Old 02-07-2016, 07:38 PM   #1
2010 19' Flying Cloud
tucson , Arizona
Solar generator for powering laptop?
I have a 19 foot Flying Cloud and don't use much electricity when dry camping beyond lights. However, I do a lot of work on the computer, and the batteries in the AS do not charge laptops or my Verizon mifi.
I was doing research and came across this: a portable solar charger for laptops. http://www.voltaicsystems.com/generator
Has anyone used something like this? Does it work?
kayt is offline   Reply With Quote
Old 02-07-2016, 08:15 PM   #2
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Wouldn't you be much better off with something like this 100W solar suitcase and then use the trailer to charge your laptop?
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 02-07-2016, 08:17 PM   #3
tucson , Arizona
I'm just starting to research, so maybe that would be better. Is it easy to hook it up to the trailer?
Old 02-07-2016, 08:44 PM   #4
2015 30' Classic
Pleasanton , California
Why don't you pick up an inexpensive 600 W inverter, so you have 110 V available inside your trailer for your computer and MIFI? Select an inverter that has a low quiescent current drain while on.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 02-07-2016, 08:55 PM   #5
tucson , Arizona
hi Alano, I don't know anything about inverters so pardon if this is a dumb question: what do I do with the inverter? I searched online and it says something about a 12 volt battery? Do I buy one of those and hook the inverter to it for power?
Old 02-07-2016, 09:15 PM   #6
2015 30' Classic
An inverter converts 12 V DC into 120 V AC. You would typically connect the inverter directly to the batteries of your AS. Some folks install 120 V outlets that are wired to the inverter. However for a small inverter (600 W), many inverters come already wired with one or two 120 V outlets.
There are pure sine-wave inverters and modified sine-wave inverters. For most purposes a modified sine-wave inverter is perfectly adequate, and is cheaper and smaller than a pure sine-wave inverter.
Al, K6IV
Old 02-07-2016, 09:18 PM   #7
tucson , Arizona
Thanks, Alano. Is it difficult or dangerous to connect the inverter to the AS batteries?
Old 02-07-2016, 09:22 PM   #8
2015 30' Classic
Only basic electrical knowledge is required to install an inverter. You'll be required to run heavy gauge wire from the inverter to the batteries depending on the distance required. I would download the installation manual for one of the better-known brands on-line (Samlex, Xantrex, GoPower, etc.) and see if you're comfortable. Otherwise, any RV shop will gladly install one.
Al, K6IV
Old 02-07-2016, 09:30 PM   #9
2014 19' International
Port Townsend , Washington
I am also interested in a portable solar unit and the 100 watt Renolgy is something I like. But am I missing something...our 19' International seems to charge our iPhones and iPads just fine, or am I wrong?
I want to solar to enable more boo docking.
LBelle is offline   Reply With Quote
Old 02-07-2016, 09:33 PM   #10
tucson , Arizona
LBelle, when I plug my laptop or iPhone into my wall outlet in my AS when the trailer isn't hooked to electricity, the devices don't charge.
Old 02-07-2016, 09:51 PM   #11
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Do you have a 12v socket? If so use a car charger.
Old 02-07-2016, 10:02 PM   #12
tucson , Arizona
hi Scott, yes I do have a 12v socket I believe, in the cabinet by the stereo. I'll try hooking up a car charger first and see if that works.
Old 02-07-2016, 10:36 PM   #13
1974 Argosy 20
Kooskia , Idaho
The Verizon MiFi can operate on 12 volts directly via a 12 volt power adaptor which reduces the voltage to the 5 volts all USB powered equipment takes. I use mine all the time that way. It uses a very small amount of 12 volt power that way. Mine measures about 50 mA.
The computer would be best powered with a small inverter. Virtually all laptops take less than 200 watts max, and average about 40 to 70 watts.
Then how you keep the trailer batteries charged when out for a lengthy time period may become a solar issue.
Old 02-08-2016, 04:58 AM   #14
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
So you can power your cell phone/tablet directly from that. To power the laptop, buy a 200w inverter you can plug in as suggested in the post above.
Then the 100w suitcase charges your batteries.
generator not powering A/C 02interstate Sprinter and B-van Forum 16 02-12-2018 03:37 PM
Generator powering A/C unit CBWELL Generators & Solar Power 3 08-01-2014 07:56 PM
Powering on the Honda Generator time2play Generators & Solar Power 16 06-25-2013 06:10 PM
Powering my Sirius receiver. Toronto_Guy Audio, Video & TV 4 10-05-2009 07:49 PM
Control center not powering up gparker Electrical - Systems, Generators, Batteries & Solar 1 07-14-2006 07:13 PM
