12-09-2014, 08:12 PM
#121
2018 33' Classic
Newport
, Pennsylvania
Originally Posted by BlueMesa
Honda EU7000IS
Awesome. Runs both of my a/c
VERY quiet
About $3800 shipped
250 lbs. has wheels.
May I ask where you got it for $3800
12-09-2014, 08:14 PM
#122
2018 33' Classic
Newport
, Pennsylvania
Do you run both off of the 30 amp receptacle or use the 30 and a 20 so you 50 amp plug goes in a pigtail
12-10-2014, 04:27 AM
#123
2015 30' International
Springdale
, Arkansas
http://www.electricgeneratorsdirect....or/p14017.html
Sorry was $3999 with no tax, free shipping and free lift gate service.
As to the power. You run it on 240 mode which means 22.9 amps in each 120v leg. Likely nothing in your AS runs in 240, but the 50 amp plug brings in two 120v legs just like your house. The AS then typically has one a/c plus microwave on one leg and the other a/c and hit water in the other. The last two circuits (split one on each leg), then split up the outlets with one having the 12v converter on it. Hope this helps.
Do a search of "Honda EU7000" in the electrical generator forum (can't remember how to post link). Also in that post is where to get the adapter that goes from your 4 prong 50 amp to the 4 prong outlet on the generator. You'll also see a chart of power output for the generator.
Also the generator is EFI so very easy to start even if you have to use the cord (has electric start).
Good luck.
12-10-2014, 04:47 PM
#124
2014 30' FB FC Bunk
Hoover
, Alabama
We like out eu7000 so far - it doubles for home backup as well
12-11-2014, 07:40 AM
#126
2014 30' FB FC Bunk
Hoover
, Alabama
SOLAR or GENERATOR? That is the question for Boondockers...
That bit about inadequate prewiring (too small gage if I recall) is depressing/annoying
12-11-2014, 08:55 AM
#127
2007 22' International CCD
Corona
Inadequate prewiring is not surprising. What surprised me was being unable to find the roof end of ours. We gave up and did it right.
12-13-2014, 10:31 AM
#128
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Originally Posted by SeeMore
Thanks for the information and links. I have a 22" visio tv powered by 12v that I stumbled across at Sams about 3 years ago. I then went to my "electronics junk drawer" and found a 12v cigarette power cord that just happended to fit.
The Amazon link also shows the very simple and inexpensive mounting bracket that works well and that I have used several times for mounting 22"- 24" led tv's.
I will only add that the Jack antenna also comes with a 12v power supply that works great, so no inverter required to watch a little tv.
Dan
12-14-2014, 11:06 PM
#129
1974 Argosy 20
Kooskia
, Idaho
I am going to be bold and say I disagree with lewster about the solar pre wire on SOME of the Airstreams. On my FC 20, the wire is #10 and runs from the front vent to the area where all the battery connections are made, under the front bed. It is adequate for up to 200 watts of panels in my opinion. In fact that is what I have installed on my FC 20, two 100 watt panels. I am glad it was there, it made my installation much easier.
I have a Blue Sky MPPT charge controller and when the batteries are discharged enough to take all the panels can put out, I measure about 11 amps of charge current. The battery charge voltage is in the 13.6 v range so the panels are producing 13.6 x 11 amps = 150 watts. For panels flat (not tilted) in the North West summer that is a very fair ratio of rated vs. actual watt performance. You will never get 200 watts from a 200 watt panel system do to the way they are rated and the losses that always occur.
The 11 amps I measure is not going to cause a significant voltage loss or efficiency drop on the short run of #10 wire involved. The MPPT charge controller, located inside but near the batteries compensates for the voltage drop (panels put out in the 17.5 to 18 volt range to begin with).
Now, if the wire run is very long, and it may be on some Airstreams, there may be higher losses which could be unacceptable. And if you wish more than 200 watts of panels a wiring upgrade certainly would be advisable. But for a reasonable average solar system the pre wire can work just fine.
For what it is worth, I have been working with solar electric systems since 1995 when I put my first 1000 watt system in place at my own home. It has been since moved from Idaho to a friends off grid home in NM, where it still provides all the power for his homestead. Most of the panels are original, and the inverter has been running virtually 24/7/52 since the mid 90's with only one repair. I also do volunteer solar work for the Forest Service and have a number of systems in place which I designed and maintain.
12-15-2014, 05:32 AM
#130
Naples
No Problem! We spec all of our systems with 2% voltage drop or LESS. Aside from inadequate wiring, Airstream uses wire runs that are excessive and connect the charge lines to the bus bars rather than directly to the batteries.
We (myself and AM Solar) feel differently and want our installations to capture every drop of voltage and current for maximum efficiency. I see an increasing number of solar charge systems on RVs now that have been supplied by manufacturers. Unfortunately, many are not worth the cost of the panels. Everyone has their tolerances.......ours just happen to be lower than most.
lewster
12-15-2014, 11:15 AM
#131
Corona
My issue with the AS pre-are on my rig was that I could only find the end of the wires near the rely below the bed. We had no clue where the other end was hiding.
Our controller is neatly mounted in a custom hole in the end of the overhead cabinet next to the closet, and the very heavy cable from the AM Solar kit interconnects the roof junction box, controller, and runs to the batteries. We have very little voltage drop and plenty of charge current in good conditions.
It's worth the holes in the roof, IMHO. We sealed it carefully and have had no leaks.
12-15-2014, 11:38 AM
#132
2009 23' FB Flying Cloud
Canmore
, Alberta
The other end of the AS pre-wire will generally be alongside the edge of the front Fantastic Fan opening. It can be a little difficult to find even when you know it's there.
12-15-2014, 12:13 PM
#133
Corona
Ah, now I know. That would have not been usable given where we put the controller and panel. It worked out better to use the bigger wire and run it in the closet area.
Thanks.
