Old 05-14-2019, 09:34 AM   #1
LiveDifferent411
2019 Basecamp
Rohnert Park , California
Gray-black water tank 411
Hello. I hadnít seen anyone talking about black - grey water tanks... issues, concerns or questions. Iím very new to RVíing. We bought a 2019 BasecampX. I wanted to ask the community if anyone has thoughts, or owns a Rhino portable tank?
Do you like it, hate it? Does anyone use or have experience with using a portable tank to empty their RV tanks? Thank you in advance for your suggestions and opinions.
We emptied our combo grey/blank tank for the first time yesterday in Bodega, Ca. Letís just say... it was a moving experience.
Rnorgrove is offline   Reply With Quote
Old 05-15-2019, 02:22 PM   #2
2016 23' Flying Cloud
Fanwood , New Jersey
We use Thetford portable tank:
https://www.campingworld.com/thetfor...nk-630090.html
It comes in handy from time to time. For example, when we camp at a state park that doesn't offer sewage hook up, we use that to dump without moving the trailer (ours is FC23D). It's really easy to use especially with two people (one person holds the business end of the hose while the other person tilts the tank).
We also use a macerator pump, called Flojet to dump the waste water into the portable tank because the hose connection of the portable tank is not quite secure (that's why we need two people for above operation).
We also carry three 7-gallon portable water container if we aren't sure about dumping situation during the trip. These containers are made for fresh water, but we are using them for waste water. With the macerator pump, it takes less than a minute to empty our 21 gallon grey water tank into three containers. Bring them to a bathhouse or public restroom to dump; very easy job.
Atsushi is offline   Reply With Quote
Old 05-16-2019, 08:29 AM   #3
LiveDifferent411
2019 Basecamp
Thanks for your sharing your experience. Itís great to hear that a portable tank makes sense in certain situations. I appreciate you taking the time to respond. Cheers.
Old 05-18-2019, 09:42 PM   #4
Len and Jeanne
Len n Jeanne's Avatar
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley , British Columbia
A "biffy box" is good to have in an emergency. Like having your waste water tank get completely full and backing up into your shower. (We had that happen.) We keep an eye on the diagnostic, but with a small tank, the level can jump from OK to full in a hurry.
If you're boondocking for more than a few days, see if you have other ways to responsibly dispose of gray water. We use rectangular plastic dish tubs so we can dispose of fairly clean waste water somewhere other than pouring it down the sin-- like in a campground utility sink or drain. Or just walking a very long way off into the bushes.
When showering, we've used the dish pans to capture water, for disposal outside in a responsible place. One quick shower that is sparing of the hot water (turn on, get wet, turn off, soap up, turn on, rinse off) seems to use about 25% of our gray water tank capacity if we don't capture some of it with dish pans and then dispose of it externally.
Len n Jeanne is offline   Reply With Quote
Old 05-18-2019, 09:46 PM   #5
Len and Jeanne
If you're boondocking for more than a few days, see if you have other ways to responsibly dispose of gray water. We use rectangular plastic dish tubs so we can dispose of fairly clean waste water somewhere other than pouring it down the sink-- like in a campground utility sink or drain. Or just walking a very long way off into the bushes.
Old 05-18-2019, 09:47 PM   #6
Len and Jeanne
Old 05-20-2019, 08:19 AM   #7
LiveDifferent411
2019 Basecamp
Great suggestion to collect some of the grey water. We too have a smaller than typical combo grey/black tank. Having a few extra solutions for longer than usual boondocking helps. Thanks for your post!
Old 10-10-2019, 12:21 PM   #8
Tamaroak
2019 25' Flying Cloud
Stillwater , Minnesota
And itís a good idea but o actually measure your tank capacities and compare to the gauge readings. Our blackwater tank holds 27.5 gallons. Advertised capacity 37! Itís a big deal when boondocking.
Tamaroak is offline   Reply With Quote
Old 10-10-2019, 02:34 PM   #9
Half a Rivet Short
Carlisle , Pennsylvania
Hi
.... actually better to understand that your tank capacity will change a lot with how you level your trailer.
Size wise - do you want one that will (almost) hold your tank contents? Do you want one that is larger than that? The more capacity you have the longer between trips. Also the longer you may have a (stinky) tank sitting there.
One downside of the portable tanks is that they have to go somewhere when you are under way. Once you have used them a couple times, they likely will not be traveling anywhere but in the bed of a truck.
Once full they are pretty heavy. Moving them on wheels / behind the truck works ok. Pushing them around by hand ... not so much. Depending on the roads into / out of your campsite, the little wheels may or may not be up to the task.
Lots of variables.
Black tank only for gray and black water??? mmollema Waste Systems, Tanks & Totes 9 02-01-2017 04:36 PM
Fall 2017 - F150 with 10 speed and 411 hp/434 lb ft??? SCOTTinNJ Tow Vehicles 16 05-23-2016 10:46 AM
Overflow from gray water to black water tank? Msmoto Waste Systems, Tanks & Totes 22 12-02-2015 10:41 PM
Oak Mtn St Park (Al)/ lincoln ParishPark (la)...any 411? Beer Snob On The Road... 2 04-29-2012 04:47 PM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 06:38 PM
