Go Back   Airstream Forums > Airstream Community Forums > Boondocking
Old 07-04-2012, 06:28 PM   #1
Mifair's Avatar
2011 27 FB International
Keswick , Ontario
Refilling potable water
Im going to a park where they have fresh drinking water stations placed throughout the park not servicing each site but servicing the park as a whole for campers to bring their water containers to be filled. What water filling equipment exists that could be used to refill the potable water tank in the airstream?
What strategies do airstreamers employ to keep thei water tank topped up.
Mifair is offline   Reply With Quote
Old 07-04-2012, 06:39 PM   #2
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Do they have a way for you to dump your gray water or will you have to tote that off as well? There's a number of boondockers out here that probably have a lot of experience dealing with this.
AIR 47751
Silver Goose is offline   Reply With Quote
Old 07-04-2012, 06:41 PM   #3
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
The simplest, cheapest thing are gallon jugs and a funnel.
A funnel with a tube at the bottom would spill less water.
Five gallon jugs will mean fewer trips to the faucet, but 42 lbs. (19 kg.) to carry unless you fill it part way.
If the faucet is close and has a hose bib, you can use your water hose(s) to fill your tank. If it doesn't have one, a cheater (RV stores have them) will fasten to the faucet spigot and to a water hose. There may be rules against this as it means more water will be used than if you have to fill and carry jugs.
I'd fill the tank at home and top it off when needed. If there's no dump station, you won't be able to use much more water than the amount you started with.
Gene
Old 07-04-2012, 08:03 PM   #4
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
Easiest way for us to keep ours is ... well, not to use much water in the first place!
Lynn
ACI Big Red Number 21043
Old 07-04-2012, 08:23 PM   #5
2000 25' Excella
Northern , California
Ignoring the associated gray water issues, if the various hose bibs around the campground are within reach of the hose(s) you carry, the "water thief" device will allow you to hook up to those spigots, whether threaded or not. It's a friction fitting and tolerates low water pressure
fairly well, but if you want to speed the process, use a hose clamp to hold it on to the spigot.
Water Thief - Stanley/oliver Products 0176 - Faucets & Inlets - Camping World
Kamiak is offline   Reply With Quote
Old 07-04-2012, 08:25 PM   #6
2005 19' Safari
GLENDALE , AZ
We can add an additional seven gallons of fresh water to our 19-foot Bambi without overflowing our black and gray water tanks. We carry a seven gallon tank (from WalMart) as an emergency backup, along with several feet of clear hose (from Home Depot) that fits into the spigot. When the fresh water tank runs dry, I place the portable tank on the propane tank cover and use the hose to transfer water directly into the freshwater inlet, without a funnel. No spillage, and the water transfer takes less than a minute.
Seven gallons is enough for another shower, or a couple of extra days of dry camping (with spit baths).
A little math to calculate tank capacities and observing levels of gray and/or black tanks as they fill will determine if this may work for your model Airstream.
Old 07-04-2012, 08:38 PM   #7
"Cloudsplitter"
Thumbs up
We 'dock almost exclusively.....
A "water thief", vice grips,(to hold the spigot open), and 100' of RV hose has worked well for us for 25yrs.
Stragidy??? fill at night.
Don't forget the extreme conservation mode needed conserve water and extend time between dumps.
Old 07-05-2012, 04:29 AM   #8
ZoominC6's Avatar
2004 30' Classic Slideout
2021 33FB Classic
Colleyville , TX
Water Thief....definitely the way to go. Good luck.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 07-05-2012, 07:09 AM   #9
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I'm not familiar with this " water thief" device. Could someone please explain it's
use / function ??????
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 07-05-2012, 07:12 AM   #10
"Cloudsplitter"
Water Thief...
Old 07-05-2012, 08:47 AM   #11
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I carry 2 or 3 5-gallon containers. On the lid of one of them I removed the plastic spigot and replaced it with a brass valve to which you can attach a hose. I have a 3-foot length of clear plastic hose with a screw-on fitting to that valve. I also carry a light-weight 3-foot folding ladder.
The procedure is to take the empty containers to the fill station (spigot) and fill them, return to the trailer. Set up the ladder beside the fill hatch, place the 5-gallon container on its side on the ladder, attach the clear plastic hose, snake the end of the hose down the fill tube & open the valve. Using gravity, water flows down into the holding tank without any hassle. When the portable container is empty, I move the cap with the valve onto the next one and repeat the process.
Since we boondock in the desert, I always have the water containers in the truck so we can top up on a daily basis.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 07-05-2012, 09:40 AM   #12
HowieE's Avatar
Princeton , New Jersey
Images: 12
With 40 gallons on when we enter a park and using the campground showers we have gone more than a week without having to refill.
It depends on how you use the water.
2004 Excursion 4x4
Old 07-05-2012, 11:43 AM   #13
Wise Elder
Jammer's Avatar
2010 30' Classic
It depends how hard they're trying to discourage the filling of tanks and large containers.
In some parks these stations have threaded hose bibs and you can just hook up a hose and fill the tank. Otherwise there are Park Strategies and Countermeasures.
Park Strategy 1. No threads on hose bib. Either they've been filed off or they installed faucets that have smooth sides with no threads. Countermeasure. Use a water thief (see upthread). In most cases these work fine by themselves though you may have to hold them on. You can also up your game by using a hose clamp too.
