Old 04-17-2014, 02:47 PM   #1
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
How to Fill FW tank?
Soooo...its time for me to ask what I fear is a really stupid question. Im ok with that..so here I go.
I have a few times went to add water into my fresh water tank (I think it can hold up to 54 gallons) and when I put the water on high and put end into the opening and start filling, fairly soon, it seems to force air into the tank that then vents out back at me soon rather violently.
At first I thought perhaps I just need to slow down the inflow....but is there not a vent that should take care of that? or is it just that the vent can be overwhelmed by rapid influx of water as such?
BTW, 54 gallons is quite alot....last year, my very first attempt to add fresh water to the FW tank consisted of me adding water some...what I percieved as a significant amount...stopping, going back to check the monitor, and it was barely even at 1/8 (the drain was closed btw ).
Anyway, I may venture out for quick weekend boondoking trips just a tad this summer so I need to begin utilizing some restrictions on water practices, using my FW tank, etc...
PharmGeek is offline   Reply With Quote
Old 04-17-2014, 03:08 PM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Pharm ---- the monitors are crap. Period.
I never cram a hose down the spout, I hold it a few inches away and aim it into the inlet. That way I can actually hear the tank filling. There is a slight whistling sound as the air comes out and the splashing of the water going in. The closer to the top the higher both sounds are pitched. There is a small vent about the size of a straw to let air out, but it doesn't work very well, and I never want to build up pressure inside the tank. I heard of one woman overfilling her fresh water tank to a point that it made the subfloor's plywood bulge and break!
You may already have a full fresh tank. Sounds like it. You could try draining it - or if you'd like to get some funk out of your gray tank, disconnect from city water, turn on the water pump, fill your kitchen sink and shower pan with water, then pull the plugs and drain em, a lot the old coffee grounds and skin cells and soap scum will be washed out of the gray tank. When the pump starts running hard, you're nearly dry. Stop it and refill, and don't forget to drain the gray tank.
happy trails, Paula
Old 04-17-2014, 03:29 PM   #3
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
I start the water flowing through my water hose to flush it, then crimp it near the end to stem the flow. I insert the end of the hose in the fill fitting, and the threads keep it place - I drape the hose over the open fill door. When the tank is full it starts coming back out through the little vent that is next to where the hose is inserted. I don't get any water back out in volume until it is completely full. Perhaps your vent is not working correctly, or the tank is full and the monitor is not working. Can you gain access to the tank to do a visual check? My tank is under a dinette seat, and i can see it through the drain access hole, and can see if it is full.
robert claus is offline   Reply With Quote
Old 04-17-2014, 03:31 PM   #4
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
It Takes A While....
...to fill the fresh tank on ours from the external fill area. Ours has what appears to be a small vent hole (about 1/4" diameter) but that doesn't seem to let the air out.
So my approach is to use a water heater flush wand so I can get water down into the fill neck about a foot. From there it's a series of turning the water on, listening to the air escaping, anticipating the "burp", turning off the water, letting the tank burp, then turning on the water again. This can easily take two dozen cycles of this before water finally begins to consistently run out of the fill hole. That's when I know it's full.
On the other hand, I turn on the water relatively slowly (still using the water heater flush wand) an allow the tank to fill. This approach can easily take 30 - 40 minutes depending on how fast the water is running etc. It's a delicate balance between slow water and burping.
Then there's the third option - at least for our 1992 Classic - connect to shore water and turn on the Autofill switch. This allows water to enter slowly through a solenoid valve and presto - in 30 - 45 minutes the tank is full.
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 04-17-2014, 04:08 PM   #5
Whoa.....................slow the water flow down.
There is NO special vent as you assume.
