Go Back   Airstream Forums > Airstream Community Forums > Boondocking
Old 01-10-2016, 08:34 AM   #41
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
iPad on an airliner over the Midwest in turbulence and auto spell check generates strange stuff....
The small access hatch in the battery compartment lid allowed topping up the brake fluid without the removal of the ProPride jacks and propane tanks. Reverted back to a full size lid when Lifelines and enclosure were removed.
Enroute from Phoenix to Newark and then across the pond to Birmingham, UK to celebrate my wife's father's 90th with the rest of her family there.
Old 01-10-2016, 09:49 AM   #42
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
MORE POWER!!! If you have "portable" and are getting 'too much' power, can't you just cover some of the panel with cardboard or 'aluminum'.. (polished of course)
Peace and Blessings..
Channing
WBCCI# 30676
Old 01-10-2016, 10:25 AM   #43
dznf0g's Avatar
Oswego , Illinois
Why? The controller will only deliver what the batts need. Closed voltage won't hurt the panels.
Now, if your controller is too small, that's worthy of discussion, but most allow for higher current input than the rated amperage. They just clamp it at a ceiling. I use 260 watts with a 15 amp Morningstar and when the sun is strong it clamps off at 15 amps. However, because of inefficiency in the system, it's rare to get to 15 amps.
-Rich-
Old 01-10-2016, 05:06 PM   #44
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Thanks, Rich!!... It was kinda a "Red Green" thing... No worries...
Channing
WBCCI# 30676
Old 01-17-2016, 03:56 PM   #45
DreamStreamr's Avatar
2005 25' International CCD
Fleetwood , North Carolina
Images: 38
Send a message via Skype™ to DreamStreamr
We modified the battery box to allow taller Interstate GC2XHD 6v 230amp hour batteries, and placed two more above these. So 12v batteries with 460 amp hours are maintained by two 125watt panels wired in series (to 24vdc) through an MPPT charge controller. We see up to 18 amps charging current on sunny days when we have some catching up to do.
How much solar should you install? I suggest you should first install a Trimetric 2025 or equivalent on your 12vdc system and learn how much you use, for what, and for how long. It will tell you all this and more. Then you know how much solar and battery to install.
Chasing 75 Degrees,
Jim N5RTG
dreamstreamr.com
DreamStreamr is offline   Reply With Quote
How many watts/panels/batteries do we need? RJB54 Generators & Solar Power 14 05-29-2015 05:08 PM
Adding panels on top of panels instead of replacing? The-Marco Ribs, Skins & Rivets 18 08-02-2014 04:53 PM
West Need help picking solar panels wando1997 Boondocking 11 04-23-2014 05:42 AM
Need help picking solar panels wando1997 Generators & Solar Power 29 04-07-2014 09:50 AM
1973 Airstream Land Yacht Sovereign -- Many Many Many Upgrades!!! eBay Watch Airstreams on eBay 0 06-18-2013 06:30 PM
