Old 08-23-2013, 06:05 PM   #1
wichita , Kansas
New solar panel
I intend to buy a new solar panel. The one I have is small.(factory ?)I don't know. The guy I bought it from didn't seem to know much about it. There was no paper work so I don' t know how many watts it is. I am guessing about thirty watts.my question is. Can I wire the new panel to the old one or should I chuck the old one? Thanks in advance. Your input is welcome.
tinner is offline   Reply With Quote
Old 08-23-2013, 07:20 PM   #2
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
I'm a newbie on solar, but this should get this started.
1) Go down to the auto parts store and get a digital voltmeter. With this (among other things) you can measure the output of your solar panel. The panel should have two output wires. One is positive and one is negative. Put it out in the sun and throw the voltmeter on it.
2) Become familiar with this: Watts=Amps*Volts. Solar panels deliver watts at a certain voltage. Divide the watts by the voltage to get the amps. Charge controllers are rated in maximum amps. Do you have a charge controller and what is it's max amps?
3) If you wire 2 panes together in parallel, I do not know if they need to be the same voltage and/or wattage? Maybe not, but if you wire them in series the voltage adds together.. wiring 2 12 volt panels together in series will give 24 volts. If each of them is 100 watts then you will get 100 watts (at 24 volts).
- If you do not find a new panel that matches the one that you have I do not know whether you can hook them together or not.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
