Old 09-16-2015, 09:08 PM   #15
Roving Sewist
DotTexas's Avatar
2003 25' Safari
Sanger , Texas
Bold and Adventurous... 1. the link too me to your blog that had not been updated since your first week Full-timing... Had any recent articles? 2. I also have a Ram 1500, pulling a 25' Safari. Until I had a tuneup lately, I was thinking it was underpowered. Working fine now. What kind of milage do you get pulling the A/S?
DotTexas is offline   Reply With Quote
Old 10-21-2015, 04:16 PM   #16
2016 25' International
Wanamingo , Minnesota
Boondocking with fresh water
My wife & I were campground hosts for 6 weeks in 2012 at Slough Creek Campground in YNP. There are no services at Slough Creek. The park supplied the hosts with solar panels & a 30 gallon water tank with a small 12 volt pump to transfer water to RV tank. I liked the system so designed my own. (see pics) I bought a 50 gallon flat bottom water tank from a farm supply store (make sure to ask if it is approved for potable water) & a 12v demand pump, just like the RV uses. I think the whole system cost around $200. I then built a plywood shelf to fit in the bed of our F-150 to set the tank on & mount the pump to. I wired the pump so I can plug it into my trailer 7-pin plug on the pickup for power. I can either fill the freshwater tank on our Airstream, or hook it to the RV city water hook-up & let the demand pump do it's job when water is needed. The tank is out of the way under our topper & we still have storage below it. Another advantage is I always have a replacement water pump along for the RV should I need it. I never travel with water in the tank. When I need water I make a trip with the pickup, fill the tank, then return to camper to fill tank.
ID:	250776   Click image for larger version
Scout1 is offline   Reply With Quote
Old 10-22-2015, 06:06 AM   #17
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Scout1 - that's pretty clever and certainly meets your needs.
SeeMore is offline   Reply With Quote
Old 10-22-2015, 07:06 AM   #18
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Before you pull your black tank, I would make sure your bathroom sink isn't plumbed into it. Some of the newer AS are...
Kay
Replacing black water tank with grey water tank cheetah1 Sinks, Showers & Toilets 25 10-02-2014 05:26 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Help! My '63 overlander need plumbing, hot water tank, and water supply tank! aprilr 1960 - 1964 Overlander 9 11-30-2011 08:52 AM
Boondocking question Roadtoaster Boondocking 9 11-01-2006 09:33 AM
Quick boondocking question.... Kestrell Water Heaters, Filters & Pumps 8 07-30-2005 08:20 PM
