11-05-2013, 11:24 PM
#21
Maniacal Engineer
Lopez Island
One thing I forgot to mention in yesterday's post - we removed the furnace, one of those infamous Suburban 22's, and haven't missed it yet, and sure like the extra storage space we got from removing the unit and its ducting. The power consumption of a a nice warm wool blanket and a sweater is pretty minimal, too.
Yes, I don't take the Airstream into really freezing conditions. We've been in the high thirties w/o problems. We will fit one of those beautiful Dickinson propane fireplaces at some point to help us explore Yosemite in the late fall with less of an eye on the weather.
- Bart
11-06-2013, 05:02 AM
#22
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by SSquared
You mention that you are going to "the west". Some of the west is mountains. Depending on the altitude, generators require alternative carburetor jets.....snip.....
Convert to LPG...the low pressure regulator has a mixture adjustment.
I still lose a bit of efficiency at altitude, but have no start/running problems.
The majority of our camping is in forest CG's, one hour of charging is more than adequate to keep the 2 Lifelines topped.
With strict attention we have gone 3-4 days before reaching the dreaded 12.2v.
I have 30w of flexible panel solar that works well for battery maintenance on the pad but is not helpful at all in the woods.
We used a 1000w Yamaha for 12 years with our 22 Safari. Worked sooper for keeping us powered with the single deep cycle. Went to the new owner and is still going strong.
11-06-2013, 02:02 PM
#23
2013 25' FB Flying Cloud
Longmont
That adjustable regulator on the propane system sure makes the conversion attractive!
11-06-2013, 03:07 PM
#24
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
The lpg gets routed directly to the carb venturi so it can be adjusted at the regulator. (yellow to black hose.)
It would be nice if the threads were finer for a more precise adjustment, but once done and locked it stays put.
We've been to 5000ft with no problems, there is a lot of adjustment left.
11-06-2013, 04:28 PM
#25
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I bought a 2000 gen to keep my options open. I travel in a 2500 so it is no problem. But given a do over I would get a 1000. Awful easy to pack and move.
If you moderate your use you will probably only have to recharge once or twice during your stay. It is not like you have to run the gen every day. You are going to need to dump once too.
11-06-2013, 09:21 PM
#26
1969 27' Overlander
SW
, Missouri
Great advice! I had thought about needing to re-jet, but I'm sure I will need to if we go with a generator. We will be camping at around 7,000 feet in Sequoia NP. A couple of our other stops will be around 5,000 feet I think.
11-06-2013, 09:37 PM
#27
1969 27' Overlander
SW
, Missouri
Originally Posted by switz
Our 25FB had a 150 watt solar panel. It was not enough to recover from over night furnace usage. We had LED lights.
The furnace is my biggest concern. It's hard to predict what it will use since it depends on so many variables. I know lowering the setpoint will help reduce the fan run time, but I will have a 14 month old with me and want to keep the temp around 65 at night to keep her warm enough.
11-06-2013, 11:24 PM
#28
1974 Argosy 26
Morrill
, Nebraska
Truck drivers use 12 volt electric blankets. You could keep your baby warm with one and consume much less power.
11-07-2013, 08:06 PM
#29
1969 27' Overlander
SW
, Missouri
Interesting idea, but the 12V blankets that I found consume about 50W (4.2 A) which is more than my furnace fan. I actually have some 12V heated clothing for my motorcycle, but the jacket pulls even more power at 70W.
11-07-2013, 08:54 PM
#30
Central
, Mississippi
For 9ish days off the grid you will either need to be a gen-boondocker, running a genset a few hours a day OR an extreme solar dude. Extreme solar will mean several hundred watts of panels and AH's of batteries with a minimum electrical draw each day.
Either way,water usage and disposal will really be a limiting factor in less time, specially with a young 'un!
11-07-2013, 09:44 PM
#31
1969 27' Overlander
SW
, Missouri
I have been re-thinking that situation as well and have adjusted my travel plan to reduce the consecutive days off the grid to 5 with a full hook-up park added to the mix.
