Old 05-24-2014, 03:16 PM   #1
TetonStreamer
Teton Stream's Avatar
2017 23' Flying Cloud
Wilson , Wyoming
Honda EU2000i Generator Mount for Bambi
I have found a very good, lockable mount for a Honda EU2000i generator on my 2013 20' Bambi Flying Cloud. The link to Low Pro Lockdown is: LowPro LockDown. Keep what’s yours.
Video:
The mounting plate can attach to the battery box. (Yes you have to remove the mounting plate to access the batteries.) The fit is tight being right behind the propane container, but it makes for a very compact system. I can reach my hand around to access the choke, on/off switch, and the pull handle. You are pulling the start cord at a 90 degree angle to the generator but it is a Honda and starts easily. Purchase the Honda cover for the generator and between the propane container and the cover the unit is well protected from road and weather.
Teton Streamer - in The Toaster
Wilson, WY 83014
Teton Stream is offline   Reply With Quote
Old 05-24-2014, 11:32 PM   #2
2004 16' International CCD
Chicagoland , Illinois
Wow - that is a good find. Thank you for sharing. Would you have time to post some pics of your install?
Now I need to decide if I go for an extra battery or for your LockDown.
Airrogant is offline   Reply With Quote
Old 05-25-2014, 10:43 AM   #3
TetonStreamer
Wilson , Wyoming
Yes, Not going to be around the rig for a week or so, but will post when I am next on the road in the Toaster!
Wilson, WY 83014
Old 05-26-2014, 09:52 AM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Quoting Will Smith from "Independence Day", "I got to get me one of those."
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 05-26-2014, 03:38 PM   #5
Bend , Oregon
Anyone have any idea what kind of propane tank cover/tray that is shown in the photo?
chaeha is offline   Reply With Quote
Old 05-27-2014, 05:26 AM   #6
Aftermarket supplier
widgetwizard's Avatar
Duncanville , Texas
We make those (and other things..) for Casitas
perfectcasita.com
widgetwizard is offline   Reply With Quote
Old 06-03-2014, 06:40 PM   #7
TetonStreamer
Wilson , Wyoming
Here is the installation complete. The one Con is you have to unbolt the baseplate to get to the battery box. You can access Choke, On/Off Switch and Pull Chord while it is mounted without removing anything. I cover it with the Honda cover while traveling.
Name:	photo 1 (2).jpg
ID:	213435   Click image for larger version
Name:	photo 2 (3).jpg
Wilson, WY 83014
Old 06-03-2014, 07:34 PM   #8
LiLNomad's Avatar
2007 25' International CCD FB
Northridge , California
I would love to not have to carry it in the Suburban with me but what about all the controversy about mounting items (especially heavy ones) to the frame?
LilNomad
LiLNomad is offline   Reply With Quote
Old 06-03-2014, 07:34 PM   #9
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
Thinking of getting this...is it sAfe to run the generator there on the tongue as far as fumes are concerned? Where do u keep gas can?
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 06-03-2014, 07:39 PM   #10
2005 19' Safari
GLENDALE , AZ
I assume that since the lock is strong enough to keep someone from stealing the generator, that the Honda won't fall off during driving. Do you think the battery-box lid-hinge and lock are strong enough not to come off, too?
Looks like a nice installation; please let us know how this works out for you after a few thousand miles on the road.
Thanks for posting installation and photos!
Old 06-03-2014, 08:54 PM   #11
TetonStreamer
Wilson , Wyoming
LilNomad
At 46 lbs I am not terribly worried about the added weight. It is not mounted to the frame but the battery box which is stoutly attached inside the A-Frame. I will post feedback after 1,000 miles and beyond.
Wilson, WY 83014
Old 06-03-2014, 08:56 PM   #12
TetonStreamer
Wilson , Wyoming
As long as the front window is not open when you run it I would not think there should be a problem. Remember, you can unlock it from the mount and move it away from the rig, quite flexible.
Wilson, WY 83014
Old 06-03-2014, 08:58 PM   #13
TetonStreamer
Wilson , Wyoming
I actually drilled into the flange of the actual battery box itself. It has 1/2" lips on either side of the box.There is no stress or torque on the lid or hinge.
Will do after 1,000 and beyond.
Wilson, WY 83014
Old 06-03-2014, 10:05 PM   #14
Mexray's Avatar
1978 28' Ambassador
Morada , California
Wow...That LowPro Lockdown rig looks like a GREAT value for $200...!
Rugged construction, smooth finish...good job..!
Ray & Pat; Morada, CA
Portable Generator Sound Levels: One Honda EU2000i vs. Two Paralleled Honda EU2000i AndyPenny Generators & Solar Power 19 06-05-2017 03:04 PM
Honda Generator EU2000i Theft Deterrent Bracket z8 hm Generators & Solar Power 1 02-17-2012 04:47 PM
Honda EU2000i Generator Pricing Jan.2005 markparker22 Generators & Solar Power 12 11-23-2005 06:49 AM
Honda EU2000i generator dhe9 Generators & Solar Power 4 04-12-2005 06:33 PM
