Old 02-07-2015, 02:00 PM   #1
2010 27' FB International
Simi Valley , California
Locking the Propane Cover
2010 27FB International
We plan on boondocking quite a bit and I would like to have the capability to be able to lock my propane cover to secure (I realize that anything can be broken into) my propane from being tampered with/stolen.
I'm not sure I can utilize my cover's locking mechanism since it is easily bendable (easy to remove a lock).
I would like to know what others have come up with to correct this, what I feel is an Airstream oversight, issue. Thanks
Steve_M is offline   Reply With Quote
Old 02-07-2015, 02:50 PM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I'm curious to see the replies you get to this question. I've never heard of "propane theft" being an issue for boon dockers.
Bob Martel
WBCCI# 5766
Old 02-07-2015, 03:00 PM   #3
1994 34' Excella
Warren , Manitoba
Best idea would be to use a bicycle type lock through the tank handles and around the frame. If thieves want in to the cylinders they will damage the cover. It is worth a lot more than the cylinders, and if they break in you will have the damage plus the cylinders will be gone. Just my thoughts!! Chris
WBCCI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 02-07-2015, 03:06 PM   #4
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
I tightened up the wing handle parallel with the support that is attached to the cover, drilled a hole through both, then use a Trimax padlock and place through the holes. Sorry; no pictures. TT in storage.
Steamy1 is offline   Reply With Quote
Old 02-07-2015, 03:15 PM   #5
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
This is what I use, protects tanks and the cover. Simple and well built.
RV, Trailer, Towable Propane Tank security locks - Fortress GasLock | Torklift International
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 02-07-2015, 03:34 PM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Locking the tanks
Old 02-07-2015, 04:12 PM   #7
This will work but is it necessary? We have never had anything stolen while boondocking but are careful where we stay.
I think your risk of theft is low in forest service campgrounds, state parks, and other places where there are other campers around.
The only thing we lock up are high dollar items like generators, bicycles, ect.
Propane bottles seem down the list of likely theft items.
handn is offline   Reply With Quote
Old 02-07-2015, 05:01 PM   #8
Originally Posted by ROBERT CROSS View Post
From Bob's link, post #10 is what I did. Thanks Bob!
Old 02-07-2015, 06:00 PM   #9
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I would not lock the cover, might need access to the tank in a hurry. I do lock my bottles with a long U-lock.
MICHAEL
Old 02-07-2015, 06:30 PM   #10
TinTin's Avatar
Canmore , Alberta
More concerned about the cover than the tanks...
Bob and Nancy
Old 02-07-2015, 06:38 PM   #11
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Appears that the long U-lock is the cheapest and best way to go. The Forklift lock is rather pricey.
TinCan
graysailor is offline   Reply With Quote
Old 02-07-2015, 08:17 PM   #12
LiLNomad's Avatar
2007 25' International CCD FB
Northridge , California
I dont have the cover but have my tanks locked with bicycle locks also. Im also a bit paranoid bout leaving chairs and my lil weber out also so i put those things away when I leave camp.
LilNomad
LiLNomad is offline   Reply With Quote
Old 02-08-2015, 06:20 AM   #13
FishByFly's Avatar
2017 25' Flying Cloud
Oak Park , Illinois
Lock your tanks down...boondocking or just traveling in general. After several years of having an Airstream with tanks under the cover, I had a tank stolen. The thief took one tank. The second tank allowed the cover to remain in place and look undisturbed. I now use a bike cable and lock to lock the two tanks to the frame. If someone comes prepared with bolt cutter, they are likely to take a tank. But, this should slow them down and maybe get them to just move on.
FishByFly
because I catch fish on a fly...
2005 30' Safari Bunkhouse
2010 F250 Lariat
FishByFly
2017 25' Safari FB
2010 F250 Lariat
FishByFly is offline   Reply With Quote
Old 02-08-2015, 08:39 AM   #14
Thanks all.
I don't believe that everyone is honest and it's better to be safe. As I said anything can be broken into or stolen it's just a matter of raising the hassle factor high enough that it's not worth it.
I like the lock through the handle and cross member...nice and simple. I will check out the manufactured gas lock though. Depends on the price.
Thanks again.
Propane Tanks - Locking Down RVGuyRaleigh LP Gas, Piping, Tanks & Regulators 7 02-22-2011 05:59 PM
Door locking after being slammed shut TomD32 Doors & Locks 4 06-25-2003 09:56 AM
Vacuum disks locking unexpectedly wvmiller Brakes & Brake Controllers 1 04-26-2003 10:12 AM
split differential or locking differential bryan foxx Tow Vehicles 6 01-22-2003 07:48 PM
