Old 06-10-2012, 10:03 AM   #15
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
Sounds like a great idea nm1oqrz, do you have a picture you'd like to share?
subfan1 is offline   Reply With Quote
Old 06-11-2012, 08:12 AM   #16
1988 25' Excella
Trumbull , Connecticut
Fishing Pole Storage
I would love to share a picture but I am totally lost on how to do it. I'll have to ask my son to help.
I would like to ask a question. Where do the posts end up after a few days. When I log onto the forums I could not find this thread and I had to do a search of my post to locate it. What am I doing wrong.
Happy camping nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 06-11-2012, 08:50 AM   #17
dznf0g's Avatar
Oswego , Illinois
Unles someone else has added to the thread since your last post, it will not show up in "new posts". I always look in "search" then "view all your posts" to find the thread which I may want to add to, but no one has responded to since my LAST post to that thread.
-Rich-
Old 06-11-2012, 09:51 AM   #18
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
For motorhome fishing rod storage, I found on the Clipper that there was a large finished dead space, approx. 6" high, in the basement under the waste tank. There was no OEM access to this space, so, a few years ago, I opened up the midship divider wall and welded in a small door frame with a sliding door, to be able to store the fishing rods in this area. Works great.
Sorry, I only have a picture of the work in progress.
Dave
Old 06-11-2012, 12:03 PM   #19
dznf0g's Avatar
Oswego , Illinois
Dave
Ingeneous solution! I have found many "dead spots" in my 30' Classic which I utilize for storage of various little used items....but alas, none long enough fo fishing poles.
-Rich-
Old 06-11-2012, 05:04 PM   #20
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
These are great ideas! I would LOVE to see pictures of the 88 excella belly storage. I wonder if I could add that to our 1989 excella!
Skatiero is offline   Reply With Quote
Old 06-11-2012, 05:29 PM   #21
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
The airstream in the link below has a rack above the bed. Interesting idea; I suppose it may depend on how expensive the rods are.
http://picasaweb.google.com/m/viewer...54048912005505
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 06-18-2012, 08:30 AM   #22
mefly2's Avatar
2015 25' FB Eddie Bauer
TV clothes hangar works well if you have a topper on a PU ... or longer SUV.
Old 12-01-2014, 06:54 PM   #23
overlander
california57's Avatar
1957 26' Overlander
IRA , Michigan
I use a schedual 40, 6 in. pipe cut to length w/threaded endcap under trailer next to black water storage tube
california57 is offline   Reply With Quote
Old 12-01-2014, 07:41 PM   #24
r carl's Avatar
Lin , Ne
I just use these, they have their own case.
Shakespeare Travel Mate Telescopic Spinning Rod and Reel Combo | Bass Pro Shops
Old 12-02-2014, 08:16 AM   #25
Originally Posted by AtomicNo13 View Post
Hi there,
We have installed an additional "sewer pipe" tube under the coach. It's a little investment in PVC pipe, end caps, and the hangers, but safe secure out of the way until you need it storage....
x2, the pipe carrier can fit in the car or truck or be used to ship rods if you are lucky enough to go to Alaska
handn is offline   Reply With Quote
Old 12-02-2014, 11:10 AM   #26
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
My fly rods have aluminum tube cases that they came in. For the others I made individual rod cases from 2" PVC tube for built in vacuum cleaners. Cut to length, add end caps and presto, all done.
Gearheart is offline   Reply With Quote
Old 12-02-2014, 04:41 PM   #27
2017 25' International
Joliet , Illinois
This guy sure made it look good on the ceiling.
bel73 is offline   Reply With Quote
Old 12-02-2014, 05:39 PM   #28
Lincolnton , North Carolina
That is gorgeous, and just became my "prototype"!!
northmeck025 is offline   Reply With Quote
