05-21-2017, 04:50 PM
2017 25' Flying Cloud
Florence
, Alabama
How to plan for BD
I have a 2017 FC FB 25'. Suppose to go BD this fall. Haven't before. If I run one of my overhead fans all night with a window or two open to simulate that, what can I expect batteries to look like in am? I have NO solar and stock wet cell batteries. Refrige is off for now as well as HWH.
The Colonel and Southern Belle
05-21-2017, 05:39 PM
2002 30' Classic S/O
Fleming Island
Fantastic vents draw 3 amps on high.
http://www.fantasticvent.com/assets/...t-new-cust.pdf
Even if you run two, that's 6 amps. Overnight, say for 8 hours, that is 48 amp hours. According to Interstate:
http://www.interstatebatteries.com/m.../rv-deep-cycle
At a 5 amp rate of discharge, a group 24 is good for 13 hours or 65 Amp*hours (that's to full discharge) and a Group 27 is good for 19 hours or 95 Amp*hours. Batteries, however, should not be discharged below half capacity, so if you only have one battery, divide those numbers by 2. Since you said "batteries" I'll assume two.
If you run your refrigerator off of propane, it should only draw about 0.3 amps if you have the humidity control turned off. One fan plus the fridge for 8 hours overnight would be 3.3 *8 or 26.4 amp hours. Both fans would be 6.3 *8 or 50.4 Amp*hours.
One fan plus fridge overnight
Usable Capacity for two Group 24 batteries - 65 AH
Capacity used for two Group 24 batteries - 26.4 AH
Percent of usable capacity used - 26.4/65 = 40%
Two fans plus fridge overnight
Capacity used for two Group 24 batteries - 50.4 AH
Percent of usable capacity used - 50.4/65 = 78%
You should be good with no problem if there are no other significant loads. You are even in better shape you have have Group 27 batteries.
Al
05-21-2017, 06:01 PM
Florence
, Alabama
Think I have 27s but busy with my rum n coke right now. Thx. I'm going to run that scenario next day or two to check out
05-21-2017, 06:26 PM
Sag Harbor
, New York
Great overview Al.
dblee1950, may I suggest that before you go on the boondocking trip, you make sure the battery cells are all full with distilled water, and that the specific gravity of each cell is good, by using a hydrometer. Best not to assume that because they are new, that the batteries have been cared for correctly by the dealer. "Lot rot" happens to many AS new batteries, unfortunately!
Make sure that all possible phantom loads are off, which would include the fridge humidity control (as Al mentioned), any radio or A/V systems including sub-woofer, hidden lights in storage areas, and so forth. The propane detector must stay on.
You can check the battery voltage when you get up during the night to use the bathroom. We don't let it get below 12.2 volts if possible, and prefer to charge with the generator once the batteries get below 12.5 (~ 90%). If your voltage goes below 12, more serious battery damage is said to occur, so you might have to turn off fans etc., or plan on replacing your batteries sooner than you might have anticipated.
By the first morning of your trip, you will have a better sense of the battery usage. Guessing that you will be in the 12.2 to 12.5 range per your overnight test scenario.
Have a great boondocking trip!
Cheers,
Peter
05-21-2017, 07:01 PM
2016 25' Flying Cloud
Venice
AS installs group 24 batteries at the factory.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
05-22-2017, 05:22 AM
Florence
, Alabama
Will ck it out tomorrow, thx
05-22-2017, 01:40 PM
Florence
, Alabama
Yep, grp 24. I'm running one fan, everything else is off. Been going 6 hrs and v indicator in AS shows 12.3, pretty much since I started this am. Not sure how good A measurement I get from that indicator. Shooting for 8 to 10 hours
05-22-2017, 03:49 PM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
Does anyone know if the fridge on my 2014 FC (5 CU Dometic, combined fridge/freezer with small freezer inside the fridge) has the humidity control, even if there is no switch for it anywhere? Is it just built in and always on or 'on' as needed, like my fridge vent fan (which I am wiring a switch to so I can shut it off selectively)?
