Welcome to the forum, rana!
You might consider getting 12-volt versions of the appliances you mention, although I am not sure if the BC has such a "cigarette lighter" outlet like old Airstreams did? As you have noted, your 120-volt outlets only work on shore power.
The new search function above works great, so you might want to read up on these ideas:
Cigarette lighter outlet:
https://www.google.com/search?q=ciga...com&gws_rd=ssl
12-volt appliances:
https://www.google.com/search?q=12-v...=airforums.com
The boating world has had 12-volt appliances for decades.
Adding an inverter would be more complicated than adding a 12-volt outlet IMO.
Good luck,
Peter
PS -- No matter which route you take, the limited battery storage in a BC may prove challenging. Get a foot pump for air pressure, and a propane/butane camping grill/burner to use instead of the Instapot?
PS2 -- Does the Basecamp X have features like this? --
https://www.colonialrv.com/blog/2019...ale-need-know/
PS3 -- "Less is More" and "Keep it Simple, Stu" come to mind, as guidelines for
camping/boondocking in the Basecamp, in order to reduce our addiction to plugging in our home-based appliances IMO.
