Old 08-11-2015, 12:11 AM   #1
2014 25' Flying Cloud
Orinda , California
Filling Up Water Tanks Before You Leave or On the Road?
I enjoy the quieter atmosphere of boondocking so I want to do more of it. My question is whether to fill up water tanks at home or on the road? If one does fill up on the road, are there particular facilities that offer potable water? Kind of like facilities that offer dump stations? If one does run out of water while on the road, where does one go to refill either the AS tank or portable gallon jugs?
Thanking you in advance.
Randi
DogGonnit is offline   Reply With Quote
Old 08-11-2015, 05:13 AM   #2
mandolindave's Avatar
Kind of by definition, Boon docking locations don't have a potable water source
Most of the festivals I go to have a water station to fill tanks, and I travel with empty tanks whenever possible.
When there is no water, or sulfur smelling water where I am going, I fill up tanks at home. I also bring four 6 gallon plastic jerry cans filled with water. I also use the jerry cans to transfer water, so I don't have to move my trailer
Water isn't free…Even if you don't pay for…someone IS. Either you pay the water company by how much is used, or you pay the electric bill for the pump that takes the water from underground. OR in some places like Canyonlands, someone pays the guy who hauls in the water on a truck.
mandolindave is offline   Reply With Quote
Old 08-11-2015, 05:37 AM   #3
Skater's Avatar
1995 30' Excella
Bowie , Maryland
We usually fill up at home. It doesn't hurt to carry around a full tank of water and might actually help (lower center of gravity from the weight).
On our recent road trip, we had several stops that didn't have water hookups, so we would refill at the prior campground (where we did have a water hookup) before departing.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 08-11-2015, 05:40 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
There are several reasons to tow with a full fresh tank. One of them is, if you have a problem on the road, you have a source of water to clean up after performing repairs. Another is a source of water if, for example, you have a problem with your tow vehicle that requires refilling the radiator.
Old 08-11-2015, 05:46 AM   #5
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I always carry at least one of my 52 gallon tanks filled. You just never know what the day will bring!
Better to have it and not need it than need it and not have it!
With that being said, I think the life and times if a full timer or nomad is much different than the weekend warier headed to the KOA!
Old 08-11-2015, 05:57 AM   #6
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
We're the "mug rumps" (Mug on one side of the fence, rump on the other.) I run with about a half full fresh water tank, and a few gallons of fresh water in the waste tanks. The Airstream is the cleanest "truck stop bathroom" we have found. We are hard pressed to use much more than 5 gallons of water a day. I resist loading extra weight if I don't have to.
If we are boondocking, then I would fill the fresh water tank for all the reasons we humans need water. Our trailers and designed to transport a full tank of fresh water, but it does add maybe 250 pounds of extra weight, almost always located ahead of the axles.
By the way, we are one of the few countries in the world where potable water is so readily available. We are blessed here in Minnesota with so much water available, at least when it isn't frozen.
David
Old 08-11-2015, 07:16 AM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
X2
FW always full at start-off.
FWIW.......100mi with a 1/2 full black tank 'duz wonders for keeping things loose & dump-able.
Old 08-11-2015, 09:24 AM   #8
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
We've been full-time for a few months and a good portion of our time out west has been dry camping/boondocking. Always start out with freshwater, and if you find water somewhere, top off. Because finding water is actually difficult.
I also carry 4 5 gallon Rhino water jugs for filling up the tank. That comes to about 20 gallons which is half of my 39 gallon tank. Two trips to a water source and we are full.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 08-11-2015, 10:19 AM   #9
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . While I hate hauling much of that 8.5 lbs per stuff around, Sunday past we were stuck behind a nasty accident on I-15 for almost 2 hours in 90+ heat. The girls with 3 horses in front of us were trying to water the horses, but the water pump in the trailer had failed. so we turned on the AS pump & provided several gallons of water for the thirsty beasts (while in the middle of the road). Quite the experience & they seemed happy. You never know, do you ? ! regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 08-11-2015, 10:21 AM   #10
Durango , Colorado
We always fill up before we leave on a trip.
One reason is because we have excellent quality water and a lot of water out West can be full of minerals, bad smell, or taste bad.
Another reason is so that we have a bathroom, lunch stop, and water available while traveling.
3rd I don't think the extra weight makes that much difference to our fuel mileage. My F-250 diesel averages between 11 - 14 MPG when towing full or empty. When not towing I get about 19 MPG.
4th the extra weight in the bottom lowers the CG and tends to smooth out the ride a little.
RVDreamer is offline   Reply With Quote
Old 08-11-2015, 10:25 AM   #11
Lily&Me's Avatar
Normal , Illinois
All of the above, and I prefer to keep my fresh water pretty full.
It is easiest, and often free, to dump your tanks at a public campground, at which time you can fill up as well.
If no public facility is available, private campgrounds usually allow this for a small fee.
If you were to become stranded for some reason, or stuck on a highway for hours due to an accident, having plenty of fresh water keeps you fully functional.
Maggie
Lily&Me is online now   Reply With Quote
Old 08-11-2015, 10:27 AM   #12
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Do you plan to drink the water?
Where does the water taste better?
I generally fill the fresh water tank at J. P. Coleman State Park because the water there tastes so good- better tasting than the water at home-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-11-2015, 10:27 AM   #13
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Since I have a heavy load already I tend to only fill the water tank full when I know that the campground I am going to has no water hookups at the site, and whose water quality is questionable. Where I know I have either good quality water available or hookups, I'll carry about 5 gallons. Enough to flush the toilet while enroute. If necessary I will fill at the destination campground or use their hookups if available.
If I'm carrying a full tank from home, I'll also carry 3, 7 gallon cans of water in my van. That gives me a total of 81 gallons of water to use. Typically we only go on one trip a year where I carry water from home.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-11-2015, 10:29 AM   #14
Will_Brule's Avatar
2014 25' FB Flying Cloud
Palestine , Texas
I always fill before leaving. 1. It is the water I am used to using. 2. Stops along the trip. 3. I've arrived at a campground at night, during a rain storm, or where the campground system is temporarily out of service. I also carry 6 gallons of drinking water in the AS (What if you get to a dry camp and your pump doesn't work until you repair or replace it?)
Will ~ "Blue Skies"
WBCCI #31443
"Don't follow me.
I've spent my life leading folks astray."
Will_Brule is offline   Reply With Quote
Filling certain prescriptions on the road. panora2 On The Road... 25 07-22-2014 03:36 PM
Fresh water tank filling when connected to shore water redzebra Fresh Water Systems 7 12-20-2013 02:52 PM
Furnace out-need help before we leave Dan S All Argosy Trailers 5 06-17-2011 05:17 PM
1st time filling both tanks,,,2010 Airstream THEPILL LP Gas, Piping, Tanks & Regulators 32 02-16-2010 03:13 PM
Do you empty propane before polishing tanks? Becky B. Cleaning, Stripping & Polishing 20 08-30-2009 07:03 PM
