Old 02-01-2016, 04:24 AM   #15
andreasduess's Avatar
1984 34' International
Toronto , Ontario
We'll be doing the same thing, combining tanks.
Dumping grey water is somewhat problematic, as the bacterial contamination of grey water can also put immense pressure on a sensitive environment, especially in the desert.
However, dispersed dumping via a drip hose for example, or while travelling, should not be an issue, especially ehen using biodegradable soaps.
andreasduess is offline   Reply With Quote
Old 02-01-2016, 04:49 AM   #16
Gainesville , Florida
But dumping grayvwater might still be illegal even if using a hose dispersal method. Get rid of it at a dump statuion or where it us legal. Combining both tanks seems like a good solution. In my case that would over sixty gallons of gray. You could also dump the gray into another tank in the truck bed to extend the amount if time, using a macerater pump.
Old 02-01-2016, 04:53 AM   #17
Originally Posted by BoldAdventure View Post
Human waste when it combines, in water with TP becomes a bio-hazard and creates sewage. When it is separated, it can be handled and disposed of in an organic, non-toxic manner.
For starters, urine is sterile. And in some cases, yes you can dump it outside. It's just the same as going pee outside.
#2 goes into a composting bin with the composting material. It takes 6-8 hrs to start composting. So if it's been that long before the last use, you can dispose of it. You can purchase a "composting" bag, this is a bag designed to break down and compost itself, to place the humus in. That can legally and safel siy be placed in the trash. It will simply continue breaking down.
The pee goes into the front, a 2.1 gallon jug you can remove and take outside and dump or pour in your gray tank.
The American Water Works Association Research Foundation finds that over 30 percent of household water use is just for flushing toilets. We have all been taught the flush-and-forget system: We dont see where it goes and we dont have to deal with it (you know out of sight, out of mind). Wastewater treatment is extremely energy intensive.
Thanks forbthe info, i,m a lot more possitive to the toilet than before after reading your comments, i trust your on the road opinions,. I can now see how this can be an alternative to some who boondock or stay at cg with limited services. Thanks again.
Old 02-01-2016, 05:13 AM   #18
Toronto , Ontario
You are 100% correct of course. I do find it easier to deal with grey water than with the accumulation of black water. Grey water can be managed easier.
Old 02-01-2016, 06:44 AM   #19
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Originally Posted by andreasduess View Post
It's not human waste anymore, it is composted matter. It looks, and smells, very similar to something you'd buy at a garden centre to use on your flower beds.
Most municipalities do not allow for raw faeces to enter the garbage stream, with the exemption of diapers, dog bags and pet litter. But as we're not talking raw faeces here, we should not have an issue.
I have been told composted or not it is still legally considered human waste and cannot simply be disposed of in the household waste stream. I don't know for sure, this is what I have been told when I considered putting in a composting toilet in a home.
Old 02-01-2016, 07:21 AM   #20
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Level Up Your Boondocking - Composting Toilet Install
The unspoken answer to this argument is that the waste can be dumped anywhere "legally or illegally" so long as the disposer does not get caught.
Frankly, I am not a composting toilet fan, but imho, disposal is not a really a valid argument against their use.
Garbage is garbage, apart from toxic chemicals, (which poo does not have), there is really no valid moral argument against throwing a bag of composted or even partially composted poop in a dumpster. (Never to be thought of again... )
Brevi tempore!
Old 02-01-2016, 07:42 AM   #21
Lumatic's Avatar
1993 34' Excella
Images: 16
If you are regularly going to toss your human compost you might want to check state and local regulations to see if it is legal where you are or not.
If compost is going to be used for fertilizer I would feel a lot easier using animal compost than human. Humans are a lot nastier than cows, pigs and the usual barnyard critters. Bugs like ecoli (which is ubiquitous) and listeria come to mine. If you are comfortable with using human compost in your tomato patch that's your deal.
In that regard I would rather see human compost go seruptitiously into a dumpster than into the food chain.
End of my 2 cents.
Old 02-01-2016, 08:08 AM   #22
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I would not consume any product that I knew was grown in human waste. It grosses me out, but for good reason.
The fact is, the "bugs" and strains that are suited for, and affect humans most, are going to tend to be in human waste more than in animal waste.
Did typhoid Marry (quite contrary) grow her garden in human compost? Who knows?
I am with you, I would prefer to see it in the dumpster too.
Brevi tempore!
