Old 11-20-2015, 01:12 PM   #43
1994 28' Excella
Burkburnett , Texas
I use diesel in my truck and keep thinking that if I had the extra money I would install a Wallas XC Duo for a stove and backup heater.
Also would like to put in the Wallas oven and a cabin heater.
paulken is offline   Reply With Quote
Old 11-20-2015, 03:49 PM   #44
Gainesville , Florida
Originally Posted by PammieSue View Post
You would be the very first person to say so. Everyone else I have chatted with agrees with me, Airstream heaters just don't work well enough to actually heat anything up. We threw ours out with the trash.
You are correct about needing hookups or generator for our electric heater, that is exactly how we handle it. Chris says if we ran the generator all night long to run it, it wouldn't cost us more than a gallon, two at the most. But we don't run the heater at night, we sleep under quilts and blankets instead. Our little heater is one we bought from Camp World, it looks like a wood burning stove. I bought one like it for my little granny flat house here in Vista back in 2012 and it works just fine. I looked at a LOT of different heaters, read a TON of reviews, and then looked for the best price. I needed to heat up my whole little house, it doesn't have heat. It's the original house built on this piece of farmland back in the '40s. The one that I bought for the AS last year was less expensive than the one for my house, and it has a knob to turn the heat up and down. I like being able to have more than two temperatures, and it makes the place all toasty pretty quick.
Actually I've never heard anyone complain about the stock AS furnace. Guess I travel with a different crowd. Good camping.
Old 11-20-2015, 04:45 PM   #45
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
I agree, I don't have any complaints other than it currently doesn't work But it's worked fine for us up until that point.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 11-20-2015, 05:26 PM   #46
PammieSue's Avatar
1988 32.5' Airstream 325
Vista , California
Wallas | XC Duo | XC Duo | Easy and warm camper travelling
Pretty interesting, and thank you for showing us something different! Our AS Classic 325 Motorhome runs on gas, the Chevy Big Block Engine. When I was younger the price of Diesel was consistently lower than gasoline, but now they pretty much run neck and neck, sometimes diesel is even much more expensive. I do realize though, that diesel engines run more efficiently. If you do install one, and use it to heat your Airstream, please come back and tell us how that works. It says for small campers and shows a pic of a appears to be a Van type camper so I'm kinda leery.
Dysfunctional Veteran- does not always play well with others. 19 a day is 19 TOO MANY.
(19 recently revised from 20, revised from 23, revised from 22. Even the VA is a work in process)
PammieSue is offline   Reply With Quote
Old 11-21-2015, 06:15 AM   #47
Hope you get the furnace fixed. In your situation it must be very uncomfortable not to have it. Should be a simple solution, just don't know what it is. Any chance if getting closer to town and maybe finding any rv place to work on it? A furnace us a furnace and a good tech should be able to at least troubleshoot it. Under warranty is good but being warm is essential. Even if you have to pay to fix it, it might be worth it. Good luck, keep the kids warm, I know you will.
Old 11-26-2015, 12:19 PM   #48
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
Smokeless Joe had a 24 Argosy that he put a diesel powered stove and water heater into. The water heater was mounted on the A frame along with a diesel tank. He used the water to heat the flooring having installed pipes above the sub floor and then a new floor above the pipes. A circulating pump, outside of the coach, completed the install. That allowed him to ditch the furnace and also the propane. He towed with a Mercedes diesel van so fuel was not an issue.
Gearheart is offline   Reply With Quote
Old 12-01-2015, 06:33 PM   #49
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
I don't have a spare tire or the carrier on the Airstream.
BoldAdventure,
Could you please elaborate on your decision not to carry a spare? I think any weight reduction, especially on the tongue, is desirable. I have thought about leaving the spare at home but could not quite come to terms with it and remove it.
Thanks for your thoughts on this.
Steamy1 is offline   Reply With Quote
Old 12-01-2015, 10:19 PM   #50
Nomadic , USA
BoldAdventure,
I've done so in depth on my "Help me upgrade to 16 inch rims" thread. But basic premise is, 16 inch Michelin LT tires aren't prone to blow outs. Blow outs are 90% preventable. This leaves road hazards as the major source of flats. I carry compressor, tools and tire patch kit (mushroom style) and stem kit. I'm comfortable doing this. 22K miles driven, no issues so far. Lastly, the Airstream tandem axle per the owners manual says you can drive with one tire off at low speeds. Finally, road side assistance. It's a bit of a gamble, but I feel the odds are favorable if the risk is managed properly with care of tires.
I probably won't carry a spare until we go to Alaska, at which point I will.
Old 12-01-2015, 10:38 PM   #51
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We travel during the fall-winter-spring months so propane is often used for heat. It would be nice to have more than the two 30 lb tanks.
So without the spare tire and carrier (which I agree with), I wonder if there is a way to install a horizontal propane tank in that space, with connections to the propane system?
Doug and Cheryl
Old 12-01-2015, 10:39 PM   #52
1974 Argosy 20
Kooskia , Idaho
Airstream has said that for many years, but since it puts the load of both tires on to one, it drastically overloads that the remaining tire, making it much more prone to failure at a later time. Of course going very slow is a big help, but that is not really possible in many situations.
The only time I had to do it was in the Yukon many years ago, when I had already used my spare. I didn't know very much about tires then either. I don't remember any consequences but I didn't keep much track of each tire then.
Old 12-03-2015, 10:01 AM   #53
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
If tongue weight is an issue and one is towing with a truck, the trailer spare could be placed in the front of the truck bed.
Old 12-03-2015, 10:20 AM   #54
Nomadic , USA
That'd work for me, but with the way some talk about room in their trucks, I dunno.
With my battery upgrade, going to even steel 40lb tanks shouldn't pose a problem for me.
Old 12-04-2015, 07:25 AM   #55
My 6-volt Lifeline batteries have added weight to the tongue, but I have tried to mitigate this by switching to aluminum tanks. I think removing the spare is a viable option to shave off more weight after reading BoldAdventure's experience. Thanks,
Old 12-04-2015, 08:28 AM   #56
dkottum's Avatar
Good suggestion; another way to add 20 lbs propane without impacting tongue weight is to carry a 20 lb aluminum propane tank in the truck bed.
Yes these should be carried forward of the truck's rear axle (along with other gear in the truck bed) when possible to lessen the load the weight distribution bars must lift. Less weight in this area and less weight on the tongue allows lighter w.d. bars and less tension applied to them. Our experience is lighter weight here results in a softer ride for our Airstream and for us in the truck.
Of course any suggestion to lighten trailer tongue weight must be qualified with the need to have at least 10% of trailer weight on the tongue, and as Airstream requires this tongue weight must not exceed 1,000 lbs (check your Owners Manual).
I believe an effort should be made to keep heavy equipment over or between the Airstream and truck's axles, rather than loading the ends, for better stability.
Doug and Cheryl
Boondocking prep with install of new AC/DC and tanks KrisE MN Boondocking 6 08-15-2015 09:40 AM
20lb tanks vs 30lb tanks? AldeanFan LP Gas, Piping, Tanks & Regulators 5 04-05-2014 12:37 PM
'Convert' from 30# tanks to 40# tanks HeavyAssault LP Gas, Piping, Tanks & Regulators 19 11-28-2013 11:42 AM
Two used 40lb aluminum cylinders may be available eubank LP Gas, Piping, Tanks & Regulators 0 08-30-2011 10:18 AM
LP Gas Tanks: Replacing 20# with 30# tanks? Pete Vermont LP Gas, Piping, Tanks & Regulators 28 01-30-2008 08:34 AM
