Old 12-14-2015, 06:42 AM   #1
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
Dish Water, Shower Water, Gray Water...
This subject relates to boondocking so I decided to put the thread in that category. If it's been addressed previously I apologize.
For this thread let's presume you are in an area that you know does not allow dumping of gray water on the ground. Whether you agree with that or not doesn't matter. The local code, campground, ordinance, administrator, whatever has mandated that it's not permissible to dump gray water on the ground.
So my question is when does water become gray water? And related to that when does it become unacceptable to dump it on the ground?
Many RVers choose to capture their dish washing water and to a lesser extent their shower water and choose to dump it outside the RV. I'm going out on a limb here and saying many of us would do this, perhaps under the cover of darkness, and think it's okay. After all, tent campers in the same camping environment - particularly if it's remote camping - are doing the same thing. The forest ranger or similar authority may even turn a blind eye toward this practice.
But that's the same water that would have gone into a holding tank and certainly at that point would be... drum roll please.... GRAY WATER! and would most certainly not be allowed to be put on the ground.
I realize gray water accumulating in a tank for hours and days becomes rancid and foul smelling. But if you open your valve and let the water go directly on the ground in a continuous fashion the rancid, foul smell is avoided.
Back to the question. When does water we use become gray water and when is it permissible or not to dump it on the ground?
I'm not for or against any of the practices described above. I find it interesting that some RVers would never pull they gray valve and let water go on the ground but they don't mind throwing out a pan of dishwater. Similarly, administators of camping areas allow one practice but not the other.
Any comments?
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 12-14-2015, 07:09 AM   #2
Lily&Me's Avatar
Normal , Illinois
In my experience, dishwater and bath water are grey water, period. Once you have used water for any purpose, it is grey.
Pulling the plug on a full grey tank onto the ground is different than taking a basin and dumping it away from your site....which can be done when boondocking, in a remote NF site, etc.......unless it is specifically prohibited, which happens sometimes, particularly in bear country.
Signs then abound about the dangers of dishwater and scented anything on the ground attracting bears, and I have seen that diligently enforced by park rangers. Bear incidents in campgrounds often mean they have to be closed for awhile.
Where it's posted, it's prohibited, but I think "no dumping grey water" generally refers to opening the tank and letting it drain. Some signs are very specific, and some NF campgrounds provide dumping stations for those who need to do dishes, dump grey water, etc.
Other than where prohibited, it comes down largely to common sense and basic courtesy.
My thoughts.
Maggie
Old 12-14-2015, 07:35 AM   #3
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Gray water..the limiting factor
For me, the gray water tank filling is the limiting factor to how long i can boondock. On a couple other threads it was suggested to capture shower water in a pan, and empty this in the toilet. Also, dishwashing water can be placed in the black tank. So, one has, in my case, 76 gallons for waste water, covering the 54 gallons in the fresh water tank and the ten gallons of purified drinking water I carry.
As to dumping gray water, we can look at some examples of the railroads in the USA. Up until the mid 1990's Amtrak dumped liquified toilet waste, via a spray technique, on to the rails at speeds over 35 mph. Then when some folks below a railroad bridge were fishing in a creek and the spray come down on them, well, that was when it all came to a head..... no pun intended.
While I am unaware of any health problems as a result of the railroad operations, other than of course the fishermen, the public relations issue is large. And, for travel trailers, this may be another issue to be reckoned with.
My plan was to have a slow drip from my gray tank when on the road......which of course would lead to the comment...."gosh I did not know it was going to rain today"....
Whatever,.... with all the various access points for dumping tanks, maybe we all need to just comply with good sanitary practices.
Happy trails and Good Luck
AIR #31871 KQ3H
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 12-14-2015, 07:57 AM   #4
Mantua , Ohio
Some cg have specific areas for tenters etc to dump their wash basins. So it is not dumped into the bushes.
Old 12-14-2015, 08:04 AM   #5
aftermath's Avatar
Spokane , Washington
If you find yourself camped in a place that forbids the dumping of gray water, then you shouldn't do it. Some places really make a big thing of this, others don't, some are very crowded, others are well dispersed, some sites are dirt and gravel with little to no bushes or trees around while some are in lush forests. The point here, as in all things, is that there is a huge variety of situations and you need to pay attention to these.
