Old 09-20-2010, 10:09 AM   #1
Plonk
, , Minnesota
Hand carrying and loading water
Currently I'm parked in a situation where water has to be hand carried.
I do have tanks set up in my tow vehicle and can haul water and wastewater that way but for a bunch of reasons that isn't practical at this site.
I am currently using several collapsible 5 gallon "fold-a-carrier" caddys:
Amazon.com: Reliance Products Five Gallon Fold-A-Carrier II Natural Collapsible Water Carrier with Integrated Handle: Sports & Outdoors
and a pump that runs on flashlight batteries, to transfer the water into the tank in the trailer:
Amazon.com: AMERICAN WICK SI75 Kerosene Battery Operated SYPHON Pump: Home Improvement
I'm chlorinating the water for safety since I am concerned about possible contamination due to the extensive handling.
While all this is workable I have the sense that there must be a better way. What have you tried? What worked? What failed?
Old 09-20-2010, 11:22 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
I carry a 5 gallon plastic jerry can bought at Mill's Fleet whenever I go camping. I just pay no attention to the label 'Diesel' on the side. Before the trip I'll put a couple quarts of 10:1 water:bleach solution and splash it all around and run it through the threads & spout. Once I've done that, I feel there is no harm in rinsing it with clean water or air drying to lessen the chlorine taste.
I've run into some campgrounds where the water is not accessible from the road. Tettegouche State Park and Kimball Lake NFS (Cook County) are a couple examples. I honestly use it more just to keep from hitching up and pulling to a tap.
5 meter Langford Nahanni
Old 09-20-2010, 11:35 AM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
When I boondock or dry camp, I take my 50 gallon PCO fresh water tank and use a regular 12v pump (plugged into a 12v power point) to transfer the water to my Airstream.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 09-20-2010, 11:36 AM   #4
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Pretty much the same thing here except I got tired of pouring the 40# to start into the fill so I found a clear water line that fits the nozzle of our 5 Gallon tanks and then put them on one of our folding tables sideways to empty to the fresh water tanks.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 09-20-2010, 11:54 AM   #5
I tried those collapsable jugs but I hated them. They were hard to handle and lots of water ended on the ground.
I carry two plastic 5-6 gallon jerry cans with handles on the bottom making it easy to pour them into the tank.
We don't drink out of our water tank so purity is not an issue. We buy bottled water or take a supply from home. We like to camp near a mountain stream so we pump water out of the stream into the jerry cans. We carry a 110 volt pump. That hooks up to the Honda generator and fills up the jerry cans fast.
handn is offline   Reply With Quote
Old 09-20-2010, 12:04 PM   #6
modarch's Avatar
1967 17' Caravel
Memphis , Tennessee
I take my large cooler to a faucet, fill it up and back my truck up to the a/s. I have a small acrylic hose that fits over the cooler's water drain valve. Makes easy transfer to the fresh water inlet since the tube is narrow enough to let air escape out of the fillng fresh water tank. The acrylic tube is the same one I use to attach to the pump when winterizing with antifreeze. I too don't drink water from my fresh water tank so not too worried about contamination.
My restoration photos on Picassa:
1967 Caravel
modarch is offline   Reply With Quote
Old 09-20-2010, 01:27 PM   #7
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
We use 2 6 gallon jerry cans. I also carry a spare shurflo pump which I have short hoses on . I installed a lighter plug on the pump and a receptacle in one of the compartments to plug it in to to get around having to hold the jugs airborn.. The whole setup works well.
Black and gray are handled with small. 5 or ten gallon tanks. Something that can be dumped easily into a toilet or hoisted into the back of the truck. Towing a large tank limits where you can go dump. We just dump more often.
All this has worked out well, and I expect it will continue to until age keeps me from being able to lift 5 gallons
Rick Davis 1602 TAC TN-2 K8DOC
PP VAC 2002-03
61 tradewind, 70 Globetrotter
69 Ambassador 64 Overlander
Old 09-20-2010, 01:46 PM   #8
1975 29' Ambassador
Reno , Nevada
You should make sure your containers and pump are rated for potable water (i.e. "food safe") for short term transport, gas cans and such aren't much of a worry as long as they haven't been used for other stuff, I think.
It is not a bad idea to use a few drops of hypochlorite to your water. Public water supplies will have this taken care of and are frequently tested. Private wells are another matter and they need a disinfectant.
If your portable container is above the tank level and you have a hose or tube that will fit on its poor spout, you can usually start a siphon just by blowing into the vent.
With the bags, a simple squeeze should do. Get a vinyl tube that will fit over the spout and go from there to your tank fill. Clamp it. Put the bag on something above tank level, give it a squeeze and it should empty into your RV tank.
Old 09-21-2010, 03:39 PM   #9
2010 27' FB Classic
Ft.Worth , Texas
I like this idea about using the cooler w/hose for double duty. Last week I used the 5 gal. clear plastic foldable containers. Made several trips to get by for another day without moving the trailer. Didn't have a pump and had to lift the water to fill. What a PAIN!
I'll be doin' it the easy way from now on.
Old 09-21-2010, 04:19 PM   #10
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
We use two blue 7 gal. water containers from Gander Mountain. We lift the jug up onto the top of our propane tank. Attach a food grade tube to the spigot and then into the trailer's water intake which is just below the level of the water container. Gravity does the rest....Tim
Tim
TAC MI 14
Everyday is a Saturday
tkasten is online now   Reply With Quote
Old 09-22-2010, 02:34 PM   #11
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
Rv iv
Here is my simple solution.
Name:	Water Fill_small.jpg
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
rseagle is offline   Reply With Quote
Old 09-22-2010, 02:41 PM   #12
jdalrymple's Avatar
2009 27' FB Flying Cloud
Siloam Springs , Arkansas
I have 3 15 gallon barrels which I obtained from a local dairy. They contained food grade udder wash solution and were easily rinsed.
To move the water, I found a 12 volt pump (see link below) that has garden hose fittings on the inlet and outlet, and is self-priming. I wired on a trailer light connector to the pump to tap power from my truck at the tailgate. Works great from me.
12 Volt Marine Utility Pump
Jeff & Cindy
Remi & Hunter
'09 27FB Flying Cloud
WBCCI #7026 Air #17054
"Fus-A-Lodge II"
Old 09-24-2010, 08:22 AM   #13
WK57ABF's Avatar
2007 25' Classic
kendal , cumbria, UK
We use this 40 litre (10.6 US gallons) water carrier - no heavy weights to lift.
The manufacturer (www.aquaroll.com) has now started to make them in silver.
John in the UK
Name:	001 (640x480).jpg
ID:	111545   Click image for larger version
Name:	002 (640x480).jpg
WK57ABF is online now   Reply With Quote
Old 09-24-2010, 12:49 PM   #14
2010 27' FB Classic
Ft.Worth , Texas
John,
That's a cool product. Thanks for the link!
Question on loading AS... kidsgone Member Introductions 1 02-13-2010 07:52 PM
Weighing for axle loading check greatlakes Hitches, Couplers & Balls 5 01-02-2010 05:56 PM
Hand Pump Water Faucet - How to Test? tpezzolo General Repair Forum 0 03-30-2009 02:09 PM
Slow forum loading this a.m.???? Kistler Forum How-To's & Support 6 12-04-2006 03:02 PM
Problems with viewing pics.. not loading?? Happycampers Forum How-To's & Support 8 02-26-2004 01:16 PM
