Old 03-16-2014, 07:06 PM   #1
Brokerchris's Avatar
2013 23' FB International
Aliso Viejo , California
How many generators do you use
Hello- We have a 23FB and I purchased 2 yamaha ef2000is. I would like to avoid bringing 2 generators with us but headed to Joshua Tree soon (temps 80-85).
I was able to get the AC to work off of one gen- with no microwave use etc.
How many of you use only one gen like this and how long will the AC work? A/S Dealer recommended bringing the 2 out with us.
Brokerchris is offline   Reply With Quote
Old 03-16-2014, 07:12 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
You will need 2 Yamaha 2000s to get a 13.5K AC to work. It may appear to work with one but I have been told can damage the compressor. Not sure if that will give you enough juice for a 15K unit
BYW I may be at Joshua Tree first couple of days in April
Old 03-16-2014, 07:17 PM   #3
Nice what JT campgrounds do you like better?
We've done a lot of tent camping in Joshua tree and have stayed at nearly every campground - this will be our first experience in JT with the Airstream
Old 03-17-2014, 03:16 AM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
You basically have two choices in generators... one large one or two small ones. I went with the two small ones, tw0 small generators are easier for me to handle. In the "off" season I only take one with me. FWIW I have the Honda version.
Aaron
WBCCI #XXXX AIR #2495
Old 03-17-2014, 04:00 AM   #5
2013 20' Flying Cloud
Cream Ridge , New Jersey
We have a Honda 3000 that works the ac just fine along with everything else in the trailer but not all at once. The gen stays in the back of the truck. The two smaller generators and the related wiring are more than I want to deal with.
Joe Palmieri is offline   Reply With Quote
Old 03-17-2014, 11:47 AM   #6
Aaron
I went for the 2 because I don't want to lift 150lbs (bad back) so 2 at 45 lbs is easier for me and we will only need the one when we wont need the AC. Also- good at home for emergencies- 4000 watts when paralleled will at least keep the fridge going
Old 03-18-2014, 11:28 AM   #7
screwcap's Avatar
2014 25' Flying Cloud
Phoenix , Arizona
We are new owners, but knew that we had to go large or get 2. That left us with Honda, Yamaha and possibly Kipor or Champion. We decided to risk getting Kipor. They are 2600w, and run at 4300 continuous, and 4900 peak in paralell. The math looks good, we'll see how they hold up.
Wade
screwcap is offline   Reply With Quote
Old 06-01-2014, 07:29 AM   #8
Peggy Wilson's Avatar
1962 22' Safari
Kansas City , Missouri
Images: 11
12 volt air cooler no generator required.Click image for larger version
Name:	ImageUploadedByAirstream Forums1401629098.089980.jpg
ID:	213277Click image for larger version
Name:	ImageUploadedByAirstream Forums1401629154.132386.jpg
Just add ice and enjoy cool air and ice water to boot.
Peggy Wilson is offline   Reply With Quote
Old 06-01-2014, 07:35 AM   #9
1962 22' Safari
Images: 11
More details
Name:	ImageUploadedByAirstream Forums1401629491.306321.jpg
ID:	213287Click image for larger version
Name:	ImageUploadedByAirstream Forums1401629543.312732.jpg
We will try this for our 1962, 22ft Safari it has AC on the roof but no gen.
Old 06-01-2014, 08:23 PM   #10
Southwestern , Ohio
Originally Posted by Peggy Wilson View Post
12 volt air cooler no generator required.Attachment 213277Attachment 213278
Peggy,
Just so's you know. . . you have probably heard air conditioner capacity stated in "tons" at one time or another. Your rooftop air conditioner is probably rated at 12,000 BTU/hour or more. (Some small trailers have 13,500 and 15,000 BTU/hour units.)
12,000 BTU per hour is "one ton" of cooling capacity, meaning that it is equivalent to melting one ton of ice per day.
Nuvite-F is offline   Reply With Quote
Old 06-03-2014, 06:13 AM   #11
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
We went with two Honda's 2000 and have them for over two years. I only take both when we will need the AC otherwise I travel with only one. We choosed them as they are easier to lift in and out of the bed of the truck then a larger one.
I also use regular gas without the ethanol as it keeps the carburator from clogging.
urnmor is offline   Reply With Quote
Old 06-03-2014, 07:12 AM   #12
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Been using one Honda 2000i for 7 years now. AC is still running fine. It's the Carrier IV super efficient model.
Ahab is offline   Reply With Quote
Old 06-03-2014, 07:14 AM   #13
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
But Ahab, it is not possible to do what you have been doing. You must be mistaken.
<jk sarcasm>
Old 06-03-2014, 08:28 AM   #14
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
I have 2 Honda 2000 units. Use both with the trailer, they are really for Hurricane use. I did have a Honda 3000 on a boat with remote start, sold the boat. The 3000 is my all-time favorite for rv use. Current boat has a 4.2 KW Fisher Panda (German) single cyl. diesel in a sound proof enclosure. Sea water cooled and will run all day and night for weeks on end. Very expensive little guy.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Cold weather starting - Yamaha Generators tberkhouse Generators & Solar Power 4 03-19-2012 07:25 PM
Powerhouse Inverter Generators 68 Overlander Commercial Listings 2 08-18-2011 10:24 PM
Generators EastWestTrav Generators & Solar Power 14 05-25-2011 08:38 PM
Generators OK for TV's (televisions)? DKDarrow Electrical - Systems, Generators, Batteries & Solar 12 01-18-2011 10:53 AM