I believe that I will probably add another group 29 battery to double capacity to 250 Ah regardless of whether I go with solar or a generator.
Our plans are structured to allow for dumping of the tanks and refilling the fresh tank every 3-4 days. We have mostly camped in parks with only power hookups but without plumbing. I am fairly comfortable that our water and containment capacity will be adequate for that duration.
11-08-2013, 05:03 AM
#32
Normal
I suggest a supply of what we called "blanket sleepers" for your little one.
Fleece, all one piece, with feet and a zipper up the front.
An undershirt on her little body and warm socks on her little feet, inside the jammies, will help keep her warm and toasty in cold weather and while toddling around on cold floors.
Grandma Maggie
11-08-2013, 08:02 PM
#33
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Solar or a generator- both are nice to have, but you may not need it. I have a 10 year old Honda 1000w genny that works great, but I have yet to use it camping. I bring it along for insurance.
I boondocked for 3 days in the middle of October at a music festival. Beginning voltage was 12.88v. After 3 days it was only down to 12.81. Minimal lights- all LED., minimal water pump usage, minimal furnace usage. I was camping by myself. Two 6v golf cart batteries. Fridge uses no battery power.
You can do it with out spending money for solar or a genny.
I recommend:
1. 2 6v golf cart batteries ($130 at Walmart).
2. All LED lights
3. $30 for a battery minder to keep track of battery voltage (Best Converter).
4. Coffee perculator
5. No microwave- I reheat stuff on the stove
6. If your batteries get low, charge off of TV or go to a campground with power.
Your mileage (and power use) may very.
Have fun being a power miser.
Dan
11-10-2013, 09:28 PM
#34
1987 32' Excella
Nepean
, Ontario
As part of our winter camping, I boondock for a two-week stretch every January in Quartzsite. In the desert the temperature drops considerably during the night, so heat is necessary. Here's my setup, which works for me - I do have a requirement for 110-volts for my CPAP machine.
I have 3 75-watt solar panels (225 watts in total) mounted on the roof feeding into 4 AGM batteries - two in the battery cases and two behind the gaucho. The charger/converter has been replaced with a Xantrex Freedom 3000 (3K-watt pure sine wave inverter/charger). All the lights have been converted to LED. I have added a blue-flame heater, which provides heat without any electrical draw. The blue-flame heater is only $120 on Amazon, and it is mounted in the same way as the Catalytic heaters (at less cost).
There is a lot of free camping on BLM land, and my setup is ideal for this. A side benefit is that when on the road, I can switch on the inverter and run the refrigerator on ac instead of propane.
The shore power wiring is: from the shore power cable to a junction box, then to the inverter/charger. From the inverter/charger back to the junction box - different circuit - and then to the 110-volt breaker panel. Thus, switching on the inverter provides 110-volts throughout the trailer.
I do have a generator as a backup - a cheap 3050 watt one from Harbor Freight (cost me $250 two years ago). It is a bit noisier than the Honda, but I use it sparingly.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
11-11-2013, 06:05 AM
#35
1977 31' Sovereign
Tampa Bay
I was reading about these and considering the purchase of one. However, the manual says NOT to install in an RV. Have you found any concerns or reasons why this should not be done? I have read many positive reviews on these units, numerous from RV owners using them in their rigs. Just curious. Looks like a nice inexpensive alternative... without using 12v. I had an original catalytic in my previous Airstream that worked great, but replacement costs are way more expensive than these units.
Thanks...
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
11-12-2013, 07:21 AM
#36
1987 32' Excella
Nepean
, Ontario
Because the Blue Flame is not vented to the exterior, it requires that you have a source of fresh air to avoid asphyxiation. So to err on the side of caution, they don't recommend it for RV's. Since mine is mounted beside the entryway on the side of the cabinet housing the stove, I leave the stove vent open so that fresh air gets in. I also open the vent in the shower so that there is a supply of oxygen to the rear where we sleep.
