Old 11-14-2015, 03:04 PM   #15
2009 25' FB Flying Cloud
Olympia , Washington
Boondocking
I have had the same problem, however I am also new and know little about electrical issues. I did get a 90 watt portable solar unit from Overland Solar that has helped a lot. The owner of Overland Solar is very helpful and has answered many questions I have had about boondocking since he does it all the time. I am in the process of installing an isolator so that I can run on one battery at a time and use the solar when possible to recharge that battery. Using one battery at a time has increased the amount of time I can dry camp considerably. He also suggested upgrading the converter since the ones installed by the factory are junk. I bought a Progressive Dynamics Converter and installed it last week. This is a 3 stage converter with a boost mode, normal mode and storage mode. It will increase the life of the battery. He did mention that if you have drained the battery too low it may have damaged the battery permanently. One problem I have is even with LED lights if I turn on the main light switch it controls 12 lights in the main section of our 2009 25' Flying Cloud FB, I don't think this is a good idea when dry camping, it just draws too much. Therefore I just turn on the lights over the table and one over the sink. It's not a lot of light though. I would like to be able to hook up only half as many lights on the main switch to limit the amount of draw but it's beyond my knowledge at this point.
Alec J is offline   Reply With Quote
Old 11-14-2015, 04:21 PM   #16
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
coincidentally, I just happened tp check the parasitic draw on our trailer last week when I had an ammeter heed up to mature brake current when I pulled the breakaway switch.
With the on/off store switch in on position, I was surprised to see that the draw was
1.45amps - a lot higher than I expected, but from what I read here here seem to indicate similar load.
I should have put the store switch in the off position to see what it dropped to - didn't think to do that. I'll check it next time I am messing around!
Brian.
When I pulled the pin on the breakaway switch I measured and additional 12.5 amps draw.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 11-14-2015, 07:13 PM   #17
Tincampers's Avatar
Sneedville , Tennessee
One thing that will help the Overland Solar unit is to remove the charger from the back and move it closer to the batteries. Having it on the panels results in a voltage drop that severely limits the charging. I was only getting 13.2 volts until I moved mine and now I can get 14.7 volts most any sunny day.
Tincampers is online now   Reply With Quote
Old 11-14-2015, 09:05 PM   #18
Burnside Bob's Avatar
1973 31' Sovereign
Mt Angel , Oregon
FWIW, anything with a remote control will have some circuitry powered 24/7. The remote controlled Fantastic Fans and Sony entertainment system are examples. Turning battery switch to 'off' will kill these drains. If you boondock a lot, you could wire in on/off switches ahead of each remote operated goodie. Then you could keep your 12V system on without the drains from these devices unless you wanted to use them.
Best, Burnside
"To err is human, to air is devine."
Burnside Bob is offline   Reply With Quote
Old 12-13-2015, 11:17 AM   #19
ddruker's Avatar
2000 27' Safari
Palo Alto , California
if you have solar, your solar controller and battery monitors are also likely a parasitic draw - at least at times when the sun isn't shining.
- Dan
1999 27' Safari + 2011 Mercedes GL 350 Turbo-diesel
ddruker is offline   Reply With Quote
Old 12-13-2015, 07:07 PM   #20
2016 30' Classic
Erie , Colorado
M and M a bit more info might help. If you don't have a Trimetric battery monitor buy an AC/DC Clamp meter. Not usually found at Home Depot/Lowes as most of what they have is AC only. I have an inexpensive one from Amazon made by Mastech.
You can out it on one of the cables on the battery and tell what actual DC amps are being drawn by the coach while the storage switch is off, then turn the storage switch on with all other appliances off, then one item at a time. Build a list so that you know what each item is doing.
Pretty important if you like to boondock to understand the impact of all the circuits in the trailer.
My 15 Classic draws .5 amps with everything 'off'. That seems to be from a couple of items. LP detector, low voltage relay for my Lithium Batteries, bit of a draw from the monitor for the BlueSky. By seeing exactly what is happening with the clamp meter I can then plan on trips out to the trailer to do a re-charge.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 12-13-2015, 08:31 PM   #21
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Clamp on meter to measure DC
I second Gary's recommendation of getting a clamp-on type meter. As he says, however, many of the cheaper ones can't measure DC. The one I use I did find at Home Depot a couple years ago. It is made by Klein. I think it cost around $100. Seems like a good unit.
SSquared is offline   Reply With Quote
12v
Parasitic electrical flow waltc 2009-2015 Flying Cloud 20 09-17-2014 05:44 AM
LCD Tv has a 12v converter... Can I use it on 12v? Keyair Audio, Video & TV 6 05-11-2010 03:40 PM
Parasitic Drain aftermath Batteries, Univolts, Converters & Inverters 9 03-15-2010 09:23 AM
kitchen draws coming apart billiards Cabinets, Counter Tops & Furnishings 2 09-08-2009 08:13 PM
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 10:58 AM
