Old 03-20-2016, 08:49 PM   #1
mcomeaux's Avatar
2016 27' Flying Cloud
Sunriver , Oregon
CPAP Machine Useage
We are planning on a trip that's going to be a few weeks. My wife uses a CPAP machine. I do not have a generator and was wondering if the inverter was activated for the evening with nothing else on would it run the cpap machine all night without depleting batteries? How do other members address this?
I appreciate any input.
Regards
Mike
mcomeaux is offline   Reply With Quote
Old 03-20-2016, 08:57 PM   #2
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
You need to know how much the draw is, a 2000 honda is super quiet and will run all night....
Old 03-20-2016, 09:54 PM   #3
McDave's Avatar
2014 23' Flying Cloud
Fair Oaks , California
CPAP Machine Useage
I've tried using the CPAP machine while Airstreaming, and generally find that it's too much of a hassle to bother with. I actually like using it at home, where it can stay in one place plugged in, and even if I get up at 4 AM to go to the bathroom, I turn it back on when I come back to bed. But in the Airstream, with wires running all over the bed, it's just more hassle than it's worth. I go backpacking, and my Dr said for a week or two it's no problem to go without it. Since we don't go out for more than a week or two at a time in the AS, I've pretty much stopped taking it there too. From the specs on my CPAP, you could run it all night with the inverter if the battery were fully charged. But the battery would be pretty far gone in the morning and you would have to charge it up again the next day. If your wife really needs to use the CPAP every night, you should get a generator.
P.S. Other things are always on: the refrigerator thermostat and fan, various sensors, the clock, etc., and the inverter itself draws about 2 amps whenever it is on.
McDave is offline   Reply With Quote
Old 03-20-2016, 10:01 PM   #4
2015 30' Classic
Pleasanton , California
You should be fine. Even the lastest machine from ResMed including all the bells and whistles (humidity and heater) draws 105 W from 120 V. That will consume 105 W / 120 V / 0.8 = 1.1 A from the battery. Add another 1.5 A or so due to the 1000 W stock inverter losses and your total current drain from the batteries will be 2.6 A. If you keep it on for 10 hours that's 26 AHr from your batteries. Since you probably have two 84 Ahr group 24 batteries, you shouldn't drain your batteries more than 50%, so you will have 84 AHr of capacity to use. Since the inverter and CPAP will only use 26 AHr, you have 84-26 = 58 AHr to spare.
If you don't have a generator, how will you make sure your batteries are charged for the next evening?
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 03-20-2016, 10:11 PM   #5
mcomeaux's Avatar
Sunriver , Oregon
Charging
I have solar panels and as I'm driving should charge them as well to.
Thanks for the answer. Someone else had mentioned it would be no problem but your answer gives me a bit more security. I'm probably going for a generator sometime in future but wanted to hold off a bit.
She does have the newest Resmed to that heats.
Old 03-20-2016, 11:00 PM   #6
Maniacal Engineer
barts's Avatar
Menlo Park , California
105W from 12v is 105/12 = 8.75 amps; this would drop a single group 27 to about 40% change over 8 hours. The resmed prob. doesn't draw that much, and the inverter costs some too.
My resmed draws about 1.5 -> 2 amps when running on 12V sans humidifier; it easily lasts the night on a single smaller 12V cell.
Solar panels are a big win here.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 03-20-2016, 11:15 PM   #7
1974 Argosy 20
Kooskia , Idaho
Many CPAP machines can run on 12 volt power directly with the appropriate power cord. If the humidifier part is not used, they draw very little power that way.
The topic has been discussed in other posts here, so maybe someone can find them and re post the thread.
Old 03-20-2016, 11:33 PM   #8
2015 30' Classic
Barts is correct. When the ResMed is powered from 120 V it's 8.75 A from the battery will all the features enabled. Best to try and run it directly from 12 V - it will be more efficient!
Al, K6IV
Old 03-21-2016, 12:12 AM   #9
mcomeaux's Avatar
Sunriver , Oregon
Thanks for all the replys!
Old 03-21-2016, 07:52 AM   #10
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I have about 12 years experience using mine in the Airstream. I run on 12 volts when not hooked up. I run on 110 when plugged in to shore power. I also carry a small inverter that will run it if needed. We carry a generator because we sometimes spend a week with no power and because our rig does not charge much when driving. I have had one of the 12 volt outlets short and burn out while running the CPAP. That is why I carry the little inverter. I do empty the tank and move the unit onto the bed when towing.
Old 03-21-2016, 05:58 PM   #11
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
Res med's input voltage is 24 volts. Hard to run that off of 12. In the summer forego the humidifier and power use is a lot less. I use a 400W inverter and a 150 watt solar charger and have no problems keeping the CPAP going all night.
Gearheart is offline   Reply With Quote
Old 03-22-2016, 12:57 PM   #12
NoNameinNM's Avatar
2016 28' International
Albuquerque , New Mexico
Regards
Mike
Hi Mike,
If you know you'll be dry camping in one spot for more than one night, consider battery packs made specifically for the CPAP machine. They also come in handy if you have a power outage at home.
My husband and I both use CPAP machines. Even though we ordered the factory solar with our Airstream last year, we decided we'd play it safe by acquiring the CPAP battery packs. There are a lot of options out there-- we chose these: http://www.sleeprestfully.com/produc...CPAP-Batteries
They are compact, come in their own carrying cases and are very easy to transport. We opted to put together kits with two of the batteries for each of us. I currently have the Resmed AirSense 10. If I turn the heated humidifier down to a setting of 2, I can get three nights out of a single charge. If I turned the humidifer off, I could probably get four nights, maybe a bit more.
We don't do a lot of dry camping and weren't sure how much use we'd get out of the battery packs. At the Balloon Fiesta Rally, the weather turned very cloudy, our solar panels never could recharge the batteries and we slowly lost ground over the course of the event (it didn't help that the first night had been very hot and we'd kept the Fantastic Fans running most of the night, which dropped the house batteries down significantly). That left us unable to adequately recharge the battery packs off the inverter, but since we live in Albuquerque and needed to make a trip back to the house anyway, we were able to take care of that at home.
We have a couple of trips planned that will involve dry camping for at least four nights. We bought a generator to ensure that we can always keep the battery packs and the house batteries charged.
NoNameinNM is offline   Reply With Quote
Old 03-22-2016, 02:40 PM   #13
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
I agree with NoNameinNM....battery packs are the way to go. I have the Resmed 10 and have had no issues in either my old Airstream or the new one.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 04-17-2016, 09:47 PM   #14
thanks for this
I am always grateful to those who are experienced and share their information in a positive and helpful way. I have a CPAP and am still learning how to use it while camping.
bd
dower.bill is offline   Reply With Quote
Airstream metal useage Inland RV Center, In Ribs, Skins & Rivets 6 09-27-2015 01:02 PM
Cpap Wildwash Batteries, Univolts, Converters & Inverters 8 08-28-2015 04:56 PM
12V power for CPAP machine. TomS Electrical - Systems, Generators, Batteries & Solar 16 10-30-2014 07:51 AM
3.0 Amp CPAP machine running off a Marine battery Lothlorian Off Topic Forum 9 08-15-2010 11:02 AM
Portable washing machine Sneakinup Washer/Dryer & Dishwashers 11 06-04-2009 07:54 PM
