Old 04-19-2011, 11:24 PM   #1
1960 18' "Footer"
1959 18' Traveler
Durango , Colorado
Carefree truck camper awning on 1959 Caravan
Hi, my 1959 Caravan has the strip of metal that used to hold an awning. My old Carefree awning off of a Lance camper will slide onto this metal strip however the material hangs at a 130 degree angle instead of a 90 degree angle due to the curvature of the Airstream body. Is there a way to retrofit this awning onto my Airstream? Cost is my concern, I cannot afford to go buy a new one that was made for the Airstream...thanks in advance
jiffypop is offline   Reply With Quote
Old 04-20-2011, 12:39 PM   #2
Southwestern , Ohio
Hi, and welcome to the forums!
We used a "bag" awning intended for a pop-up camper on our 16 foot 1960 Pacer and it worked fine as-is. If the awning is in OK shape and you have all the hardware, I suspect you can use it just like it is.
Nuvite-F is offline   Reply With Quote
1968 Avion C11 Truck Camper restoration jforb Vintage Kin 310 01-04-2016 06:20 AM
Carefree Awning replacement toaster68 Awnings 4 04-14-2011 07:46 AM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
