12-01-2015, 10:39 PM
2007 28' International CCD
1999 34' Limited
2009 22' Interstate
Woodbury
Honda 3500 generator
I have an opportunity to buy a Honda 3500 genset. Would that be adequate for my 2800 international? Thanks!
12-01-2015, 10:53 PM
E Pluribus Aluminus
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Land Of Enchantment
, New Mexico
Yup, depending upon your load. The 3500 would easily run a 13.5K AC/heat strip and a few lights, TV, and the microwave. Depending on the age of the microwave, you may need to alternate with the AC. Would be careful if using electricity for the water heater.
Here’s an easy chart to give you an idea of power consumption: Generator Load Management Basics | Funroads RV Travel
and another with more details: http://rvservices.koa.com/rvinformat...d-amp-draw.asp
Good luck!
Jaxon
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
12-02-2015, 05:48 AM
Mantua
, Ohio
Might be noisy, but would run everything. Or do you mean a 3000?
12-02-2015, 05:53 AM
Sag Harbor
, New York
You should check your owners manual for the 28's various electric loads, and then compare them to the rated output of the 3500. This will permit you to make your own determination from the basic facts IMO. If you have added electrical loads you need (like an indoor or outdoor toaster oven, microwave, etc. etc.) you can decide which alternative gen is right for your use.
12-02-2015, 07:23 AM
1994 34' Excella
Warren
, Manitoba
I have an older Honda 3500 Gen set and it runs our 34' just fine. You do have to watch if you draw too much, just the same as being plugged in to 30 amp service. Only drawback is the weight of the unit and the noise. Chris
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
12-02-2015, 09:32 AM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Honda and many other generators make two basic types of generator - one for "construction" and one for homes/RV's/businesses. The contractor generator is so noisy it'll drive you insane if you have to run it anywhere near people.
Cheap that will get you thrown out of a campground or rally isn't a good deal... and the big ones do weigh a LOT.
Paula
12-02-2015, 03:14 PM
1999 34' Limited
2009 22' Interstate
Woodbury
Thanks to all. Some great info that I was not aware of. I think I will do the twin Honda 2000.
12-02-2015, 03:31 PM
2016 25' Flying Cloud
Holly Springs
, Mississippi
I came to the same conclusion. The 3500 is quite heavy--a two person job to lift. The paired 2000's can be loaded by one person and weigh less combined than the single 3500. Noise-wise, you do have two gens running (sometimes) but these units are remarkably quiet.
You won't go wrong with either Honda or Yamaha and both are about the same price point, as I recall.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
12-02-2015, 03:39 PM
Venice
I too have been prepping for a gen purchase. For our type of use either the Yamaha or Honda rise to the very top of the pile. My research tells me that most others are made in China & a service/repair network in non existent.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
