05-24-2014, 03:16 PM
TetonStreamer
2021 27' Flying Cloud
Delaplane
, Virginia
Honda EU2000i Generator Mount for Bambi
I have found a very good, lockable mount for a Honda EU2000i generator on my 2013 20' Bambi Flying Cloud. The link to Low Pro Lockdown is: LowPro LockDown. Keep what’s yours.
Video:
The mounting plate can attach to the battery box. (Yes you have to remove the mounting plate to access the batteries.) The fit is tight being right behind the propane container, but it makes for a very compact system. I can reach my hand around to access the choke, on/off switch, and the pull handle. You are pulling the start cord at a 90 degree angle to the generator but it is a Honda and starts easily. Purchase the Honda cover for the generator and between the propane container and the cover the unit is well protected from road and weather.
Teton Streamer - in The Toaster
Wilson, WY 83014
05-24-2014, 11:32 PM
2004 16' International CCD
Chicagoland
Wow - that is a good find. Thank you for sharing. Would you have time to post some pics of your install?
Now I need to decide if I go for an extra battery or for your LockDown.
05-25-2014, 10:43 AM
TetonStreamer
Delaplane
, Virginia
Yes, Not going to be around the rig for a week or so, but will post when I am next on the road in the Toaster!
Wilson, WY 83014
05-26-2014, 09:52 AM
2002 30' Classic S/O
Fleming Island
Quoting Will Smith from "Independence Day", "I got to get me one of those."
Al
05-26-2014, 03:38 PM
Bend
, Oregon
Anyone have any idea what kind of propane tank cover/tray that is shown in the photo?
05-27-2014, 05:26 AM
Aftermarket supplier
Duncanville
We make those (and other things..) for Casitas
perfectcasita.com
06-03-2014, 06:40 PM
TetonStreamer
Delaplane
, Virginia
Here is the installation complete. The one Con is you have to unbolt the baseplate to get to the battery box. You can access Choke, On/Off Switch and Pull Chord while it is mounted without removing anything. I cover it with the Honda cover while traveling.
Wilson, WY 83014
06-03-2014, 07:34 PM
2007 25' International CCD FB
Northridge
I would love to not have to carry it in the Suburban with me but what about all the controversy about mounting items (especially heavy ones) to the frame?
LilNomad
begorragirl
2017 25' Flying Cloud
Denville
, New Jersey
Thinking of getting this...is it sAfe to run the generator there on the tongue as far as fumes are concerned? Where do u keep gas can?
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
06-03-2014, 07:39 PM
2005 19' Safari
GLENDALE
, AZ
I assume that since the lock is strong enough to keep someone from stealing the generator, that the Honda won't fall off during driving. Do you think the battery-box lid-hinge and lock are strong enough not to come off, too?
Looks like a nice installation; please let us know how this works out for you after a few thousand miles on the road.
Thanks for posting installation and photos!
06-03-2014, 08:54 PM
TetonStreamer
Delaplane
, Virginia
LilNomad
At 46 lbs I am not terribly worried about the added weight. It is not mounted to the frame but the battery box which is stoutly attached inside the A-Frame. I will post feedback after 1,000 miles and beyond.
Wilson, WY 83014
06-03-2014, 08:56 PM
TetonStreamer
Delaplane
, Virginia
As long as the front window is not open when you run it I would not think there should be a problem. Remember, you can unlock it from the mount and move it away from the rig, quite flexible.
Wilson, WY 83014
06-03-2014, 08:58 PM
TetonStreamer
Delaplane
, Virginia
I actually drilled into the flange of the actual battery box itself. It has 1/2" lips on either side of the box.There is no stress or torque on the lid or hinge.
Will do after 1,000 and beyond.
Wilson, WY 83014
06-03-2014, 10:05 PM
1978 28' Ambassador
Morada
Wow...That LowPro Lockdown rig looks like a GREAT value for $200...!
Rugged construction, smooth finish...good job..!
Ray & Pat; Morada, CA
06-04-2014, 01:09 AM
1948 22' Liner
Roy
, Utah
Now my gears are turning again. Thanks! :-)
"Some things you can tap. Some things you can hit. Know which one is which!"
1948 Airstream Liner 22'
06-04-2014, 06:03 AM
Mantua
, Ohio
Appears that it would be simple to create a tube to direct exhaust fumes in any direction you pleased if that were a problem. Jim
06-05-2014, 12:20 AM
Chicagoland
That turned out very nice. Thank you for sharing and for including the pics.
06-07-2014, 05:25 PM
What about noise and vibration? I keep mine on the ground a few feet away from the trailer with the exhaust pipe pointed away. It is almost inaudible.
06-10-2014, 08:58 PM
2012 27' Flying Cloud
Lake Oswego
, Oregon
Hey there, we are taking a trip to Yellowstone next month and I'm thinking about purchasing a Honda 2000i and the Low Pro Mount you have on your Bambi. I'm wondering how the set up has performed for you so far? Do you leave the generator on your Bambi when you're away from the trailer? Has the system posed any inconveniences for you so far? Are you 100% happy with the set up? Thank uou😄
06-11-2014, 07:21 AM
TetonStreamer
Delaplane
, Virginia
Just returned from 10 day trip around Wyoming and western South Dakota. We were boondocking in National and State Parks about 70% of the time and therefore on battery power. I left the Honda in the rack the whole time, simply removed the cover, cranked it up and charged the batteries. No more noise than having the generator on the ground. No exhaust issues in the trailer. Know that you cannot power the A/C with the 2000i unit. You can power the convection oven through the inverter although I do not know how healthy that is for the batteries. Overall it works very well. The only hassle is dealing with the cord, would be nice to have a hard wired plug in the A-Frame area. Don't forget to buy the Honda waterproof cover for the unit. It gets pretty wet back there when on the road in the rain.
Wilson, WY 83014