Old 02-01-2016, 08:44 AM   #23
field & stream's Avatar
2008 23' Safari SE
2007 Base Camp
Santa Ynez , California
Brevi tempore!
No argument? How about concern about transmission of diseases such as cholera, typhoid, hepatitis, dysentery, norovirus, e-coli and more.
I'm not saying this isn't manageable, but it is not an issue to be casually dismissed.
field & stream is offline   Reply With Quote
Old 02-01-2016, 08:49 AM   #24
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Hi Mike,
I'm following this thread with great interest. Please do us a favor and post an update in a month or two after you've had a chance to experience all aspects of this device, including a couple of dump episodes, how clean does the bowl stay (really) and also some comments on the real world savings in fresh water, and your real world experience with combining the grey/black tanks.
Thanks!
Bob Martel
WBCCI# 5766
Old 02-01-2016, 09:20 AM   #25
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
What is that hose coming out the side of the toilet. There seems to be an electric cord attached to it.
Kelvin
Old 02-01-2016, 09:23 AM   #26
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
The fact is, a lot of poop goes into landfills from baby diapers to adult diapers... Not to mention dog poop and the contents of millions of cat boxes.
We have a fairly effective solid waste disposal system of "can to landfill" with minimum of human contact.
As a practical matter, a relatively few people using composting toilets isn't going to raise a huge stink.....
That said, so long as I have access to a good water supply and a sanitary sewer or septic system, I wont be composting my poop inside of a habitable structure or trailer.
Brevi tempore!
Old 02-01-2016, 09:25 AM   #27
Chelsea , Michigan
Images: 12
Kelvin
There is a 12 volt fan that continuously and slowly exhausts air from the compost receptacle. In this case, Mike has connected the exhaust hose to his black tank vent stack and the wire is undoubtedly powering the fan.
Bob Martel
WBCCI# 5766
Old 02-01-2016, 09:29 AM   #28
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
This is the caveat. Some places you can dump gray on the ground, other places no. We check with BLM or field offices when we can. The BLM office out of Yuma gave us a list, they have a classification system of areas that are considered Environmentally Sensitive. The desert does have some of these areas. And then there are other areas where it's not a concern.
We use bio-degradable ph safe soaps anyways.
There is also another way you can get rid of gray. You can take a large black tarp, use 4x4s around the perimeter and fill up your tarp and let it evaporate in the sun.
Or just keep it in your tanks. I'll be combining mine, after I've had them professionally cleaned out. But not before. I don't want surprises coming out of my drip hose.
Originally Posted by AnnArborBob View Post
Hi Mike,
Thanks!
That's the plan for sure. I'll probably write a follow-up post in a month or two.
As for the discussion about human waste, germs and disposing of it, you are all forgetting a big key here. This material is not human waste by the time it's disposed of. It's HUMUS. https://en.wikipedia.org/wiki/Humus - You can google the compost process yourself. And how things break down. Also see: https://en.wikipedia.org/wiki/Urine-...ing_dry_toilet
The point of the composting toilet is to let natural bacteria's do their work and break down the material. It's safe within 6-8 hrs and is no longer human waste. That's why you can dispose of it legally.
If you wanted to get really into it, there is even an entire book dedicated to the subject called The Humanure Handbook: A Guide to Composting Human Manure. And let’s not forget the liquids! Ammonia in pee has tons of great nitrogen (the stuff in fertilizers) and can be used for landscapes, food, fuel, and fiber. Its liquid gold, or at least according to the book, Liquid Gold: The Lore and Logic of Using Urine to Grow Plants.
If you take a dump in a plastic bag and pee into a zip lock bag and throw that in the trash, that's a totally different subject. And some of you are treating it as such. But why then is that a problem but your dog's crap isn't?
But feel free to debate it till the cows come home.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
boondocking, composting toilet, diy, natures head, toilet
Installing a composting toilet gamana Sinks, Showers & Toilets 18 04-03-2017 08:48 PM
Composting toilet: winter use? Joyfulgirl Sinks, Showers & Toilets 5 08-27-2011 08:45 PM
Your questions about our Composting Toilet FLYNCLD Waste Systems, Tanks & Totes 55 03-28-2011 05:04 PM
Anyone installed a composting toilet? casaalumina Sinks, Showers & Toilets 15 10-08-2008 12:53 PM
Composting toilet replacement Phaedrus Sinks, Showers & Toilets 4 10-17-2003 06:19 PM
