Old 07-17-2015, 12:34 PM   #15
Originally Posted by idroba View Post
Only the Motorhomes have generators. Not the trailers. Well, there was a 12 volt generator option built in for a few years in the early 70's. It was not popular nor was it a good generator.
I had that 12 volt generator in my 73 31 foot Airstream.
When that generator worked, is was very good.
However, when you traveled the country, of course you change altitudes.
When that happens, all you had to do was adjust the carburetor, again and again and again.
As I recall, a change in as little of 1000 (one thousand) feet required another adjustment.
Then and only then, did that generator work properly.
Oh well, Airstream tried, as they always do, but sometimes it just doesn't work out.
How many remember pumping the black water into the hot exhaust system of the tow vehicle, but only when moving over 20 MPH.
Unfortunately, the pump would also work at a stop light.
Talk about being embarrassed.
Old 07-17-2015, 01:00 PM   #16
1974 Argosy 20
Kooskia , Idaho
Ah, the Thermasan system. It was supposed to be all automatic and only pump when going over 20 mph, but like many things, when it failed, it failed spectacularly.
The GMC forums had a member who designed and upgraded that system as his job. Unfortunately, by the time it became perfected the company that made it was tired of the start up system issues and caned the entire project. It also didn't really dispose of enough liquid per hour, so you had to travel a lot of hours to empty the tanks.
I am getting too old, Andy, and like you, remember too much.
Old 07-17-2015, 01:41 PM   #17
Remembering some things though, is far better than nothing.
At least you and I can say, "been there done that".
Old 07-17-2015, 04:08 PM   #18
Skater's Avatar
1995 30' Excella
Bowie , Maryland
There was also an option for a propane Onan 2500 (similar to what is in the Sprinters and B190s) in the 90s, for at least the 30' and probably the 34' trailers (it was in place of under-dinette storage). When we were buying ours, we came across one...that's the only reason I know. It included 40 lb propane tanks as part of the package. We didn't buy that trailer; it went for a lot more than we felt it was worth.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 07-17-2015, 05:51 PM   #19
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Are you serious?
Larry
Originally Posted by aa6rv View Post
Don't the Airstream's come with a Generator installed? I've looked at Airstream's for years and always assumed there was a built-in Onan 6 KW to hand the load. Even a 3KW Generator is pushing it's limits. But at least that will work. A 2K forget about it.
Or is this a backup Generator? You could take two 2K Generators and hook them up in Parallel to handle the extra load....but don't run out of gas on either one.
David
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 07-17-2015, 05:59 PM   #20
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Lewster,
Good grief, I had totally forgotten about the Thetford "ThermoSan" debacle back in the 70's. I had one installed on a "Discoverer" motorhome that was built on a Dodge chassis with the 413 engine.....
There was also a model of it that actually had a disconnect for trailers that had a pump and a hose that pumped the crap into the exhause system of the tow vehicle. As I remember those were also the early days of the catalytic converter. The crap as I remember was injected into the exhaust manifold ahead of the converter, and ruined many of them...
Ahhhh yes, the good old days!
Larry
Yamaha 2800 vs the Yamaha 2400iSHC gaylejoe Generators & Solar Power 14 04-30-2017 08:55 PM
Yamaha 2800: will it run a 13.5k AC? gaylejoe Generators & Solar Power 18 09-23-2012 12:39 PM
Generators -- Honda 2000 vs. Yamaha 2400 Redcobra Generators & Solar Power 33 03-07-2011 11:12 AM
Yamaha EF 2000 IA vs Honda EU2000 IA Chasmorgan Generators & Solar Power 14 07-15-2010 04:56 PM
