Old 01-27-2014, 09:19 AM   #1
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Heat for Boondocking
The only thing that keeps us from boondocking at this time of year in the desert is a heat source other than the electricity eating stock furnace. Has anyone installed a catalytic heater in a 25 or 27 FB. If so where did you put it? I don't see any wall space sufficient to place one.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 01-27-2014, 11:55 AM   #2
SteveH's Avatar
Common Sense , Texas
We had an '04 28' Classic with a catalytic heater and it was mounted on the side of the kitchen cabinets close to the door entrance above the magazine rack, as I remember.
Regards,
Steve
Old 01-27-2014, 01:50 PM   #3
1972 21' Globetrotter
Wylie , Texas
Have you considered small portable catalytic. I have a Coleman/propane that is my third string (after heat pump and electric vornado). So in case of power outage which did happen in ice storm this year, it moves up to starter. Power outage made me think of installing one permanent in the LP system(since I junked my suburban(?) furnace) that may move it up to 2nd string and even 1st in event of freezing temps. But the portable/small cans would definitely work for your 17'. I did noticed that some big boy units also offer the mount/portable option.
rippie is offline   Reply With Quote
Old 01-27-2014, 04:26 PM   #4
2006 25' International CCD
Laguna Niguel , California
Mr. Heater - Big Buddy or buddy models. They run on disposable canisters but you can also run off of bulk cylinder with a hose and filter attachment. Fantastic heater, I have used it for years. It has an auto shut off if it is knocked over and also has a low oxygen auto shut off.
msfitz is offline   Reply With Quote
Old 01-27-2014, 06:21 PM   #5
Central , Mississippi
Originally Posted by msfitz View Post
Mr. Heater - Big Buddy ...
And it's rated for RV use.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-27-2014, 06:58 PM   #6
deauxrite's Avatar
2007 27' Safari FB SE
Full Timers just passing through , Arizona for a couple of weeks and then on to Utah!
Smile Mr. Heater
Mr Heater is our choice for boon docking in the desert. Takes the chill off in the morning before sun up..the then sun takes over!
Living life on the Road
deauxrite is offline   Reply With Quote
Old 01-27-2014, 07:06 PM   #7
2012 20' Flying Cloud
Bishop , California
You might consider an Olympian heater. I use one in my 20 ft. Airstream. Olympians are not as sensitive to higher altitude changes as some others. I had a quick connect propane fitting installed inside my front lower storage cabinet (under the bed). It is easy to store the heater there. I would highly recommend an extra CO detector, leaving a vent space open and not using any catalytic heater at night when sleeping.
billdunlap is offline   Reply With Quote
Old 01-28-2014, 08:33 AM   #8
X2, I wouldn't sleep with a catalytic heater going.
We routinely boondock in Colorado in the fall where temps go down into the teens.
The stock two group 24 battery setup on our AS gets us through the night with thermostat set about 50. We sleep in sleeping bags.
During the day, our 200 watt solar charger almost completely recharges the battery and the Honda EU 2000 finishes the job.
handn is offline   Reply With Quote
Old 01-28-2014, 11:44 AM   #9
Gainesville , Florida
Cat heaters were standard in AS for years. My 73 AS and my 64 Avion each had a cat heater. Jim
Old 01-28-2014, 01:57 PM   #10
Wise Elder
Jammer's Avatar
2010 30' Classic
I don't consider them safe so have made other choices
My Cayo C-11 has a non-electric furnace in it, similar to the Newport fireplace that many Airstreamers have used. Mine doesn't have a window though:
DickinsonMarine.com - Propane Fireplaces
I have modified the wiring in my tow vehicle so that it has a second battery that connects to the charge line, and an isolator relay, and with that mod find I can run the furnace overnight without exhausting battery capacity. There are other electrical mods that are cheaper and more practical than a separate source of heat. More batteries, solar, modified converters so that batteries are charged more precisely
Old 01-28-2014, 02:32 PM   #11
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I've been following this thread and wondering what the problem is. My 24' Argosy has a single group-24 flooded battery, nothing special, though I do have LED lighting. Just recently I was boondocking in weather that was in the low 30s at night (but nice in the daytime.) Based on the state-of-charge tables for 12v lead-acid batteries I was around 75% in the mornings, maintaining about 60F in the trailer while sleeping and heating to a bit over 70F when I was ready to get out of bed.
