Old 06-15-2014, 05:16 AM   #29
TetonStreamer
Teton Stream's Avatar
2017 23' Flying Cloud
Wilson , Wyoming
I would say it should have no problem. The beauty of this mount is that all one need to do to fasten it to the "base plate" (which locks into the mounted base) is remove the rubber feet, align base plate over the feet bolt holes and re-install the feet (through the base plate). If the 1000 and the 2000 feet template are the same you are golden.
Teton Streamer - in The Toaster
Wilson, WY 83014
Teton Stream is offline   Reply With Quote
Old 06-15-2014, 08:05 AM   #30
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Very nice installation. Unfortunately there is not enough room to mount a 2000i that has the tri-fuel conversion.
Al - K4GLU is offline   Reply With Quote
Old 06-15-2014, 08:17 AM   #31
Aftermarket supplier
widgetwizard's Avatar
Duncanville , Texas
That wont work.
The 1000 is significantly slimmer than the 2000 so the security aspect will be lost. A lot of work went into getting the 2000 mount just right.
jim
widgetwizard is offline   Reply With Quote
Old 06-19-2014, 07:15 PM   #32
2013 20' Flying Cloud
Between Here and There and Nowhere , what have you got?
If you bolted to the flanges of the battery box, how did you get nuts on the bolts?
openroad118 is offline   Reply With Quote
Old 06-22-2014, 10:42 AM   #33
TetonStreamer
Wilson , Wyoming
Drilled through both the battery box cover and the box flange. Bolt the bottom (receiver) section of the generator mount to the Battery Box, no problem feeding bolts through drilled holes and tighten nuts to secure.
Wilson, WY 83014
Old 06-22-2014, 11:38 AM   #34
Jeepers!'s Avatar
1965 17' Caravel
San Antonio , Texas
Based on what I read in other RV threads the EU2000 (which I also own) only puts out 8 amps with unregulated voltages, even with the special Honda "battery charging cord". I'm reading this thread with interest due to my imminent 65 Caravel purchase, but now I have doubts…
edit: 12v charging
Jeepers! is offline   Reply With Quote
Old 06-22-2014, 01:42 PM   #35
I don't mean to be obtuse, Teton Stream, but my battery box, also a 2013 20" FC, has battery box flanges bent INWARD, that is, into the box, toward the batteries. This would place the nuts in the box and impossible to reach. Or am I missing something?
Old 06-22-2014, 10:05 PM   #36
TetonStreamer
Wilson , Wyoming
Interesting, mine are bent outwards.
Wilson, WY 83014
Old 06-23-2014, 01:19 PM   #37
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
edit: 12v charging
As far as I know, none of the mainstream generators are great for battery charging directly (from the 12v output), but they'll run the converter-charger (or a regular battery charger) just fine. As long as your trailer is set up to charge its own batteries when on shore power you should be able to get just as much charging amperage on a 2k inverter generator as you do on 30A shore power.
— David
Old 06-24-2014, 12:54 PM   #38
2005 19' Safari
GLENDALE , AZ
Teton Stream,
If bolts go through battery box cover and mounting flanges, does this mean you can't open the battery box?
Also, are bolt heads and/or nuts exposed? Could a thief remove mounting bolts and take generator? (However, I assume the thief would also have to remove the battery box cover's hinge, too.)
Old 06-24-2014, 10:15 PM   #39
TetonStreamer
Wilson , Wyoming
Yes, you must remove the receiver plate to access the battery box. I have only accessed the battery yearly to add water and check battery connections so I did not see this as a terminal (sorry the pun) issue. The head are not exposed for they are concealed by the generator secured on top of receiver plate. (I apologize to engineering for bastardizing the terminology of your unit!) I do not believe a thief could remove the unit as installed and locked. The hinge has no impact on the security of the unit.
Wilson, WY 83014
Old 06-25-2014, 02:12 AM   #40
Duncanville , Texas
...The head are not exposed for they are concealed by the generator secured on top of receiver plate. (I apologize to engineering for bastardizing the terminology of your unit!) I do not believe a thief could remove the unit as installed and locked. The hinge has no impact on the security of the unit.
With access to just the nuts, the unit remains secure. The mounting bolts just spin if you try to remove the nuts. One day we will get around to making a video that shows this....
Old 07-11-2014, 02:07 PM   #41
2014 16' Sport
Dallas , Texas
Is there a model that will power the A/C (30 amp) by chance? Semper fi.
-- newowner
03SSGT is offline   Reply With Quote
Old 07-11-2014, 03:18 PM   #42
DKB_SATX's Avatar
1976 Argosy 28
-- newowner
For the generator in the thread title, the typical method is to use 2 (one being the Companion model) running in parallel.
If you want to do it with a single generator, Honda EU3000is, Yamaha EF3000iSEB, etc.
Some have reported success with the Yamaha EF2400iSHC with smaller AC units, and that often turns into a religious debate.
— David
Portable Generator Sound Levels: One Honda EU2000i vs. Two Paralleled Honda EU2000i AndyPenny Generators & Solar Power 19 06-05-2017 03:04 PM
Honda Generator EU2000i Theft Deterrent Bracket z8 hm Generators & Solar Power 1 02-17-2012 04:47 PM
Honda EU2000i Generator Pricing Jan.2005 markparker22 Generators & Solar Power 12 11-23-2005 06:49 AM
Honda EU2000i generator dhe9 Generators & Solar Power 4 04-12-2005 06:33 PM
