06-14-2017, 09:56 PM
#41
2017 30' International
Broomfield
Dexter Lift Kit on 2017 Flying Cloud 23D
Rich well done. Hahahah. What's next on the list?
06-14-2017, 10:21 PM
#42
2017 23' Flying Cloud
Parker
Haha... what ever you want to do on your new rig, my wife is over all the upgrades. She thinks I am a nut, doing so much work to a 6 month old trailer....
So get your list ready, and let me know [emoji6]
Troutboy
06-16-2017, 05:15 PM
#43
2016 27' Flying Cloud
Hartsburg
, Missouri
Seems several of us are on a parallel course with upgrades. I've been considering lifting our trailer. At first I considered fabricating my own components and getting a friend to help weld it, but now I see the kits are marked down to $128 on etrailer so I'm placing my order. Thanks Rich for a helpful post --Frank
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
06-16-2017, 07:53 PM
#44
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
Well I think I just got motivated to order then as well at that price. Next question will be do I rent an impact gun and round up/rent a couple floor jacks and extra jackstands and spend a day on it? Just returned from visiting the new SLC AS Dealer to check out their service dept for possible repair of two panels (impressed) and they said it would be 4-5 hours labor at $140 an hour if I provide the kit. $560-$700 is probably enough for me to put up with sore joints and scraped knuckles. Sure wish there were more of the $400 (including parts) Oregon guys around.
06-17-2017, 08:31 AM
#45
2013 25' International
Boise
, Idaho
Shop in Oregon
What is the Oregon shop? I'm in Boise, Idaho and it might make sense for me to work my way out there for an install. I want to do this, too.
06-17-2017, 10:02 AM
#46
2019 27' Globetrotter
Salem
, Oregon
McKay Truck, Trailer & RV, in Albany, Or (541) 928-3331
My install included the frame spacer kit #10 2.63T. The LP line is between the axels and they removed the line and reflare and reroute and leak test on the line.
I was very pleased.
PM me with any otehr info if you like. Total cost including kit was 378.00 but this was a year ago.
Dave
06-22-2017, 02:45 PM
#47
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
Lessons learned (re-learned) installing lift kit.
Buy or obtain a good impact gun. The heavy duty Milwaukee is everything they claim. At $300 it ought to be!
Start to finish it about 4 hours. In my case I had no obstructions on the inside rails of the frame. 30' FC.
15/16 open end wrench is necessary for holding the vertical bolts while tightening. I used a pair of vice grips to hold the wrench in place attaching wrench to frame, otherwise the wrench falls off just as you get ready to impact the nut. Horizontal bolts go in first and get tightened and torqued to 150 Foot lb. Vertical bolts next. Floor jack necessary, I didn't use any jack stands. Work on one axle at a time, leave the wheels on the other axle. One at a time.
06-22-2017, 05:28 PM
#48
Hartsburg
, Missouri
My lift kit arrived today. Will be installing it at a friends who has a big enough shop to pull the trailer in and he has impact gun. Along with the tips posted here, I'm hoping it goes smoothly. --Frank
Frank & Fran
Equalizer Hitch
06-22-2017, 06:58 PM
#49
Parker
Good luck Frank, you will do fine. Sheriff1, I'm sure it will be fine, but when you do it that way, there is no way to get the axel "untorqued" or loose for the lowering, so it is a little different approach and the discussion Boxite and I started to have earlier in the thread. Glad it went well, and I agree the impact gun makes a huge difference, in hindsight I should have used this as an opportunity to upgrade mine....
Troutboy
06-22-2017, 07:08 PM
#50
Senior Member
Sparks
, Nevada
I think you misunderstood, one axle is loose at both ends while trailer is supported by the second axle. Both spacers installed, one at a time then tightened.
06-22-2017, 08:15 PM
#51
Parker
Ahhhh, cool. That makes sense. How do you like it so far, did it give you the lift you were expecting.
Troutboy
06-22-2017, 09:51 PM
#52
Senior Member
Sparks
, Nevada
Looks better with lift and will help clear curbs. Same as I did to our 27FB so I knew what to expect.
06-23-2017, 12:27 AM
#53
The Aluminum Tent 3
Park City
, Utah
How did you hold up the trailer? Did you use blocks under the the axle you weren't working to raise the other, and use the floor jack to lower each axle one at a time?
06-23-2017, 08:03 AM
#54
Senior Member
Sparks
, Nevada
Left the tires on the axle I wasn't working on, no chance of it falling on you.
08-11-2017, 08:47 AM
#55
explorer
On the Road Full Time
, Utah
darn, I was wondering how the gas line reroute would go on a 23d. I think I"ll drill my spring plates so I can route it directly through the lift block, adding some rubbing protection to it.
Stupid question, but is the white gas line flexible? Or is it a copper line?
Currently Airsteamless. Looking for a toy hauler...
2018 Toyota Tundra
Follow our journey living and working from the road full-time: https://themoreweexplore.com
08-11-2017, 08:58 AM
#56
Salem
, Oregon
On my 2016 FB it was copper.
Dave
08-11-2017, 08:27 PM
#57
Parker
Its a copper tube, encased in a white Pex like tube. I think the apex is protection.
Troutboy
08-11-2017, 08:32 PM
#58
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
That is correct. It is PEX and it is there for protection
08-11-2017, 09:40 PM
#59
explorer
, Utah
Did you have to bend it to get it under the axle?
2018 Toyota Tundra
08-11-2017, 09:41 PM
#60
Parker
Yes, I bent it slightly. You need to be careful and not crimp it.
Troutboy
