Nothing is that simple. The literature assumes "standard conditons" - a certain latitude, altitude, cool panel temperature, perfect alignment, clean panel, etc. You won't have any of those things. There are also Peukert effects, battery age and condition considerations, wiring voltage drop, you name it.
So here's what you should do. Set it up where and as you plan to use it, hook the system up, and see what sort of charging rate you're ACTUALLY getting. Then you'll know more. But given the large size of your battery bank, it'll take a LONG time to charge those babies up if they're seriously run down.
