solar Panel in the Sun... The light has a green/yellow when not charging. When the battery voltage dropped... the CHARGING began.
Now with the two 80 watt panels and the 100 watt portable Costco purchase... our batteries are 100% every day.
This is so simple, add a second and wire the controller up the same and have TWO 100 watt panels for under $250.
Just follow simple instructions and you have saved enough to upgrade to 16 inch wheels and 16 inch Michelins! If a Yahoo, like myself, in basic electronics can do this... by following the + and -, you will have no problem.
Photo #61 is the 2014 25 foot International.
This is so easy if you just follow the + and -, why pay a thousand or more to have someone else 'do you a favor'? Have your... husband... help if you need to move the panel into the Sun and follow the polarity to the batteries.
Do not be shocked to find the Solar Controller has very thin wires to connect to the heavy wiring for the rest of the set up. If you can solder the wiring, best. Although you can use a twist cap and then wrap securely with all the black electrical tape you want to use. Buy 3M electrical tape. The cheaper stuff is exactly what you are paying for... cheap.
Call me
Ray and sing You are my Sunshine, My only Sunshine... when the Sun is out. Not at night, but set it up at Sunset to catch the Sunrise Sun while you are in bed. This works. I am not making a cent off of this, unlike Honest Elvin the electrician.
If I need a second added panel... I do not know for what other than if YOUR batteries were dead... or a third, figure up the numbers. If it works... tell us about it.
If this does not work. Take photos of what you did, so we don't.