Park Strategy 2. Spring loaded faucets that close by themselves. Coutermeasure. You can either utilize any small children traveling with you to hold these open or have available a collection of rubber bands, zip ties, vise grips, woodworking clamps, etc.
Park Strategy 3. Water squirts out of something too large to get a water thief over. Countermeasure. Fill a clean water jug and dump from that into the trailer. I recommend the Moeller Scepter water jug as it has a pour spout that works well for filling tanks in the trailer, is easier to store than the square containers, and less prone to spillage than the collapsible ones.
Park Strategy 4. Water is unavailable within reasonable hose length of any road. Countermeasure. Either use Moeller Scepter jugs as with #3, or escalate by carrying more hose.
Park Strategy 5. Water squirts out of something too large to get a water thief over and low to the ground so you can't get a a Moeller Scepter under it. I've run into this, some places really do try hard to screw things up for RVers. Also, this situation is occasionally encountered when using a natural spring as a water source. Countermeasure. I combine a small pot or pan (the largest that will fit in the available space, and a battery operated pump similar to this one: Amazon.com: American Wick Si75 Kerosene Battery Operated Syphon Pump: Home Improvement to load water into either the trailer tank or a Moeller Scepter.
General countermeasure. Beyond a certain point you're better off just filling up the Moeller Scepter jugs someplace besides the park and toting them to the trailer in your tow vehicle. This is where the collapsible jugs come in, even though they tend to leak and spill you can carry 2-3 of them along with you so that you can put 20 gallons or so of water in your car. The battery operated pump helps transfer water out of these into your trailer tank.
Chlorination. I add 1 mL per gallon of household bleach when using these methods to control any bacteria or other pathogens introduced during handling.
If you don't use the showers in the trailer you can go a long time if you arrive with full tanks.
Old 08-13-2012, 08:42 AM   #14
2015 28' Flying Cloud
Durango , Colorado
I use a 7 gal blue container (Wall-Mart) to replenish the FW tank, and can do this twice before my GW tank is full. A telescoping portable hand truck makes toting the 7 gal container much easier, or I leave it in the back of the Jeep and back up alongside the Airstream. For less than $40 I installed a small 12v SS water pump (Harbor Freight) in my refrigerator access compartment which allows me to simply drop an suction hose into the blue container sitting on the ground (or in the Jeep) and put the outlet hose into the regular FW tank fill.
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Old 08-14-2012, 11:46 AM   #15
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I use 2 6 gallon fake plastic GI cans as it is easier to carry 2 jugs than one since the weight is balanced.
I have a spare Shurflo pump rigged with a cigar lighter plug and a 12 volt outlet in a compartment near the water fill.
The pump avoids the problem of holding up the jugs and pouring the water in, plus I have a spare pump if needed.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 08-14-2012, 03:03 PM   #16
Road Geezer
Road Geezer's Avatar
2011 27' FB Flying Cloud
San Jose , California
Images: 40
I'd add one suggestion. I carry about 125'--2x50' + 1x25"--of white water hose and a thief with us when camping. I've had no problem "hogging" the water faucet, however it's configured, for the 10 to 15 minutes it takes if I simply fill up after hours. Late at night, a flashlight helps my wife let me know that the tank's full.
Road Geezer
Respect Nature
Respect Science
Respect Each Other
Road Geezer is offline   Reply With Quote
Old 08-18-2012, 06:17 AM   #17
blickcd's Avatar
Milford , Ohio
These are all great ideas but I am curious as to how long Mifair plans to stay in this location. My wife and I have survived three days without re-filling our 50 gallon fresh water tank. For a regular weekend stay of two nights, 50 gallons is more than enough with some water conservation like navy showers. If we used campground showers we could probably add another day.
For situations where we think we may need to take on fresh water, either a longer stay or having guests, the first thing I will do is try to get a map of the campground and determine the location of the water faucets in relation to my site. Then I bring what I think will be the right amount of hose.
We have 75' of white hose but I usually bring 50' of green garden hose just in case. The garden hose works okay since we don't drink water out of the trailer faucets. I also have a water thief that works well when needed.
I always have one of those collapsable water jugs on board that holds about 2 gallons. In 8 years of camping there were only a few times that I got that out and lugged two containers full from a remote faucet and dumped them in the tank. We hadn't run out of water but it was getting low so that effort was more for my peace of mind.
blickcd is offline   Reply With Quote
Old 08-22-2012, 01:38 PM   #18
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
A flexible poly bladder (often sold for use with gray water holding) can be filled with from 1-5 gallons of fresh water as you prefer. We just keep one in the TV for emergency use.
Old 08-22-2012, 03:00 PM   #19
2010 27' FB Classic
N/A , Texas
Talking about flexible bladders.
When I backpack or canoe trek., I have found that the aluminized bladder that comes in the box of wine containers to be reusable to carry water and fit in a small space when empty.
Probably too small to use adding water to the trailer but would work out well for a day hike. Or like you say, "in the TV for emergency use".
"There’s two kinds of people, them goin’ somewhere and them goin’ nowhere. And’s that what’s true". -Ben Rumson
