Old 03-16-2019, 08:45 PM   #1
2017 22' Sport
Renton , Washington
One Generator with a classy carrier
Got my Torklift Lock and Load generator carrier to hold by Generac 2200i in very classy fashion all set up this week. In combination with the Micro-Air Easy Start I am able to limit myself to one small generator to power the 13500 BTU AC unit plus a nearly everything else, save the micro wave.
I wanted to keep my AS sans bumper because I really like the sloaping aesthetic being visually uninterrupted when not carrying the generator.
Really happy with this Torklift product that easily locks into the Torklift trailer hitch added to the AS.
ID:	335846   Click image for larger version
Glampman is offline   Reply With Quote
Old 03-16-2019, 08:59 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Prepare to be flamed....
Old 03-16-2019, 09:06 PM   #3
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Hahaha
Dept of “OverKill”
Old 03-16-2019, 09:48 PM   #4
2012 Avenue Coach
Corpus Christi , Texas
I say make it yours. If you're happy and it works, that's all that matters.
rowiebowie is offline   Reply With Quote
Old 03-16-2019, 09:55 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
or...genuflected 😂
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 03-16-2019, 10:18 PM   #6
2007 22' International CCD
What’s being referred to is the issue of a lot of weight way to the rear on a trailer frame that was NOT designed to handle much weight at all past the rear bumper. Weight way back there also exacerbates any tendencies to induce uncontrollable trailer sway.
It’s flat not a good idea to put heavy stuff back there for good Engineering reasons.
In a polite manner, it’s FAR safer to put that nice generator in the bed of the truck. Not a good design, and personally, I wouldn’t want you passing me on a fast downhill.
Let the usual yelling commence.
rmkrum is online now   Reply With Quote
Old 03-17-2019, 12:54 AM   #7
2017 22' Sport
Renton , Washington
Appreciate your intent relative to the weight. I tested the trailer on the freeway in quite windy conditions. No additional sway in the rear.
I am assuming your perception might be bent towards how you may distribute weight in the back of your own trailer when you travel. I am highly cognizant of weight ratios and closely monitoring my speed. Sewer tanks are empty and no other additional items weighing in the back.
I know, it is much easier to view and comment without considering nuance. Nuance is far more boring than absolutism. The world was flat until it wasn't.
Enjoy the Spring and I will enjoy the vitriol my post will likely engender. And I will have cool AC minus shore power in the meantime.
Old 03-17-2019, 01:20 AM   #8
Mach5's Avatar
2019 25' Flying Cloud
Woodland , California
Aside from the possible decrease in stability, I like the installation. A good solution to having to lift that heavy thing into the back of your vehicle all the time.
Is that a Blue Ox Swaypro rotating latch on the trailer? If so, it looks like you are at least one spring bar short. What type of weight distributing hitch are you using?
Mach5 is offline   Reply With Quote
Old 03-17-2019, 01:59 AM   #9
Mach5's Avatar
Sorry about quoting myself, but apparently I'm too late to edit my original post.
Honda Pilot probably has a class 3 hitch, with a max tow of 4500 lbs. The 22FB Sport gross is 4500 lbs, so you probably don't need weight distribution anyway, nor is it recommended by Honda.
Old 03-17-2019, 09:13 AM   #10
Streamracer's Avatar
1986 25' Sovereign
Huntsville , Alabama
Nice set up if that's what you like. I hope you have a good weatherproof cover or you will find a lot of dirt and grime from road spray. Happy camping.
Streamracer is offline   Reply With Quote
Old 03-17-2019, 09:22 AM   #11
Silverpuller's Avatar
2018 26' Flying Cloud
Thornton , Colorado
Nice, clean looking rig. If we carried a generator, I’d probably mount it exactly the same way. Until our current AS, I put a 2” hitch receiver on every trailer we’ve owned (four) and carried more weight than your generator. NEVER have had a problem.
Silverpuller is offline   Reply With Quote
Old 03-17-2019, 09:37 AM   #12
2007 27' International CCD FB
San Diego , California
That should work great for you and should have you ready to tackle some good summer camping.
Nothing wrong with how and where you have it given its minimal weight, close and tight to the body. As you don't have a bumper, it's closer and tighter still, and is less weight overall than putting on a bumper, Fiamma rack, and a couple bike, that is approved by the manufacturer. As you're well cognizant of keeping enough tongue weight, I'd say you've done your due diligence.
Great comment on the absolutism that exists on these boards.
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i
Rear Bumper Hitch
pteck is offline   Reply With Quote
Old 03-17-2019, 09:41 AM   #13
Long Island , New York
Ditto.
Just a simple factual observation that Airstream's design parameters probably do not anticipate this much weight at the rear.
Just a simple fact . . . for everyone's information.
Exceeding a manufacturer's recommendations exposes the owner to various risks, which he or she is free to ignore [blithely IMO].
No flaming etc. in these simple factual observations.
Happy trails,
Peter
PS -- The combined weight of the lift and gen is, what, about 170 pounds? [another simple fact BTW!]
Old 03-17-2019, 09:51 AM   #14
To be clear, it is not a sway or weight distribution issue that is being referenced. It is an AS structural design issue.
The AS belongs to you...see reference in my signature. 👍
IMO it really doesn't do anything aesthetically buttwise.
W. H. Auden
Amanamus
"Tahawus"
Bike Carrier-Anyone Used This One? interstateflyer General Repair Forum 1 11-29-2016 02:14 PM
Classy Flyswatter Al - K4GLU Airstream Lifestyle 1 07-22-2015 09:58 AM
69 Airstream Cafe VINTAGE RETRO CLASSY One-of-a kind Concession Food Trailer eBay Watch Airstreams on eBay 0 05-22-2012 10:00 AM
69 Airstream Cafe VINTAGE RETRO CLASSY One-of-a kind Concession Food Trailer eBay Watch Airstreams on eBay 0 03-21-2012 08:30 PM
One down, one to go.... Pick Axles 3 01-13-2003 10:31 AM