I am of the school where dumping gray water is usually OK. I would NEVER simply open my drain and let it flow. I use a garden hose and direct the water to a nearby tree or bush. I do most of my camping in wooded areas which makes it easy. When we are at a place that doesn't work, I drag the trailer to the dump station.
I have mentioned this before on this forum and the "other" one before I got our Airstream. I find it funny when people are quick to rip into the practice when they often camp next to tenters, tent trailers and such who openly toss out pans of dishwater all the time. Just walk through a forest campground and you will see a tent trailer with a 5 gallon bucket sitting next to the sink drain.
It is important to always remain respectful of those around you and all those who will camp in the spot you currently occupy. Common sense and respect should always guide your decision.
aftermath is offline   Reply With Quote
Old 12-14-2015, 08:10 AM   #6
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
Funny thing is that many TT have an outdoor shower option and there seems to be no problem with that. Shower water goes directly onto the ground beside the trailer.
Gearheart is offline   Reply With Quote
Old 12-14-2015, 10:08 AM   #7
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Suffice to say, any water that has contaminates in it (food particles, soap, toothpaste, etc.) is "grey." Some campgrounds are so strict that they provide a dish washing facility for the tent campers so that they aren't tempted to rinse their coffee cups and fling the rinse water on the grass. If you are willing to play by the rules of the campground, or if you want to hold yourself to the highest standard, then any water you aren't willing to drink needs to go into your grey water tank.
I imagine that the trailers' outdoor showers are intended to be used to rinse off sandy bodies at the beach, muddy feet, or dirty pets, not for someone to soap up and take a full-blown-grey-water-generating shower.
I have spent time camping with some very hard-core enviro-friendly backpackers who swap out their hiking boots for "camp shoes" to minimize scuffing up the ground in the campsite, and forbid the use of tent stakes because they leave holes in the earth. They also swallow the rinse water after brushing their teeth and drink whatever water is used to rinse dirty dishes.
So if you want to extend your time boondocking, and your limit is based on a grey tank filling up, then rather than sneaking grey water into the bushes, try to minimize generation of grey water. Plan menus that minimize the dirtying of dishes, take sponge-baths instead of showers, use a bucket full of dishwater to flush/rinse the toilet, etc...
Old 12-14-2015, 10:55 AM   #8
Mantua , Ohio
Always thought the outdoor showers were for rinsing only,.
Old 12-14-2015, 11:51 AM   #9
kdickinson's Avatar
Taos , New Mexico
When we were at the Rose Parade rally we were not able to allow grey water to drain on the ground (we don't have a grey water tank). A blue boy is a great addition which allows you to empty the grey water into it then take it to an approved area to empty it in. They have wheels and can be easily pulled. I got mine at goodwill for next to nothing cost wise
kdickinson is offline   Reply With Quote
Old 12-14-2015, 12:05 PM   #10
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
grey water
What I did was install 2 grey tanks 1 for the shower and 1 for the kitchen ....although I can use them as one I have a valve for separating if I want. I rarely use them separately but it does give me the option to get rid of shower water only.
Ive always used common sense when it comes to grey water disposal in boondocking areas. If the tenters are hauling theirs to a dump I don't dump anything .
rucos is offline   Reply With Quote
Old 12-14-2015, 12:07 PM   #11
1977 31' Sovereign
Lynnwood , Washington
There's a significant difference between dumping a gallon of dish water vs dumping 20 gallons of gray water all in one spot.
At issue here is integrity. And surprise, surprise - integrity is how a man behaves when no one's looking.
It occurs to me you're just looking for justification to dump gray water when no one's looking.
Tom
TomKirk is offline   Reply With Quote
Old 12-14-2015, 12:10 PM   #12
Yertle01.com
TRizzuti's Avatar
2006 22' International CCD
Estes Park , Colorado
I don't know about the rest of the campers in the world, but it's very difficult for me to take a shower and not pee at the same time, so I don't dump my "gray" water on the ground.
Terry P. Rizzuti, "Yertle"
TRizzuti.com
Yertle01.com
"My two cents is worth every penny."