Old 04-17-2014, 04:47 PM   #6
1974 Argosy 20
Kooskia , Idaho
All of my Airstreams and Argosy's over the years have had a water tank vent tube as well as the fill tube. If that vent gets crimped, or has a low spot in it, no venting will occur and the tank will fill slowly or very poorly. There was a thread last summer/fall about a 20' FC like mine which had a bad vent an the guy had the same problem of poor filling and blowback. He finally found the kink or whatever and fixed it.
I would say it is a dealer warrantee issue to be taken care of by them.
Old 04-17-2014, 05:45 PM   #7
2005 19' Safari
GLENDALE , AZ
I think I recall someone previously posting that they put the end of their garden hose into the filler neck of the freshwater tank, turned on the water, and walked away to do something else while the tank filled. The hose coupler held the hose in the filler tube, and the tank overfilled and couldn't release the excess pressure, because it was blocked by the hose coupling that was still pumping in fresh water.
In any case, the freshwater tank ruptured and flooded the inside of their Airstream.
I used to fill our freshwater tank this way. However, I now hold the water hose 2-3 inches away from the filler neck; so I can see the water overflowing when the tank is full.
Filling the tank really doesn't take that long; but it's kind of like watching water come to a boil -- It seems like it takes forever...
Old 04-17-2014, 06:23 PM   #8
SStar's Avatar
2004 28' Classic
Midland , Texas
water filler
Make you one of these simple filler attachments. Screw it onto the hose you are filling with, the cut off piece of hose extends down into the filler neck, you control the flow with the valve, or cut it off completely when needed.
ID:	209875   Click image for larger version
SStar is offline   Reply With Quote
Old 04-17-2014, 06:26 PM   #9
SStar's Avatar
2004 28' Classic
Midland , Texas
Also, as you fill the tank a few times you will learn to estimate how full it is by the sound, then adjust the fill rate.
Old 04-17-2014, 06:31 PM   #10
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Do you have an outdoor shower? I sometimes disconnect the shower head an full the tank from the thinner shower hose. Leaves plenty of room for air to escape and no need to disconnect the city water connection.
Old 04-17-2014, 08:17 PM   #11
1999 30' Excella 1000
small town , Maryland
Pharmgeek, Theirs no such thing as a stupid question on this website. I'm always learning from these threds. Nice ''backpack'' you have in your avatar.
streaminwild is offline   Reply With Quote
Old 04-17-2014, 08:25 PM   #12
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
that is a fantastic idea assuming I guess that it is set up to allow that excess air to escape that way...ill be looking into that.
I am pretty sure mine has a vent right above the opening for the FW fill - and I am suspecting it is blocked...even moderate water flow produces this rapid and frequent “blowback”....then after that air escapes (its like a big burp with no sound like a burp) - I can resume filling for another 15-20 seconds)...then pause for the burp....its annoying...only a small trickle of water would not produce this...
It does this even when I give the water hose some distance and to not stick it a bit in the opening. I would never walk away from it!!
Old 04-17-2014, 08:33 PM   #13
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
Phamgeek, at least you have correct spot. Last year my daughter was helping me set up and I was not paying attention, long story short we filled the black tank, by hooking hose to wrong intake thank goodness we did not leave the trailer for a planned shopping trip. The trailer would have flooded with black tank overflow, can't begin to tell u how close we came.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 04-17-2014, 09:35 PM   #14
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Hahahahahahaha - that was close !!!
Ol Ron at Foley RV made that error - lucky for him it was in a tank never pooped or peed in and it shot the water up and out the vent on roof - he will appreciate me airing that out here
Noobie - how to fill fresh water tank? Bohemian Fresh Water Systems 26 10-18-2016 01:51 PM
Remote water tank fill Garages Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 2 05-07-2010 11:36 PM
Water Tank Fill Door Replacement Ganglin Fresh Water Systems 2 07-06-2007 07:13 AM
Can't fill water tank. Killo1 Fresh Water Systems 5 07-21-2006 10:28 PM
how long to fill black tank? Stefrobrts Waste Systems, Tanks & Totes 11 06-30-2003 11:14 AM