That's with a bog-standard old NT-22a furnace, the new ones are reputed to be slightly better on battery use. I charged the battery up in the afternoons with a generator, I haven't invested in any solar for this trailer.
Granted I have no 12v propane detector, and pilot-light refrigerator and water heater, but modern trailers have 2x the battery so at the very worst that should be a wash.
— David
DKB_SATX is online now   Reply With Quote
Old 02-25-2014, 10:10 PM   #12
Kyle401's Avatar
1969 27' Overlander
SW , Missouri
Based on the current draw testing that I have done on my newer Dometic RM2652, the control board uses consumes about 0.8A in propane mode. If left on all day, it will use about 20 AH per day. That alone is equal to your total consumption. After I tested it, I regret even more that my original pilot light model puked ammonia on our maiden voyage.
I would imagine an auto-ignition water heater would be pretty similar. However, that is only a guess since my water heater is a pilot light model. It doesn't seem that there would need to be such a high draw to run temperature monitoring functions, but there is probably little incentive to increase the efficiency of these units since the RV trend seems to be heading toward bigger units with more amenities. Plugging in is assumed. Besides, Dometic is selling generators now too.
Kyle401 is offline   Reply With Quote
Old 02-25-2014, 10:29 PM   #13
1974 Argosy 20
Kooskia , Idaho
Just some more information, not disputing your numbers.
The refrigerator in my 2014 FC 20' uses (actual measurement) 0.32 amps and that only when the flame is on, virtually nothing when it is off. The water heater uses 0.74 amps when the flame is running, nothing at all when off.
The original refrigerator fan on the (stupid) side vented refrigerator however used 0.55 amps and was very noisy. I immediately replaced it with a larger, and much quieter one and have the fan current down to about 0.25 amps when it is running.
I believe the newest refrigerator 12 volt current is substantially lower than the older ones, but I can only report on what mine are, I don't have any older refrigerators to measure.
Old 02-25-2014, 11:03 PM   #14
Len and Jeanne
Len n Jeanne's Avatar
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley , British Columbia
How much heat do you need?
Like Handn, we've boondocked in "shoulder season" weather comfortably by keeping the furnace on at a low setting, and piling on extra bedding. We keep some spare sleeping bags in the bins above the bed, for use whenever the temperature dips down, and layer them on top of our regular bedding.
Electricity-eating uses are more of an issue than staying warm, but we've replaced a lot of our unit's halogen lamps with leds, we turn off the fridge and/or fridge fan a lot (as its insulation plus our frozen gel pacs keep the contents cold) and turn off the main switch when we're out for the day and don't need electricity. We also moved to a two battery system, and bring a generator.
Last February we were in Death Valley, followed by March in southern Nevada, Arizona, and Utah, and never found the cold indoors at night to be a problem.
Cold weather during the day isn't an issue. Either we're out and about, or else we wear sufficient clothing to stay warm.
The one piece of advice for cold weather camping is to conscientiously keep the humidity down inside: dry any wet items like towels, jackets and boots in the vehicle or outside, as you can otherwise get a lot of interior condensation on the walls and windows.
Len n Jeanne is offline   Reply With Quote
heat pump not switching to furnace Alumitater Furnaces, Heaters, Fireplaces & Air Conditioning 5 02-01-2014 06:20 PM
Aux Heat Element Question Ridgerunner3 Furnaces, Heaters, Fireplaces & Air Conditioning 2 02-12-2012 07:16 PM
Heat Pump glenbrowning Furnaces, Heaters, Fireplaces & Air Conditioning 9 01-04-2012 08:28 AM
Had the honor to step inside a 1962 Bambi this weekend and fell in LOVE with the heat J5MM LP Gas, Piping, Tanks & Regulators 9 03-14-2011 02:52 PM
Heat Pumps Brianv512 Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-19-2011 05:15 PM
