Originally Posted by KirkBoy
Hello!
I don't know about all the others that have posted here, but my current Dometic and my past Norcold refrigerators all required 12 VDC even when switched to run on LP. My current fridge has an LED control panel and it's always on when the fridge is running. I've tried to find out how many amps the fridge uses while on LP, but the owner's manual doesn't say; it only lists amps when using 12 VDC to actually cool the unit. I'll bet it's pulling at least 1 amp. Does anybody know?
Kirk
.9 amps in the normal mode and .4 with the hidden Climate Control switch "off" for my Dometic.
I have 3 group 27's and just completed a 6 day stint with NO hookups. I monitor the charge with a TriMetric monitor, phantom draw plus the fridge pulls me down 2% a day (that would be 6% on a single battery). I never got below 89% even with 2-3 hours of inverter driven TV/DSS. A two hour tow only got me from 89% up to 91%. A all day tow always got me to 100%.
A crappy solar panel added 2% back, keeping me topped off if I had a low usage day, otherwise I ran the Honda 2000i for an hour in the morning + one more in the pm to get to 100%.