TRizzuti is offline   Reply With Quote
Old 12-14-2015, 12:25 PM   #13
2007 27' Safari FB SE
Lincoln , California
Bigbat
Most dish washing water contains food particles. I think that dumping on the ground may attract flys especially if it is dumped on the same bush day after day. It seems to me that dumping the gray water in the fire ring is somewhat better than on a bush. At least there is a chance it will be incinerated. It's always good for putting out the fire.
Bigbat is offline   Reply With Quote
Old 12-14-2015, 12:32 PM   #14
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
We stayed the night at a national forest campground last April in northern California .
It was quite early in the season and we had the entire campground to ourselves.
On the registration sign , the Forest service had placed a few dos and donts , among the dos it said to please find a deserving bush or tree and dump all gray water there .
We were more than happy to oblige .
dannydimitt is offline   Reply With Quote
Old 12-14-2015, 01:39 PM   #15
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I often wonder:
What is really the difference in an RV camper letting the water he brushed his teeth in, bathed in, cooked in, washed dishes in go on the ground and a tent camper doing the same thing? but the tent camper isn't regulated/prohibited-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 12-14-2015, 01:57 PM   #16
Mantua , Ohio
Originally Posted by m.hony View Post
I often wonder:
Some cg I have been do regulate the tenters by giving them a designated dump spot usually a raised gravel area or a regular dump pipe.
Old 12-14-2015, 02:27 PM   #17
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
When we camped in the Sierras at a campground next to a river no gray water could be dumped within100 ft. of the stream. They did allow us to release water on the dirt roads which helped keep the dust down. I put a sprinkler head on the blue boy hose fitting so the water was widely dispersed and walked along the road to our camp site.
Dennis
dennis3751 is offline   Reply With Quote
Old 12-14-2015, 03:04 PM   #18
rvb
rvb's Avatar
1977 Argosy 28
Euless , Texas
Grey water
I camped for years in tents while working with the Boy Scouts. Many camps provide a sump adjacent to the privy or rest rooms specifically for disposal of grey water. One Corp of Engineer's area had one restroom for the whole camp and directed us to dig a hole and use it as a grey water sump then fill it in before leaving. A general rule is if dish water is dumped on a tree or in the bushes it should be away from the camping area because any food particles will attract ants.
When I wash dishes, I wipe off any food residue or grease with a paper towel which goes out with the trash, then in a small basin in the sink use a spray bottle with a soap/water mix, scrub then rinse. This uses a lot less water and soap and most of the grease and food particles don't go in the water or in my tanks.
rvb is offline   Reply With Quote
Old 12-14-2015, 03:09 PM   #19
2000 30' Excella
2014 30' Classic
Princeton , Iowa
I can go up to 7 days with out dumping so I have not had a need. I worked all my life in the production of Milk, meat and eggs. In this production a lot of "by product is produced. If spread thinly on the ground I have never seen this "by product" hurt anything.
larryglarson is offline   Reply With Quote
Old 12-14-2015, 03:22 PM   #20
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Food particles are very obvious in dish water even after sitting in the grey water tank. I have found a partial solution, the sink drain now has a fine screen that fits the 1.25 inch opening. Grey water can be minimized by the way the dishes are washed and the type of showers taken. To reduce the water used in the shower change or modify the shower head to one with smaller openings, the dishes don't need to have a sink full of water, a soapy sponge(dilute the original dish washing detergent to make it easier to control amount used) and minimal rinsing will reduce the grey water volume. Paper plates without plastic layer can be burned in the fire pit.
On reading post above this, I would say other posters are more familiar with saturation camping, when a small site is used every day, too many dropping grey water will be a problem. Out on a farm or large space with occasional campers would make a big difference.
Tailgater Satellite Dish-DISH TV Mrjkq Computers, Internet & Satellite 15 11-11-2016 11:18 AM
Can you urinate in shower with gray water drain open? JoePaCO Full-Timing 65 08-21-2014 12:02 PM
Shower water and the Gray Water Tank MIKO92 All Argosy Trailers 16 07-22-2014 12:53 AM
345 Shower filled with gray water! sharptalk Sinks, Showers & Toilets 11 07-19-2011 04:30 PM
Shower Soap Dish Removal silversled Sinks, Showers & Toilets 1 11-27-2010 06:04 AM
