Old 08-26-2011, 02:03 PM   #1
airperson
2006 25' Classic
Ft Worth , Texas
Electric winch for truck
I am thinking of checking out acquiring an electric wench and perhaps having one installed on the bed of my truck to lift heavy items such as generators. Has anyone had any experience with one. I would appreciate any feedback.
Airperson is offline   Reply With Quote
Old 08-26-2011, 02:17 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Is that some sort of robotic harlot?
ó David
Zero Gravitas ó 2017 Flying Cloud 26U | Il Progetto ó 1976 Argosy 28 Center Bath | WBCCI# 15566
He has all of the virtues I dislike and none of the vices I admire. ó Sir Winston Churchill
Old 08-26-2011, 02:23 PM   #3
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 36
Perhaps He Means Eclectic Wench...
one who enjoys a free-wheeling, Airstreaming lifestyle.
Ken L
1966 Tradewind 24
2018 GMC Yukon XL Denali
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 08-26-2011, 03:12 PM   #4
Erik Olson's Avatar
1974 29' Ambassador
CONCORD , North Carolina
Images: 20
Send a message via Skype™ to Erik Olson
I've used Warn (M8000) and Superwinch products on my previous vehicles. Both are excellent. As it is with tow ratings, you want your load to be well under the working limits as advertised by the manufacturers.
You will need to mount these winches via a rated bumper that can also take the fairlead. For safety, use the synthetic line (instead of the more dangerous braided steel cables) if you can afford it. Add to your kit a couple of rated shackles, a tree strop and snatch block along with a pair of gloves for safe pulling.
Superwinch -- EE -- Expedition Exchange Incorporated
Erik Olson is offline   Reply With Quote
Old 08-26-2011, 04:23 PM   #5
Iwannagocamping
Dakota's Dad's Avatar
Rineyville , Kentucky
This thread so isn't about what I thought it was...lol
See our blog here on how two RV/AS rookies tackle a 1979 Sovereign resto!!
Just the photos.. (sometimes you don't need the blog, just a picture worth a thousand words..)
1979 Sovereign International
2004 Ford Expedition Eddie Bauer
2 Golden Retrievers
Air #36788
TAC#3179
WBCCI #1265
Dakota's Dad is offline   Reply With Quote
Old 08-26-2011, 04:32 PM   #6
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
misteak?
I think the OP meant "eclectic Wench"-just sayin'
wmarsha is offline   Reply With Quote
Old 08-26-2011, 04:49 PM   #7
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
And carry a rubber mat to drape over the line in case it snaps
Phrunes is offline   Reply With Quote
Old 08-26-2011, 04:56 PM   #8
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
As a general rule, most electric wenches aren't much good at lifting heavy objects. They are more suited to a more intimate atmosphere.
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 08-26-2011, 05:25 PM   #9
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I am guessing that you are referring to an electric winch as a wench (electric or otherwise) might not do real well at hoisting a generator into your truck.
I would take a look at the electric hoists that are used to lift wheelchairs into vehicles. You also might take a look the manual hoist that they sell at RV supply stores to lift items on the rook of class A's.
Brian
SuEllyn & Brian McCabe
Old 08-26-2011, 05:38 PM   #10
airperson
2006 25' Classic
Ft Worth , Texas
Thanks Moosetags, electric hoists now that is worth looking into.
Old 08-26-2011, 05:50 PM   #11
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
If you pick a wench that is young and strong enough, she can lift your generator for you!
Old 08-26-2011, 06:10 PM   #12
airperson
2006 25' Classic
Ft Worth , Texas
Phrunes, My bride says that I will be singing 10 octaves higher if I even contemplate your advice. Sadly, she won’t even consider an old wench...
Old 08-26-2011, 06:12 PM   #13
Airline's Avatar
1972 29' Ambassador
grants pass , Oregon
Beer Wench
There's a Beer Wench at my house right now
anyone need another beer ?
Airline is offline   Reply With Quote
Old 08-26-2011, 06:29 PM   #14
Southwestern , Ohio
What do you have in mind? A winch mounted in the bed of your pickup can be used to pull something into the bed but won't lift anything by itself.
The two possibilities are using the winch in combination with a set of ramps to pull something heavy up the ramps, but that's a lot of stuff to lug around just to get one or two things into and out of the truck. (I have loaded machinery--lathes and milling machines weighing over a ton--into my truck using ramps and a come-along.)
The other possibility is a pickup bed crane like this one
Pick-up Truck Bed Crane
which work OK for lifting heavy machinery in and out of the back of a pickup, but aren't compatible with a cap over the bed--so once your generator or whatever is in the bed, it's still out in the open.
Nuvite-F is offline   Reply With Quote
No LP - All Electric, is it realistic? J.air.doe Electrical - Systems, Generators, Batteries & Solar 40 02-07-2015 05:40 AM
Total electric. Good idea or bad idea? EZstream Generators & Solar Power 34 08-17-2011 08:40 PM
Electric Brake Question Gastrolith Brakes & Brake Controllers 4 06-21-2011 08:11 PM
Electric Horn wiring diagram on a 345 John H. Classic Motorhomes 7 02-01-2011 03:07 PM
New Electric Service - YAY!!! or Life is Better When Everything WORKS!!! bugnot1 Winter Living 6 01-23-2011 10:32 PM