I'd like to find a way to disable it if in fact it is always on or on when the fridge says it needs it. Trying to really crack down on phantom draws.
05-22-2017, 03:52 PM
Sag Harbor
, New York
You could probably get better feedback on the 23FB thread:
http://www.airforums.com/forums/f142...um-166374.html
Does your owner's manual talk about this, or the fridge mfg. Dometic pamphlet with your AS paperwork?
05-22-2017, 04:03 PM
Florence
, Alabama
I'll read up on those links as time allows. What I do know is that the airstream was plugged into shore power probably for the last two weeks with battery charging engaged I'm not too worried about frying bats because I have the PD4655 charger. As I recall it showed that it was in the slow state of charge i forget what the real name is but the wizard was only blinking every 10 seconds or so. I assume ([emoji1317]) bats were fully charged. My indicator may be off? Bats are less than a year old according to stickers and AS was delivered straight from factory to dealer where I picked it up.
05-22-2017, 04:09 PM
2014 25' FB Eddie Bauer
Vero Beach
An alternative to running the vent fan(s) is to get a standalone "endless breeze" fan (which is from fantastic and is essentially the same fan we have in the vents but in a case with a 12v cigarette lighter end). Having that fan blowing on you (even on low speed,which consumes about half the power of full speed) will make you more comfortable at night. On a night with a breeze and the windows open you'll do just fine with no fan.
Your 2017 model trailer may only have USB plugs, not 12volt. There may be a USB model of small box fan. If not, you may want to have a traditional cigarette lighter outlet added. I put an extra 12 v with USB on my wife's side of the bed so she gets the fan.
05-22-2017, 04:14 PM
The Aluminum Tent 3
Park City
, Utah
The Dometic manual (it's a comprehensive manual for all models) only mentions 'climate control' for the larger unit that has the separate fridge and freezer, there is a switch to turn it on or off. No mention of any other models, I was just wondering if anybody knows if there is anything similar on the smaller 'all in one' units. I am going to email Dometic and ask them and will report back.
Florence
, Alabama
Good idea. I'll look into that kind of fan. Thx
05-22-2017, 05:50 PM
Sag Harbor
, New York
. . . Bats are less than a year old according to stickers and AS was delivered straight from factory to dealer where I picked it up.
That was what I was cautioning you about in Posts #4 and 8 -- the possibility that the batteries have "lot rot."
Many brand new Airstreams have batteries which have been mistreated by the dealer. Your 12.3 volts after only 6 hours of using one fan is a red flag warning IMO.
Post #4 has some suggestions about checking the specific gravity of each battery cell, which would take about 10 minutes and might confirm that the batteries are compromised.
No need to keep repeating things.
Good luck.
Peter
05-22-2017, 08:31 PM
Florence
, Alabama
I'll check SG tomorrow. I did check v at batteries and found 12.5. Maybe inside indicator is off. Not sure about lot rot as as I said AS came straight from production to me.
05-22-2017, 08:32 PM
Florence
, Alabama
Thinking about agm batteries. This is a pain
05-22-2017, 10:01 PM
Silver Star
1970 23' Safari
Victoria
, British Columbia
tester
why not do a dry run in your parking spot if possible.
I do that at times .... I'll run both ventaxia's all day plus a few other things to test out my batteries.
Just returned from 3 nights started at 12.6v and ended around 12.2 ... ran 3 fans ...furnace ..lights..water pump etc . We were boon docking and find 3 nights easy to do ... my wife even used her 110 hairdryer and the 110 toaster twice.
I have 2 6v golf cart "All Canadian" brand batteries.
05-23-2017, 06:39 AM
Florence
, Alabama
That'll be next. I checked voltage with my good quality meter and found 12.5 when inside indicator showed 12.3. I'll continue to follow with hydrometer
05-23-2017, 08:55 AM
Florence
, Alabama
Originally Posted by A W Warn
If you choose to replace the battery, you might measure your battery box to see if a group 31 battery will fit. On my 25' it did. That battery has 100AH capacity.
Sounds interesting. I'll check the dimensions. I'm going to try to get as much out of these bats as I can.