There is a huge difference between the catalytic heater and the blue flame one. The catalytic heater (which is also not really recommended for RV's for the same reason) is a radiant heater. So it radiates heat where pointed. In my case, the heater was pointed to the right side of the gaucho, which meant that was the only place that got any warmth. The left side of the gaucho was cold and there was no heat transferred to the rear of the trailer. The blue flame, on the other hand, is a convection type of heater. Cold air enters a vent at the bottom, and it is heated as it passes through two plates of tempered glass and exits the vent at the top of the heater. You can immediately feel the heat exiting as soon as it is fired up. As hot air rises, there is an air movement that ends up providing heat throughout the trailer, particularly towards the rear. The thing you will notice is that the floor is still cooler than the ceiling.
Last winter we were boondocking in Quartzsite, and the night-time temperatures dropped to 25F. We were quite comfortable with just the blue flame heater.
The Blue flame we have has just the settings for off-low-high. There is one with a thermostat, and it is my intention to swap that for my current one.
VE3JDZ
AIR 12148
WBCCI 8080
11-12-2013, 08:28 PM
#37
1969 27' Overlander
SW
, Missouri
The blue flame heater looks like a good option. I had also considered a Mr Buddy heater, but was concerned about the surface temperature with the kids. I don't have a great place to mount a catalytic type heater and it's hard to monitor everyone all the time.
I appreciate all the good ideas. I'm definitely learning a lot about power management options.
11-12-2013, 08:36 PM
#38
2014 30' FB FC Bunk
Hoover
, Alabama
this has been an excellent thread...good info...not going to be boondocking soon, but very informative for when I do down the road...
11-12-2013, 09:07 PM
#39
Central
, Mississippi
Originally Posted by Kyle401
... I'm definitely learning a lot about power management options.
After our first 'learning experience' camping in Yellowstone, we found a few things out.
We stay warm at night with a good memory foam mattress and blankets. That alone fixed 90% of the battery issues because the furnace was a horrible thing to run on battery power.
Catalytic heaters work great although we only use it while we are awake.
LED lights draw so little power that we don't even make a big deal about leaving a few on for the evening.
Feeling normal means watching a bit of television, we set up the Directv and flip channels each evening (our biggest power draw)
Lots of battery power, we used 3 big interstate group 27's
A 3 stage charger and a Honda 2000 will pump a bunch of charge in a couple of hours, monitor it with a Trimetric.
Even a small solar panel will keep up with the evil draw of the fridge...
06-24-2014, 09:32 PM
#40
1969 27' Overlander
SW
, Missouri
Thanks for all the advice. I ended up installing 300W of fixed solar on the roof and adding a second battery. In addition, I replaced all the overhead dome lights and the light over the sink with LED's. I left the incandescents in bathroom fixtures and reading lamps.
The only 120V we used was a small 140W inverter to charge our camera batteries and other electronics. All other usage was for the 12V systems in the trailer. We did end up staying off the grid for 9 consecutive days. Each night we ran the furnace set at 65F with average nightly temperatures about 45F.
The minimum voltage in the morning was 12.5V and we started every evening at 12.9V. All of our sites were partially shaded. The earliest we had full sun was 11AM. Despite this, the charge controller reached float mode by 4PM every time I thought to check it.
I'm pretty sure that I significantly overestimated my power usage. I was planning on about 40 AHr per day, but believe that actual battery load was closer to 25 AHr per day. I installed a shunt for a future AHr meter, but don't have one yet so this is sort of a best guess.
Part of the lower usage was due to worst case estimates for things like furnace run time. The remainder was due to the solar carrying most of the loads throughout the daylight hours. I was also able to use the late afternoon solar surplus to charge the electronics without cutting into the house batteries.
It was great not having to fuss with a generator. Breaking camp was easy since I only had to raise the stabilizers and hitch up. Overall, I was very pleased with the solar system's performance and would choose it again over a generator. My recommendation for new boondockers would be to go solar first. You may never want a generator.
