Old 01-02-2014, 10:57 AM   #1
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Funnel for freshwater fill??
I am looking for a funnel with the proper angle that can be used to fill the freshwater tank from 2.5 or 5 gallon jugs by one lone person. Donít want to pump it, siphon it, etc. Want to simply poor the water in from a jug.
So I am looking for a funnel that will support itself in the hole while one pours the water in. A 2.5 gallon jug of water weighs about 22 pounds and thatís doable with both hands but not doable if I have to hold the funnel as well. This is a common problem with the AS filler neck/door arrangement.
I have one of these and it takes two operators, one to hold the funnel and one to pour. Due to the constricted flexible tube, it is slower than Christmas as well!
I may dreaming here but perhaps someone has solved this problem without using pumps, siphons, tables, ladders, sticks, tripods, an octopus, etc.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 01-02-2014, 11:10 AM   #2
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Yeah, those fills are definitely designed for using a hose, aren't they?
What sort of spout or cap is on your jug? Could you rig up something with a hose on the end?
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 01-02-2014, 11:30 AM   #3
dznf0g's Avatar
Oswego , Illinois
Get a piece of clear potable hose at your favorite big box store that has an ID large enough for your jug spout and an OD small enough for the fill neck. Insert and pour away.
-Rich-
Old 01-02-2014, 11:52 AM   #4
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Connecting water hose to jug
I have a four gallon cubical blue plastic jug made by Reliance. It has a screw-off spigot. I took a regular water supply hose and cut off one end. I screw that hose into the fitting on the jug. I don't remember if it already had the right threads, or if it required an adapter from the hardware store. (Sorry, I don't have a picture and the trailer is parked in storage)
With this arrangement, I first insert the cut-off end of the hose into the water filler (far enough that it wants to stay put), then use both hands to lift the jug up to shoulder height for draining.
One of the reasons we use this method is, many commercially available funnels that are about the right size, are labeled as not being suitable for drinking water.
SSquared is offline   Reply With Quote
Old 01-02-2014, 12:15 PM   #5
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
But then a garden hose would tell you the same thing. How many times have you (we) taken a drink from a hose ???? Wash it with a bleach solution between uses if it makes you feel better and use the funnel.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 01-02-2014, 12:19 PM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
I have had good results using a Moller Scepter 5 gallon water can which has an integral spout that fits the water fill door in my trailer. I've tried a number of approaches over the years and it seems to work best. It also closes securely so that the water is kept sanitary while in transit.
Old 01-02-2014, 03:14 PM   #7
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Over the holidays one of my relatives got a very wide mouth funnel for filling the fuel tank on his circle track car. I'm thinking about getting one for the f/w fillin my 65 overlander. They cost about $15 from a race type shop
Cochese is offline   Reply With Quote
Old 01-26-2014, 12:47 AM   #8
mefly2's Avatar
2015 25' FB Eddie Bauer
Go to hardware store and buy some PVC reducers starting with the size you want in the funnel and ending up with 1-1.5 inch ... glue together with 45 degree elbow ... you get the idea,
Better yet get a designated "potable water" plastic tote (RotaPax) that cones with the spout that you can adjust to your best pouring angle for entry into your vertical fresh water inlet.
Old 01-26-2014, 08:10 AM   #9
Florida 55's Avatar
2008 27' Safari FB SE
Pfafftown , North Carolina
Images: 42
Reliance Water Jug
Al,
I bought four Reliance "Rhino Pack" 5.5 gallon water containers. They are BPA free. Made of heavy duty plastic. Are molded to nest together. Best of all the pouring spout that nests under the cap of the container perfectly fits the fresh water intake opening on the Airstream.
They can be purchased from Campmor for $16.99 each and free shipping for orders over $50.00. Here is link: Rhino Pack Containers at Campmor
We took them on our trip west in the fall of 2013 and they worked out great although you have to fiddle with the caps to insure they don't leak. I find the weight of 5.5 gallons is manageable when holding up the can to pour the water into the Airstream. Here are some pictures of the cans.
ID:	204374   Click image for larger version
ID:	204376   Click image for larger version
Chuck
Airstream - 2008 Safari 27FB SE (Sweet Pea)
TV - 2011 Ford F250 Lariat, 6.7 Diesel, 4X4 (Brutus)
TAC FL-55 | WBCCI 3823 - Unit 12 | AIR 48265
Florida 55 is offline   Reply With Quote
Old 01-26-2014, 08:44 AM   #10
Alphonse's Avatar
Lower Alabama , USA
Originally Posted by Florida 55 View Post
Al,
I bought four Reliance "Rhino Pack" 5.5 gallon water containers. . . . . .
Thanks Brother N, this is a better solution of a funnel. Got 'em on order!
Al
Alan
Air #64439
TAC AL-8
2018 Canopenian
Old 04-16-2014, 09:07 PM   #11
stephenh2's Avatar
Tyler , Texas
I cut the bottom out of a 20 ounce throw away water bottle, remove the cap, shove that end into the filler and start pouring. The bottle deforms to fit. I use a 6 gallon water jug with a spout. Works great!
Sent from my SCH-I605 using Airstream Forums mobile app
Home again in Tyler, Texas
Please visit any time!
stephenh2 is offline   Reply With Quote
Old 04-17-2014, 01:35 PM   #12
1999 28' Excella
New Orleans , Louisiana
We have a 5 gallon BPA plastic container with a spout and a hole for air intake. Went to HomeDepot and bought clear tubing that fit the spout. Set it on our table with a stool on top and let her rip. Water in the tank in less than 2 minutes..yeah!
badkat is offline   Reply With Quote
Old 07-02-2014, 09:06 AM   #13
bovk's Avatar
2011 20' Flying Cloud
Beaumont , Texas
I bring water in a 12 gal tank on my truck and I got a small water pump 12 volt that gets the electricity from truck hitch plug. The outlet is a garden hose I keep for fresh water. Lasts 2 days between water trips.
bovk is offline   Reply With Quote
Old 07-02-2014, 01:05 PM   #14
FCloud9's Avatar
Mohnton , Pennsylvania
Hi Badkat,
Do you remember approx. department/store area where you found the clear tubing...we've been looking at all our home centers & cannot find large enough diameter.
Many thanks...
FCloud9 is offline   Reply With Quote
