Old 12-05-2015, 07:52 AM   #57
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
That 1,000 pound restriction sounds good 20 years ago with the much lighter trailers but becomes an issue with the current 28' models with a factory 2016 literature tongue weight of 976 pounds before any hitch is attached or propane is put into the tanks. Since the factory numbers are low to begin with, that model trailer tongue would always be overloaded.
Boondocking prep with install of new AC/DC and tanks KrisE MN Boondocking 6 08-15-2015 09:40 AM
20lb tanks vs 30lb tanks? AldeanFan LP Gas, Piping, Tanks & Regulators 5 04-05-2014 12:37 PM
'Convert' from 30# tanks to 40# tanks HeavyAssault LP Gas, Piping, Tanks & Regulators 19 11-28-2013 11:42 AM
Two used 40lb aluminum cylinders may be available eubank LP Gas, Piping, Tanks & Regulators 0 08-30-2011 10:18 AM
LP Gas Tanks: Replacing 20# with 30# tanks? Pete Vermont LP Gas, Piping, Tanks & Regulators 28 01-30-2008 08:34 AM
