01-05-2017, 11:22 PM
Registered User
2016 25' Flying Cloud
Fairfield
Should I charge batteries with external battery charger
While boondocking and I am running the generator to power the heater or A/C should/can one hook up the batteries to via a BatteryMinder (or whatever brand) charger to charge them or should I let the OEM 1 stage charger charge them? If I did so I would need to put the power setting to shore mode?
Thank you,
Matti
01-06-2017, 05:38 AM
Naples
Thank you,
Matti
MUCH BETTER IDEA than allowing the OEM Parallax unit to cook your batteries from applying improper, unregulated voltage to your batteries!
Be sure to use the BatteryMINDer's temperature sensor as well.
lewster
01-06-2017, 06:57 AM
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
I don't disagree with Lewster, but keep in mind that a typical 1 amp trickle charger may take a long time to replenish your batteries.
@living.somewhere.yonder | Instagram
01-06-2017, 07:13 AM
2013 31' Classic
billings
, Montana
Your onboard original charger will do fine, I always get 6 years plus from my batteries, check the water level twice a year..
01-06-2017, 10:35 AM
Naples
The BatteryMINDer I'm suggesting is not simply a trickle charger, rather a fully adjustable unit that can charge at 2, 4, or 8 amps with charge patterns for gel, flooded or AGM batteries.
The older units were model #12248. They have been superseded by a new model which I don't have the number for.
Lew Farber
lewster
01-06-2017, 11:16 AM
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario
, Ontario
Listen to Lou!
A charger with a Charge Wizard is the way to go for sure.
I used a 'Genius' charger until I had a PD 4655 converter installed. Both worked just fine. Voltage is correct, and specific gravity is right up there.
01-06-2017, 12:10 PM
Lovin' the Mountains
Scottsdale
A little different method that I use with my 2015 25' Flying Cloud. It requires some extra monitoring but it has worked well so far. Recall that the "Use/Store" switch just inside the door will disconnect batteries from shore power when in the store mode. The only module drawing power from the batteries with the switch in "Store" is the propane detector near the floor beneath the stove. I have tapped into the lines that feed this detector and attached them to a digital volt panel meter and switch; these I have mounted beneath the kitchen sink. The switch activates the panel meter only when I need to check the battery voltage. So, the "Use/Store" switch is only in the "Use" mode when the batteries require charging - otherwise it is in the store mode. One day I'll replace the OEM battery charger and will no longer have to rely on this - but until then... I'd be interested in comments on this method.
01-06-2017, 04:04 PM
2014 23' Flying Cloud
Fair Oaks
Solar panels come with a voltmeter similar to that described by Tomsos, that gives you a continuous voltage readout. The solar panels charge the batteries with the use/store switch in either position. I monitor this meter whenever we are not connected to shore power to ascertain that the solar panels are recharging the batteries to an optimal level every day. If they don't, which happens sometimes when conditions are not sunny, or there is an unusually high draw on the batteries, then I have to recharge the batteries and if there is an unusual draw on the batteries I can't account for, I have to track it down.
01-06-2017, 05:13 PM
Blenheim Ontario
, Ontario
Why bother? There is a volt indicator in the tank monitor panel. It seems to be pretty accurate too.
Trailer Trash. ........"
01-07-2017, 12:03 AM
Registered User
Fairfield
Thank you everybody
Lewster,
Thank you for you words of wisdom. I do plan on switching out the OEM Parallax once I get the Okay from the better half. I dream and she keeps me in check. The BM 12248 was replaced by the 1500, looks like the added a desulfator stage and built the temp monitor into it.
Thank you,
Matti
01-07-2017, 11:46 AM
Scottsdale
Regarding MelGoddard's note, I have owned two Airstreams, the battery check voltage on the water panel meter bears no resemblance to the actual battery voltage. I have no idea what it is measuring.
01-10-2017, 02:57 PM
Blenheim Ontario
, Ontario
My OEM meter on the water panel, reads within .1VDC compared to two multi- meters of mine.
What can I say???😞
01-10-2017, 02:58 PM
Blenheim Ontario
, Ontario
What can I say???😞
Trailer Trash........"
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
external charger effect on electronics
thebreezeman |
Electrical - Systems, Generators, Batteries & Solar |
2 |
02-05-2015 07:37 AM |
External charger and battery ?
Rousseau |
Batteries, Univolts, Converters & Inverters |
5 |
09-01-2011 12:55 AM |
Tru charge battery charger install?
nsteel |
0 |
11-21-2007 07:09 AM |
How Long Should an Idle Battery Hold Its Charge
SilverCabin |
26 |
04-24-2007 05:43 PM |
internal charge wizard or external
dragonnfly |
8 |
07-12-2006 02:18 PM |
