Old 04-08-2015, 11:26 PM   #1
Danny Bell's Avatar
1966 28' Ambassador
Colville , Washington
Honda 90 on back of 1966, 28' Ambassador ?
Just wondering if this is feasible and if anyone has done this ? My Honda trial 90 weighs 200lbs. Is this too much weight to add to the rear bumper ? Could this cause rear separation of body to frame ?
Thanks for your thoughts and experience,
Dan
Danny Bell is offline   Reply With Quote
Old 04-09-2015, 04:57 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
There are dozens, if not hundreds, of threads about this.
Search for "broken frame", "rear separation", "negative tongue weight", "moment arm".
Old 04-09-2015, 05:15 AM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Do use the "search function" to find those threads. But the short answer is that because of how they are built (semi-monocoque construction) It is a very bad idea to hang anything off the back of an AS. 200 pounds would just about destroy your trailer over a short period of time not to mention affect the towing dynamics in a bad way.
Don't do it.
Try and find a way to carry the motorbike in your truck bed provided you have the spare payload capacity.
Bob Martel
WBCCI# 5766
Old 04-09-2015, 09:24 AM   #4
Danny Bell's Avatar
1966 28' Ambassador
Don't do it.
Bob,
That's basically what my gut told me. I know 200lbs. in the rear could cause a lot of dangerous sway and I definitely don't want structural damage. It was just a thought, now I know. My truck has a shell on it but they make some nice mounts/carriers for the front of my truck for Honda 90's. I have to research the effects of overheating the truck due to air blockage. My old jeep wagoneer that I plow snow with gets pretty warm when I go to town for gas, so I fill it up with 5 gal. jugs I keep on the ranch.
Dan
Old 04-09-2015, 10:13 AM   #5
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I had a Bambi with rear separation due to a spare tire on the back bumper. More weight on a trailer with an even longer rear overhang would be even worse.
Stephanie
Old 04-09-2015, 10:13 AM   #6
Chelsea , Michigan
Images: 12
Good luck with your research, Dan. Airstream doesn't even recommend putting bicycles on the back of their trailers unless you use a specially designed (and expensive) bike rack that attaches to both the body and the bumper of the trailer for support. That bike rack would definitely not work for your motorcycle.
Bob Martel
WBCCI# 5766
Old 04-09-2015, 12:03 PM   #7
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Can you build a rack for the front of your TV? Back in the day, I saw everything from Honda QA-50s, CT70's/90/110's hanging on the front. Spare tires too. You can airbag the front to match the load. Personnally, I would avoid the problems you could possibly create.
Clayton
NavyCorpsman is offline   Reply With Quote
Portable Generator Sound Levels: One Honda EU2000i vs. Two Paralleled Honda EU2000i AndyPenny Generators & Solar Power 19 06-05-2017 03:04 PM
Honda EU2000 x 2 vs Honda EU3000 and Yamaha 3000 IntegrityAir Generators & Solar Power 43 07-01-2009 11:19 AM
Honda EU 3000 vs 2x Honda EU 2000 vajeep Generators & Solar Power 93 07-23-2008 11:02 AM
