Old 12-03-2015, 06:00 AM   #1
2007 28' International CCD
1999 34' Limited
2009 22' Interstate
Woodbury , Minnesota
Genset alternative
Yesterday I went to a Northern Tool store to look at Honda 2000 gensets. I found a great alternative. NH have been selling and servicing Honda for years. They sold a lot of 2000 so they decided to make their own. They took all the most frequent service items and changed them for better service. They are called Powerhorse. The unit has both a 20 A and 30A receptacle on the front but you only get 30A using two. The cable to connect two comes with each one. But you do get a full 30A rather than 26.5A on the Honda. It looks identical to the Honda and weighs the same. If you should have a problem with it, you just bring it to any NH store in the nation. The salesman said every thing was better about it. He did say that it was a hair louder but not noticably. The best thing is that it sells for $599 rather than $999 and on sale now for $569. I was really impressed so I thought I would pass it on.
dickschaak is offline   Reply With Quote
Old 12-03-2015, 06:46 AM   #2
Images: 59
Did you buy one? Have you used it?
Old 12-03-2015, 07:01 AM   #3
Gainesville , Florida
What's an NH store?
Old 12-03-2015, 07:06 AM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I assume that is a typo and he means a Northern Tool Store.
Brian
SuEllyn & Brian McCabe
Old 12-03-2015, 07:10 AM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Northern Tool Store used to be Northern Hydraulics, hence some of us still think NH.
Old 12-03-2015, 07:36 AM   #6
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
A quick review of the specs shows Powerhorse to be slightly quieter than the Honda at idle and slightly louder at full load. Also appears to be several pounds heavier. Bargain price makes it an attractive option...
BambiTex is offline   Reply With Quote
Old 12-03-2015, 07:57 AM   #7
Images: 59
It's built in CHINA!
. . . and the Honda is built in Thailand.
Old 12-03-2015, 09:13 AM   #8
1999 34' Limited
2009 22' Interstate
Originally Posted by avionstream View Post
What's an NH store?
The company used to be called Northern Hydraulics & Tool (NH) Now it is just Northern Tool.
Old 12-03-2015, 09:16 AM   #9
1999 34' Limited
2009 22' Interstate
I lifted both in the store and there did not seem to be any difference. Maybe I am stronger than I think.
Old 12-03-2015, 09:46 AM   #10
1974 Argosy 20
Kooskia , Idaho
Both this generator and the Honda 2000 are rated at 1600 watts for long term use.
1600/120 volts = 13.3 amps for either one. Paralleling two would give the same 26. 5 amps on either set of generators. So, there is no difference in capacity.
Old 12-03-2015, 10:25 AM   #11
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Are two 2000w generators running in parallel noisier than one 3000w generator when powering the Airstream AC?
Kelvin
Old 12-03-2015, 10:42 AM   #12
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Same weight
I think you are right. A closer reading shows the 55 lbs to be Shipping Weight. I think genset weight is 8-10 lbs less.
Old 12-03-2015, 10:56 AM   #13
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Kelvin
At least apples-to-apples, yes. e.g. my Yamaha 3k is quieter than a pair of Yamaha 2ks, the "big" Honda 3k (EU3000is, not the "Handi") is quieter than the Honda 2ks. However, they're big heavy suckers and may not fit under a tonneau in the back of the pickup.
— David
Excella 500 Genset uwe 1973-1974 Excella 500 10 06-14-2010 08:58 PM
Available space for genset on Limited(s) 1982 thru 1994?? route66 Generators & Solar Power 3 02-14-2006 11:38 AM
McColluch Genset frozen chosen Generators & Solar Power 4 01-28-2006 08:55 AM
Genset exhaust routing ? TheGanzman General Motorhome Topics 7 12-06-2005 08:05 AM
Genset for Trailer Over59 LP Gas, Piping, Tanks & Regulators 0 05-31-2005 11:05 AM
