Old 06-10-2015, 02:41 PM   #1
Refugee from Napa, CA
Photobum's Avatar
2015 25' FB Flying Cloud
Madison , South Dakota
Honda Generators
I am currently in Green Creek Campground, in Toiyabe National Forest, Ca. Just outside Bridgeport, at an elevation of 8,000 feet.
My generators are running rich, and in fact one will run for a few minutes and then shuts down. I have read the owner's manual and it says that if you are going to be at elevation you need to have the carburetor adjusted by a Honda Dealer.
Does anyone know how to this and can you post pictures? Much appreciated as otherwise I will be driving a few hundred miles to get this done.
www.vincentgoetz.com
Instagram. Alluminator
Photobum is offline   Reply With Quote
Old 06-10-2015, 02:51 PM   #2
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
I have run my 2 Honda 2000's, for extended periods, at elevations higher than that with no trouble. Are you sure the vents on the fuel caps are open?
Bud
Ridgerunner3 is offline   Reply With Quote
Old 06-10-2015, 02:59 PM   #3
dznf0g's Avatar
Oswego , Illinois
There is a jet kit for high elevations....no adjustment I am aware of, just jets.
-Rich-
Old 06-10-2015, 03:23 PM   #4
aftermath's Avatar
Spokane , Washington
Have you checked the air filters?
aftermath is offline   Reply With Quote
Old 06-10-2015, 07:41 PM   #5
2013 25' FB International
Flagstaff , AZ
Make sure you have the choke in the right position. Same symptom. I made that mistake our first trip out this spring and was convinced there was a problem with the gen until I got home and fired it up again. I then realized I was reading the diagram backwards. Been using them for over 2 yrs so not sure why I mixed it that time.
RT66 is offline   Reply With Quote
Old 06-10-2015, 11:35 PM   #6
Some Guy
djarrett's Avatar
2018 28' Tommy Bahama
Nashville , Tennessee
I had a similar issue on my 2000 and it turned out it was the little vent on the gas cap had gotten closed while moving the unit.
D
djarrett is offline   Reply With Quote
Old 06-11-2015, 11:10 AM   #7
Photobum's Avatar
The problem is jets, and I need to drive over fifty miles one way to get them replaced. I know about the the other suggestions made here (caps, air filter etc. ) and in fact pulled the air filters before I posted.
Jets. Couldn't just have a damn screw could they?
Old 06-14-2015, 11:39 AM   #8
I have three different jets for my honda 2000. I change them regularly as I camp at a wide range of altitudes. Two nuts pull off the carburetor and the jet screws into the bottom of the post under the bowl. Takes about 10 minutes. I carry three sizes: 0-5000', 4-7000', and 7000'+. I googled it where you can you tube the change.
Perker is offline   Reply With Quote
Old 06-15-2015, 09:30 AM   #9
Photobum's Avatar
Thanks Perker!!!!
Old 06-17-2015, 05:46 PM   #10
My Honda has run many hours with stock jets over 8000 feet.
High altitude jets will improve fuel economy.
There is a problem with your generator, most likely a crudded up carburetor. There are small jets inside and unless fuel is run out of the carb and the float bowl drained (there is a screw on the bottom of the bowl) when the generator is stored, the carb will crud up if it is stored for a while.
handn is offline   Reply With Quote
I Love my Honda EU2000i Generators panabax Generators & Solar Power 30 10-30-2016 02:10 PM
Honda vs Yamaha Generators ROBERTSUNRUS Generators & Solar Power 115 06-13-2016 09:32 AM
Why are Honda Generators quiet? JimGolden Generators & Solar Power 48 02-18-2008 05:34 AM
biodiesel for honda 2000 generators? silver suz Generators & Solar Power 34 08-07-2005 10:08 AM
Running Honda Generators in Parallel Cracker Generators & Solar Power 16 05-16-2004 06:49 PM
