Old 12-20-2012, 09:26 AM   #1
2007 20' Safari SE
Boston , Massachusetts
Catalytic heaters
Hi all. I've searched the forum for answers to this question, but haven't really found much.
I'm going to be doing a lot of boondocking this winter. It will mostly be in the Southwest, but I do expect to be in a number of places (northern NM, southern CO) where it will be quite cold in February/March. Boondocking for any length of time would be a real challenge if I'm using the AS propane heat system, due to the draw on the batteries from the fan. I'm thinking a catalytic heater with no fan might be the answer. Would love to hear from people who do cold-weather boondocking frequently -- do you use a catalytic? How many btu's should I be looking for to heat a 21' AS? Any other tips for staying warm while conserving battery power?
HermitCrab is offline   Reply With Quote
Old 12-20-2012, 09:47 AM   #2
1971 21' Globetrotter
Cave Creek , Arizona
We use an Olympian "Wave 8" in our 21' 1971 Globetrotter, and we like it!
It may be larger than we actually need, but it sure warms the place up well!
Plus, you can stand in front of it and warm your backside like a fireplace.
Be sure and follow the safety instructions if you get one, and most people advise against running it while you sleep.
"Money frees you from doing things you dislike. Since I dislike doing nearly everything, money is handy." Groucho Marx
snakecharmer is offline   Reply With Quote
Old 12-20-2012, 09:54 AM   #3
clicker187's Avatar
2013 25' FB Flying Cloud
San Gabriel , California
A buddy of mine has a Olympian "Wave 6" for his 27 foot...He likes it. It stores in the closet...don't forget to buy the legs and the cover. He also had a supply line with a quick connect add under the refrigerator.
He also suggested 12 volt mattress heated pads.
John T
clicker187 is offline   Reply With Quote
Old 12-20-2012, 10:20 AM   #4
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
We have a Wave6 as well, been using it for almost 10 years. On low it
keeps our 31 ft sovereign at 70 down to 30 out. Couple of things, we leave
a window cracked about 1 inch, we have a carbon monoxide detector, we have
a cover for it when not in use. It is on a permanent wall mount.
Jim in Pima Az, enjoying our 1975 31 ft Airstream Sovereign
Jim in Pima is offline   Reply With Quote
Old 12-20-2012, 10:44 AM   #5
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Are you planning on using your water while you're out boondocking? The furnace keeps your tanks warm through vents in the bellypan. The catalytic heater won't do that. It'll heat your living space just fine, though. (and do crack a window & have a detector if you use it!)
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 12-20-2012, 11:03 AM   #6
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
How much do you need to crack the windows When using it? Also do you loose all your heat with the windows open?
Silverflames is offline   Reply With Quote
Old 12-20-2012, 11:57 AM   #7
Excella CM's Avatar
1978 31' Excella 500
Venice , California
The heater consumes oxygen although it burns clean so you need to allow a little replenishment. 10 or 15 sq. in. is plenty. Using a ceiling vent will let the hot air out so use a window.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 12-20-2012, 12:56 PM   #8
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
We had something like that in our former trailer. It worked nicely. It was mounted on the side of the cabinet as you entered through the door. We never used it as a primary heat source but it would nicely take the chill off and warm the front living area.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 12-20-2012, 03:02 PM   #9
Wise Elder
Jammer's Avatar
2010 30' Classic
I know they're popular but I think they are dangerous and won't have one in my trailer.
For boondocking I have a gravity-vent furnace in my C-11 that doesn't require electricity. In my Airstream I just have the furnace, extra batteries, and provisions to charge the batteries from the truck alternator.
Old 12-20-2012, 03:07 PM   #10
1994 30' Excella
Mississauga , Ontario
There is a catalytic heater available that vents to the outside. It doesn't create as much trouble with condensation but does run a very small fan for the vent. Supposedly you don't need to have a window open.
Al
Al and Jean
TAC ON-3
Old 12-20-2012, 04:10 PM   #11
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Al
Do you know what the brand name is or where to find them?
MICHAEL
Old 12-20-2012, 04:17 PM   #12
1994 30' Excella
I believe a search for Platinum Catalytic heater will turn it up. I believe the company is west coast.
Al
Al and Jean
TAC ON-3
Old 12-20-2012, 04:27 PM   #13
AWCHIEF's Avatar
Images: 33
Found it:
http://ventedcatheater.com/6.html
Al, Thank you
MICHAEL
Old 12-20-2012, 07:34 PM   #14
Life of catalytic head due to poisoning
I have long thought of buying a Wave 6 but have been deterred because of reports of catalytic bed (or mat) contamination called poisoning which is not covered in warranty.
This occurs after a year or two use perhaps in normal conditions. I am concerned that the useful lifespan may not be that great.
I'd like to hear from owners whose experience may verify/ deny this.
Your comments....
Steve
Sav'h Steve is offline   Reply With Quote
