Old 09-24-2010, 12:58 PM   #15
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Originally Posted by WK57ABF View Post
We use this 40 litre (10.6 US gallons) water carrier - no heavy weights to lift.
The manufacturer (www.aquaroll.com) has now started to make them in silver.
John in the UK
Very NICE idea - thank you.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 09-24-2010, 02:58 PM   #16
Wise Elder
Jammer's Avatar
2010 30' Classic
I wonder if they have a U.S. importer.
Old 09-24-2010, 03:52 PM   #17
wbrownrr's Avatar
2002 22' International CCD
San Luis Obispo , California
I stole the idea from rseagle (see post #11). Works like a charm, and no moving parts to break. This is similar to the idea in post #10. In fact, I also use a blue 7 gallon container which I bought at Walmart.
Wayne
2002 22' CCD
2008 Dodge Ram 1500 5.7L Hemi
wbrownrr is offline   Reply With Quote
Old 09-24-2010, 04:02 PM   #18
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
But how do you start the siphon from the top of the jug? I like that Aquaroll thing... I can't seem to find a US distributer though...
Marc
Old 09-24-2010, 04:06 PM   #19
WK57ABF's Avatar
2007 25' Classic
kendal , cumbria, UK
Don't know. Would it be worth asking one of your camping accessory stores to import them?
We import US accessories via a UK dealer purchasing from the Stag Parkway catalogue. With duties & taxes goods usually work out at 's for dollar price shown in catalogue.
As senior citizens and fulltimers we've found no easier way of hauling water.
John in the UK
WK57ABF is offline   Reply With Quote
Old 09-24-2010, 04:44 PM   #20
wbrownrr's Avatar
3Ms... as you can see in rseagle's picture, the water container is higher than the water fill opeining on the side of the AS. The tubing goes into the water container, then hold the open end lower than the bottom of the container and suck on the tubing until a siphon suction is created (water will flow freely and you might get a mouthful of water). Then the only tricky part is to quickly insert the tube into the water fill opening without losing the suction. Make sense? Actually, it's much easier to do than to explain!
Wayne
2002 22' CCD
Old 09-25-2010, 08:23 AM   #21
2010 27' FB Classic
N/A , Texas
Not sure it's really necessary, if you want to buy one. Looks like they will ship direct to you.
Old 09-25-2010, 09:38 AM   #22
Mexray's Avatar
1978 28' Ambassador
Morada , California
It's curious, on Aquaroll's shipping page, the pull down menu has just about any country in the world, EXCEPT the USA?
Their product looks like a good idea, and should sell well over her on this side of the pond...
Ray
Ray & Pat; Morada, CA
Old 09-25-2010, 10:02 AM   #23
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
We use a 45 gallon collapsable water bladder purchased at Camping World and a 12vdc pump (purchased at Harbor Frieght) that plugs into the rear outlet on our Expedition We pump the water from the back of the truck into the trailer with our freshwater hoses and the pump. Works very well. No lifting, pouring, spilling etc.
Both the bladder and the pump stow away in a very small space.
http://www.campingworld.com/shopping...45-gallon/1605
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
LHall is offline   Reply With Quote
Old 09-25-2010, 12:12 PM   #24
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
2012 30' Flying Cloud
Grand Rabbits , Michigan
Here's a water purification tip:
PUROGENE is an excellent water tank treatment, and can be used in drinking water. I would argue that it actually improves taste a bit, and we use it every time we fill our tank. It is available from Bay-Tec Containers.
PUROGENE Long Term Water Storage Treatment - AquaTank Water Bag
I buy the 16 oz. container for $30, and it only requires one ounce per 30 gallons of water. That conversion also works out to one milliliter per gallon. I use a medicine measuring syringe (plastic plunger type, but it at Walgreen's for less than $1).
I have found that the 7-gallon aquatainers work well for having extra water available and refilling our tank. Our Sport 22 has a 20 gallon tank, and with six aquatainers in the back of our truck, we travel with over 60 gallons of water.
Hibby
Hibby is offline   Reply With Quote
Old 09-25-2010, 12:14 PM   #25
WK57ABF's Avatar
2007 25' Classic
Ray
Yes, you are correct USA not mentioned. Yet if you click on "Buy on Line", then "Info", shopping from North America is mentioned under the heading "Making a Purchase". Cannot understand this.
Will phone the company on Monday and ask why no USA on their pull down menu.
Hope this helps.
John in the UK
Old 09-25-2010, 12:30 PM   #26
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
My setup is even easier than wbrownrr states. Get yourself a Super Siphon.
Amazon.com: Super Siphon w/ 6' Siphon Hose - TWO for 16.95: Sports & Outdoors
It has a glass ball in the copper fitting at one end. Place this in the water container and the open end into the trailer fill point. Make sure the container is sitting on a carpenter's helper above the fill point. Plunge the copper fitting repeatedly until the water column passes over the high point of the hose and it's down hill all the way! No sucking required.
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
rseagle is offline   Reply With Quote
Old 09-25-2010, 01:04 PM   #27
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
If we are staying in a location long enough to know we will have a need to haul water then we move into "water conservation" mode - which pretty much means using onboard water only when there is not another alternative - food preparation and clean-up is done outdoors, showers and daytime toilet use is a visit to the campground facilities (or lake and privy if not at a campground).
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 09-27-2010, 12:50 PM   #28
WK57ABF's Avatar
2007 25' Classic
Hope this helps.
John in the UK
Phoned Aquaroll this morning and they have insurance/compensation issues with shipping to the USA. However, www.campingworld.co.uk will ship a similar product to North America. The product is manufactured by Pyramid and called "Water Hog", below is a pic :
John in the UK
Question on loading AS... kidsgone Member Introductions 1 02-13-2010 07:52 PM
Weighing for axle loading check greatlakes Hitches, Couplers & Balls 5 01-02-2010 05:56 PM
Hand Pump Water Faucet - How to Test? tpezzolo General Repair Forum 0 03-30-2009 02:09 PM
Slow forum loading this a.m.???? Kistler Forum Admin, News and Member Account Info 6 12-04-2006 03:02 PM
Problems with viewing pics.. not loading?? Happycampers Forum Admin, News and Member Account Info 8 02-26-2004 01:16 PM
