Old 10-30-2013, 06:47 AM   #29
Green Cove swprings , Florida
put a little marvel mystery oil in ethanol gas for the Honda generators it will free up sticky vavles
cgullseeker is offline   Reply With Quote
Old 10-30-2013, 08:47 AM   #30
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
I would be very careful what you add to the gas or oil of your generator.
A thimble full of stabil goes into the gas tank of ours before running the carb dry and draining the bowl prior to storage.
From a study of engine oil & fuel additives....
Detergents And Solvents
"Many of the older, better-known oil treatments on the market do not make claims nearly so lavish as the new upstarts.
Old standbys like Bardahl, Rislone and Marvel Mystery Oil, instead offer things like "quieter lifters," "reduced oil burning" and a "cleaner engine."
Most of these products are made up of solvents and detergents designed to dissolve sludge and carbon deposits inside your engine so they can be flushed or burned out. Wynn's Friction Proofing Oil, for example, is 83 percent kerosene.
Other brands use naphthalene, xylene, acetone and isopropanol. Usually, these ingredients will be found in a base of standard mineral oil.
In general, these products are designed to do just the opposite of what the PTFE and zinc phosphate additives claim to do. Instead of leaving behind a "coating" or a "plating" on your engine surfaces, they are designed to strip away such things.
All of these products will strip sludge and deposits out and clean up your engine, particularly if it is an older, abused one. The problem is, unless you have some way of determining just how much is needed to remove your deposits without going any further, such solvents also can strip away the boundary lubrication layer provided by your oil. Overuse of solvents is an easy trap to fall into, and one which can promote harmful metal-to-metal contact within your engine.
As a general rule of thumb these products had their place and were at least moderately useful on older automobile and motorcycle engines of the Fifties and Sixties, but are basically unneeded on the more efficient engine designs of the past two decades."
The gas tank and crankcase are much smaller on our Honda 2000...how much to add is an obvious concern regardless of the additives effectiveness.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 11-03-2013, 09:34 AM   #31
AirChief's Avatar
2012 19' International
Salem , Oregon
Use Ethanol Free
I use only real gas in all my small motors and it makes a world of difference. I run the gas out of the gas lines. No need for other products. I do know some areas don't have much access to ethanol free, so then you don't have a choice. However, if you can get supreme unleaded, your motors will do much better.
AirChief is offline   Reply With Quote
Old 11-10-2013, 05:39 PM   #32
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
After rereading the thread you may need to consider a large unit if your needs are hat great. I would research a specific model before jumping though. I would highly recommend Yamaha overall as they are direct drive not belt driven. Consider a tri fuel model that can run on propane no gumming and check the service life rating as it is a good indicator of the unit's life.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 11-18-2013, 10:44 PM   #33
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
While the Yamaha 6300 would certainly be adequate for two A/C units, I am also considering two Honda 3000 watt units matched up so they would provide 6000 watts. When only one A/C is needed in boondocking only one generator would run.
Has anyone used a pair of Honda 3000 watt EU3000iS in parallel?
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
